6/30/26: I’ve finished installing the wiring for the rear lights and the gas tank sending unit. I tested the sending unit, and it’s working perfectly—which is a huge relief! To keep everything secure and looking factory-correct, I ran all the wiring through a fabric sheath and clamped it neatly along the frame.
With those tasks checked off, I’ve officially finished all the electrical work in the cab. Since that phase is wrapped up, I was finally able to bolt the seat back in place. Although the color is not the saddle tan it’s going to be, I can now pull the truck out of the garage under its own power! It’s starting to feel more like a truck again!
Seat installed
Phil
Project Journals
Stovebolt Gallery Forum
