| | | Forums66 Topics128,128 Posts1,056,664 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Hello, Dad and Son, Most likely, these are the parts you are trying to match up: (if these are not your parts, please post links to your parts, or part numbers) Chevs of 40s Short shaft water pumpClassic Parts 1955 fan blade 17 5/8"" diameter fan with 11/16" inch pilot hole. Fits 1955-72 6 cylinder and V-8 with short water pump. **(NOT FOR HIGH PERFORMANCE ENGINES OR FOR USE WITH THE SHORT SHAFT WATER PUMP)** Here is the 47-53 fan blade15 3/4" diameter fan with 1 inch pilot hole. Fits a 47-53 216 only. What engine/year fan belt pulley will you be using? - what width belt? - what groove-widths do you have for your: -- generator pulley? -- harmonic balancer pulley? -- fan pulley? (and, fan pulley-diameter?) Maybe someone else can help you. Since you have already bought your parts, it does you no good to be told that there were other ways to do this. | | | |
Entire Thread
Fan, Water Pump and Harmonic Balancer
| DadandSon | 02/17/2018 11:27 PM |
Re: Fan, Water Pump and Harmonic Balancer
| tclederman | 02/17/2018 11:48 PM |
| Leo | 02/18/2018 1:17 AM |
| tclederman | 02/18/2018 1:27 AM |
| DadandSon | 02/18/2018 7:03 PM |
| Hotrod Lincoln | 02/18/2018 7:43 PM |
| bartamos | 02/18/2018 7:53 PM |
| Frank50 | 02/18/2018 10:09 PM |
| DadandSon | 02/18/2018 11:14 PM |
| tclederman | 02/18/2018 11:41 PM |
| bartamos | 02/19/2018 12:10 AM |
| 52Carl | 02/19/2018 1:18 AM |
| tclederman | 02/19/2018 12:32 AM |
| DadandSon | 02/19/2018 2:34 AM |
| Hotrod Lincoln | 02/19/2018 3:24 AM |
| bartamos | 02/19/2018 10:29 PM |
| tclederman | 02/19/2018 11:09 PM |
| bartamos | 02/20/2018 12:00 AM |
| tclederman | 02/20/2018 12:09 AM |
| bartamos | 02/20/2018 12:12 AM |
| tclederman | 02/20/2018 12:38 AM |
| evac34 | 02/20/2018 1:48 AM |
| tclederman | 02/21/2018 1:50 PM |
| bartamos | 02/20/2018 3:34 AM |
| tclederman | 02/20/2018 10:43 AM |
| evac34 | 02/20/2018 3:59 PM |
| tclederman | 02/20/2018 5:02 PM |
| JW51 | 02/20/2018 5:31 PM |
| JW51 | 02/20/2018 6:09 PM |
| bartamos | 02/20/2018 6:39 PM |
| tclederman | 02/20/2018 9:18 PM |
| JW51 | 02/21/2018 12:18 AM |
| tclederman | 02/21/2018 12:36 AM |
| evac34 | 02/21/2018 1:50 AM |
| bartamos | 02/21/2018 4:06 AM |
| bartamos | 02/21/2018 1:57 AM |
| evac34 | 02/21/2018 2:10 AM |
| bartamos | 02/21/2018 2:21 AM |
| evac34 | 02/21/2018 2:55 AM |
| bowtietim | 02/21/2018 3:46 AM |
| JiMerit Boltr#43 | 02/21/2018 4:19 AM |
| evac34 | 02/21/2018 4:22 AM |
| bartamos | 02/21/2018 4:29 AM |
| Maybellene | 02/21/2018 1:00 PM |
| bartamos | 02/21/2018 4:44 PM |
| JW51 | 02/21/2018 5:17 PM |
| bartamos | 02/21/2018 6:16 PM |
| JW51 | 02/21/2018 6:36 PM |
| tclederman | 02/21/2018 8:47 PM |
| evac34 | 02/21/2018 6:43 PM |
| JW51 | 02/22/2018 12:49 AM |
| evac34 | 02/22/2018 4:45 PM |
| JW51 | 02/22/2018 5:29 PM |
| Pre '68 Dave | 02/21/2018 6:43 PM |
| tclederman | 02/21/2018 6:58 PM |
| bartamos | 02/21/2018 7:06 PM |
| tclederman | 02/21/2018 7:43 PM |
| JW51 | 02/21/2018 8:52 PM |
| tclederman | 02/21/2018 9:12 PM |
| bowtietim | 02/22/2018 12:56 AM |
| tclederman | 02/22/2018 4:54 PM |
| bartamos | 02/22/2018 8:21 PM |
| JW51 | 02/23/2018 1:24 AM |
| bartamos | 02/22/2018 8:56 PM | |
