1 members (Thomaslb),
138
Mod | | | Forums66 Topics128,080 Posts1,055,954 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | just curious as to where your exhaust exits on your truck.just seeing what others are doing. do yours run all the way out over the axle,or in front of the wheels out the side or are you just using turn-downs off the muffler(s)......dave 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
| | | | | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | Mine are turned down just behind the rear fenders. Looks and sounds great.  | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | My 55 exits behind the rear axle and under the rear bumper.Whereas my 65 exits in front of the rear wheels.Course I am running Flowmasters on both of them,and they both sound good.Its ust a matter of personal taste. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I like em to exit out the back under the rear bumper with chrome tips. Not good if its lowered & go down steep drives. Also not good on a panel truck. Fumes can come in. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jul 2006 Posts: 707 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 707 | Just forward of the left rear wheel, cut flush with the running board. I can seeit through my mirror and hear it as I drive if I open the window. 1951 3800 Be the change you want to see. -hotshoe
| | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | It's just forward of the pumpkin on the right side of the firetruck. vents fumes away from the pump operator while flowing water out of fire hoses. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I will run mine back under the rear bumper. ...want all those guys behind me to see em...
~Jim
| | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | I haven't decided yet. Thought about under the running boards just in front of the rear wheel with a flattened tip that exits through the board itself, but I will be using flowmasters & don't want it to be too loud in the cab. I've also seen some that dump just over the rear axel that look pretty good. I suppose I'll cross that bridge when I get to that point.
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Aug 2007 Posts: 610 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 610 | im thinking of running side pipes on my 3/4 ton truck. its already got dual fenton headers. originally had dual going out over the rear axle and under the rear bumper, but had to remove them to fit my 16gal aftermarket fuel cell inbetween the frame rails and behind the rear axle. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | And getting back to the stock location, and just where can one find exhaust systems for an AD? Looks like all of the vendors quit handling them. As one of out members recently wrote about, the muffler shops only have one standard bend they can make and it doesn't match the sweep at the head pipe. You could get away with it on the hump going over the rear axle but it looks to out of place up front. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Dec 2006 Posts: 33 Junior Member | | Junior Member Joined: Dec 2006 Posts: 33 | On my 55 2nd, the exhaust exits over the axle and out under the rear bumper with chrome tips. Looks and sounds great. http://www.novich.com/55Chevy/Back.jpg | | | | | Joined: Aug 2002 Posts: 455 Shop Shark | | Shop Shark Joined: Aug 2002 Posts: 455 | All depends how much sound you want and what portion of it you like to hear.
With short mufflers and tail pipes exiting before the rear wheels you hear the whole range of sounds of the engine, plus the sound that bounces of walls and other cars in the other direction. Gives a rawer and louder sound.
Same mufflers with longer tail pipes exiting straight out the back and under the bumper would make things a lot quieter inside the cab, even with windows rolled down. Gives a softer and quieter sound.
One thing is very important for a balanced good tone - equal length pipes !! Also reduces popping at deceleration.
I had a little fun this summer and drove with straight pipes exiting right under the cab... Crazy how huge the sound of a 235 with headers and straight pipes get. With 24x3 tips it sounded like a big block or 3 Harleys at once - no kidden. Way too loud for a driver, but was fun for about a week. | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | In the coe about 4' from the exhaust manifold!  Sounds great! Eventually Ill run it out and drop it just forward of the rear axle. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I like side outs just before the rear bumper on pick-ups. I pull trailers and stuff and don't like full exhaust blowing in my face while hooking up or the black soot getting on my trailer or boat, Scott | | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | What size pipes are you using? I'm thinking 2 1/2" inches.
