| | | Forums66 Topics128,128 Posts1,056,664 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Dave says: Caution: " I do not recommend using the 1955-62 passenger balancer since the pulley is larger and may turn the fan too fast, leading to cracking. (to identify this balancer, the pulley is 6 3/4" OD X 5/8" outside to outside edge). USE: 1941-52 Harmonic balancer and water pump for ⅝" belt. 1953-54 Harmonic balancer* and water pump for ⅜" belt. " I don't know if this address your S--- hitting the fan.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | |
Entire Thread
Fan, Water Pump and Harmonic Balancer
| DadandSon | 02/17/2018 11:27 PM |
Re: Fan, Water Pump and Harmonic Balancer
| tclederman | 02/17/2018 11:48 PM |
| Leo | 02/18/2018 1:17 AM |
| tclederman | 02/18/2018 1:27 AM |
| DadandSon | 02/18/2018 7:03 PM |
| Hotrod Lincoln | 02/18/2018 7:43 PM |
| bartamos | 02/18/2018 7:53 PM |
| Frank50 | 02/18/2018 10:09 PM |
| DadandSon | 02/18/2018 11:14 PM |
| tclederman | 02/18/2018 11:41 PM |
| bartamos | 02/19/2018 12:10 AM |
| 52Carl | 02/19/2018 1:18 AM |
| tclederman | 02/19/2018 12:32 AM |
| DadandSon | 02/19/2018 2:34 AM |
| Hotrod Lincoln | 02/19/2018 3:24 AM |
| bartamos | 02/19/2018 10:29 PM |
| tclederman | 02/19/2018 11:09 PM |
| bartamos | 02/20/2018 12:00 AM |
| tclederman | 02/20/2018 12:09 AM |
| bartamos | 02/20/2018 12:12 AM |
| tclederman | 02/20/2018 12:38 AM |
| evac34 | 02/20/2018 1:48 AM |
| tclederman | 02/21/2018 1:50 PM |
| bartamos | 02/20/2018 3:34 AM |
| tclederman | 02/20/2018 10:43 AM |
| evac34 | 02/20/2018 3:59 PM |
| tclederman | 02/20/2018 5:02 PM |
| JW51 | 02/20/2018 5:31 PM |
| JW51 | 02/20/2018 6:09 PM |
| bartamos | 02/20/2018 6:39 PM |
| tclederman | 02/20/2018 9:18 PM |
| JW51 | 02/21/2018 12:18 AM |
| tclederman | 02/21/2018 12:36 AM |
| evac34 | 02/21/2018 1:50 AM |
| bartamos | 02/21/2018 4:06 AM |
| bartamos | 02/21/2018 1:57 AM |
| evac34 | 02/21/2018 2:10 AM |
| bartamos | 02/21/2018 2:21 AM |
| evac34 | 02/21/2018 2:55 AM |
| bowtietim | 02/21/2018 3:46 AM |
| JiMerit Boltr#43 | 02/21/2018 4:19 AM |
| evac34 | 02/21/2018 4:22 AM |
| bartamos | 02/21/2018 4:29 AM |
| Maybellene | 02/21/2018 1:00 PM |
| bartamos | 02/21/2018 4:44 PM |
| JW51 | 02/21/2018 5:17 PM |
| bartamos | 02/21/2018 6:16 PM |
| JW51 | 02/21/2018 6:36 PM |
| tclederman | 02/21/2018 8:47 PM |
| evac34 | 02/21/2018 6:43 PM |
| JW51 | 02/22/2018 12:49 AM |
| evac34 | 02/22/2018 4:45 PM |
| JW51 | 02/22/2018 5:29 PM |
| Pre '68 Dave | 02/21/2018 6:43 PM |
| tclederman | 02/21/2018 6:58 PM |
| bartamos | 02/21/2018 7:06 PM |
| tclederman | 02/21/2018 7:43 PM |
| JW51 | 02/21/2018 8:52 PM |
| tclederman | 02/21/2018 9:12 PM |
| bowtietim | 02/22/2018 12:56 AM |
| tclederman | 02/22/2018 4:54 PM |
| bartamos | 02/22/2018 8:21 PM |
| JW51 | 02/23/2018 1:24 AM |
| bartamos | 02/22/2018 8:56 PM | |
