Winter is Coming
Added a steering column floor mount to finish of the lower part of the column. Did have to widen (cut) the inner collar split to get it around the column and still need to fully screw it down.
Happy with how it looks so far.
Will be adding a leather type wrap around the column from the floor to roughly 6-8 inches up the column.
