0 members (),
94
2
Mod | | | Forums66 Topics128,127 Posts1,056,680 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 10,296 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,296 | Does it make any difference if his motor is 55.2? The OP has two problems. 1) His current parts do not belong together. 2) Even if they did belong together, they would still place the fan in the wrong position to pull enough air through the radiator. Whenever a TF or later 235/261 goes into an AD, it is best to go with the adapter plate which relocates the '53 water pump in the center of the radiator. An AD era fan will then work without hitting the harmonic balancer.
Entire Thread
Fan, Water Pump and Harmonic Balancer
| DadandSon | 02/17/2018 11:27 PM |
Re: Fan, Water Pump and Harmonic Balancer
| tclederman | 02/17/2018 11:48 PM |
| Leo | 02/18/2018 1:17 AM |
| tclederman | 02/18/2018 1:27 AM |
| DadandSon | 02/18/2018 7:03 PM |
| Hotrod Lincoln | 02/18/2018 7:43 PM |
| bartamos | 02/18/2018 7:53 PM |
| Frank50 | 02/18/2018 10:09 PM |
| DadandSon | 02/18/2018 11:14 PM |
| tclederman | 02/18/2018 11:41 PM |
| bartamos | 02/19/2018 12:10 AM |
| 52Carl | 02/19/2018 1:18 AM |
| tclederman | 02/19/2018 12:32 AM |
| DadandSon | 02/19/2018 2:34 AM |
| Hotrod Lincoln | 02/19/2018 3:24 AM |
| bartamos | 02/19/2018 10:29 PM |
| tclederman | 02/19/2018 11:09 PM |
| bartamos | 02/20/2018 12:00 AM |
| tclederman | 02/20/2018 12:09 AM |
| bartamos | 02/20/2018 12:12 AM |
| tclederman | 02/20/2018 12:38 AM |
| evac34 | 02/20/2018 1:48 AM |
| tclederman | 02/21/2018 1:50 PM |
| bartamos | 02/20/2018 3:34 AM |
| tclederman | 02/20/2018 10:43 AM |
| evac34 | 02/20/2018 3:59 PM |
| tclederman | 02/20/2018 5:02 PM |
| JW51 | 02/20/2018 5:31 PM |
| JW51 | 02/20/2018 6:09 PM |
| bartamos | 02/20/2018 6:39 PM |
| tclederman | 02/20/2018 9:18 PM |
| JW51 | 02/21/2018 12:18 AM |
| tclederman | 02/21/2018 12:36 AM |
| evac34 | 02/21/2018 1:50 AM |
| bartamos | 02/21/2018 4:06 AM |
| bartamos | 02/21/2018 1:57 AM |
| evac34 | 02/21/2018 2:10 AM |
| bartamos | 02/21/2018 2:21 AM |
| evac34 | 02/21/2018 2:55 AM |
| bowtietim | 02/21/2018 3:46 AM |
| JiMerit Boltr#43 | 02/21/2018 4:19 AM |
| evac34 | 02/21/2018 4:22 AM |
| bartamos | 02/21/2018 4:29 AM |
| Maybellene | 02/21/2018 1:00 PM |
| bartamos | 02/21/2018 4:44 PM |
| JW51 | 02/21/2018 5:17 PM |
| bartamos | 02/21/2018 6:16 PM |
| JW51 | 02/21/2018 6:36 PM |
| tclederman | 02/21/2018 8:47 PM |
| evac34 | 02/21/2018 6:43 PM |
| JW51 | 02/22/2018 12:49 AM |
| evac34 | 02/22/2018 4:45 PM |
| JW51 | 02/22/2018 5:29 PM |
| Pre '68 Dave | 02/21/2018 6:43 PM |
| tclederman | 02/21/2018 6:58 PM |
| bartamos | 02/21/2018 7:06 PM |
| tclederman | 02/21/2018 7:43 PM |
| JW51 | 02/21/2018 8:52 PM |
| tclederman | 02/21/2018 9:12 PM |
| bowtietim | 02/22/2018 12:56 AM |
| tclederman | 02/22/2018 4:54 PM |
| bartamos | 02/22/2018 8:21 PM |
| JW51 | 02/23/2018 1:24 AM |
| bartamos | 02/22/2018 8:56 PM | |
