| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,795 | On the SM-319 the lockout rod is moved by the 1st.-reverse shift fork as it goes into the R position. The rod is spring loaded into the "released" position so it disengages when the transmission comes out of reverse. The Saginaw most likely works in a similar fashion. Jerry