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Nov 2000 Posts: 582 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 582 | I have Patrick's dual stainless exhaust. Exits just below the left side of the bumper in a shotgun style. Looks cool! | | | | | Joined: Aug 2002 Posts: 455 Shop Shark | | Shop Shark Joined: Aug 2002 Posts: 455 | Pipe diameter depends on rpm. Stock 235 with dual exhaust likes 1-3/4" to 2". Any larger and you lose low end torque. | | | | | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | Fentons with 2" duals and Patricks dual in/dual out stainless muffler. The pipes run straight out the back w/ bowtie tips. Keeps it more quiet in the cab and keeps the tailgaters at bay! | | | | | Joined: Sep 2005 Posts: 191 Shop Shark | | Shop Shark Joined: Sep 2005 Posts: 191 | On my 67 they exit in front of the rear wheels, but they're rusted pretty bad and will need replaced. I'll probably run them over the axle and out behind the rear wheels, never liked straight out the back on a truck when I work with them. | | | | | Joined: Feb 2007 Posts: 385 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 385 | On The Road Again, I've read a little about exhaust tuning and never seen anything about pipe size versus torque, except maybe on two strokes.
Please tell me I'm wrong that the best thing to do with exhaust pipes is use a size that reduces back pressure as much as possible.
Headers are a different matter. Differences in horsepower and torque from different header designs are easily documented, but I've always heard that max values are achieved when the headers are run open. No other exhaust system at all. That made it seem to me that best performance, both power and torque, would be achieved with the least amount of back pressure.
I think I may be able to do some experiments with back pressure in the not too far distant future. If I do, I'll share my results.
195? Chevy 3800 dump truck 1973 Chevy C30 cab and chassis 1987 Suburban 3/4 ton 6.2L Diesel
| | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | my 292 runs a stovebolt cast 3+3 header to a walker, out over the axle to the rear then down, dual 1.5'' in - single out 2.25''. all under the driver side, w/ muffler as far back as possible.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Oct 2006 Posts: 166 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 166 | Mine exit on each side right before the rear tires. I like it.
SUPPORT OUR TROOPS "Some people wonder all their lives if they've made a difference. The Marines don't have that problem." -- Ronald Reagan 1966 Fleetside SWB Webshots | | | | | Joined: Jul 2006 Posts: 707 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 707 | I've done a bunch of experimenting with back pressure on motorcycles. A smaller diameter pipe = better performance at low and moderate RPM's, and better fuel economy. A larger diameter = more high-demand, high-speed power, but less economy and more backfiring on deceleration, and needs a richer air-fuel mixture to keep from running too hot. I think a 2" pipe and a low-restriction muffler will give a Stovebolt its best "happy medium" in a light truck. 1951 3800 Be the change you want to see. -hotshoe
| | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | Same for me Lori. I like them there also! | | | | | Joined: Nov 2006 Posts: 213 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 213 | I have a 60 Apache 10 stepside and they exit out both sides in front of the rear tires. I like the sound,it's not real loud until you step on it. I don't know how other cars like it at a light though with fumes aiming towards their cars or windows. No complaints so far, but I don't drive it that much either. The truck has a 350ci mildly built and the exhaust was like that when I bought the truck,I just changed the chrome tips on them. Joe
54 Triumph TR2(rhd)needs total resto. 60 Apache 10 stepside shortbed 99 Excelsior Henderson | | | | | Joined: Apr 2005 Posts: 313 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 313 | Mine comes out on the left side behind the rear wheel. | | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | I ran mine to a 4 x 4 x 30 inch collector box behind the cab with two stainless 2 inch stacks and rain caps. Straight pipes sound great especially on a long hard pull ! | | | | | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | Right now, Number Seven has no pipe extending past the muffler.
At some point, I will be putting a little more on there, but that's not for a while yet. | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Mine exits thru the rear roll pan. It also creates a back draft that stains the tailgate. Have to clean it every week. Pain in the butt. | | | | | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | I have turn downs just ahead of the rear axle. | | | | | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | My GMC 248 has Fenton headers, 2 1/4" pipes through Corvair Turbo mufflers and 2 1/4" tailpipes all the way to rear bumper with chrome tips, both on the driver's side. I think it sounds good but kind of subdued until you give it full throttle, then it sounds off a little.
