1 members (tesa), 142 guests, and 2 robots.
Topics128,080
Posts1,055,953
Members48,430
#201216 02/16/2006 2:24 AM
Some one told me today that I shouldn't run unleaded fuel in my 53 truck because it will burn the valves. I was sure it was the other way around, that you shouldn't put leaded fuel in an unleaded engine.
Who's right???
1953 3/4-Ton Chevy
More pix
If it can be built ... It can be fixed.
RB53
#201217 02/16/2006 2:32 AM
I believe you are but I could be wrong
#201218 02/16/2006 2:37 AM
I have heard the same thing about my 61. My friend was telling me that since my truck was built in the days of leaded gas it had "soft" valve seats. He claimed that newer vehicles designed for unleaded fuels have "hard" valve seats. I am not sure if he is right or not but he was sure that he was. I run unleaded gas in my truck and have for years, no problems yet. I put fuel conditioner through it once in a while, but nothing serious, just cheap NAPA stuff. I do that about every oil change or so. I am not sure if it does anything but I feel better about it.
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton
My Machine
#201219 02/16/2006 2:39 AM
Leaded fuel, if you could find it, will plug the catalydic converter. Running unleaded fuel in an old engine could theoretically could burn a valve or seat because they used the lead as a lubricant. You would have to run along time with an overlean condition to do it though. I'm still running original engines in most of my trucks with no problems,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#201220 02/16/2006 2:40 AM
Heard the same things, was told the valve seats would burn out and should be replaced with newer type seats (not the valves)
#201221 02/16/2006 3:20 AM
Resto book I read said that the old seats are soft, but if it ran on leaded for any length of time, the lead is absorbed into the seat and provides lubrication for a long time. If you rebuild the head or use an NOS head with no milage, get the seats replaced with hardened ones.
#201222 02/16/2006 3:24 AM
Thanks Guys... I was not planning on doing any internal work on the engine.
Since this truck will likely be a weekend cruiser and not a daily driver I think I will take my chances. It has 83000 on the odo so it probably had a few gallons of leaded fuel in its day. not too worried then.
Rich
1953 3/4-Ton Chevy
More pix
RB53
#201223 02/16/2006 3:32 AM
I've been running my 1966 250 for over 11 years on unleaded, and it still runs fine.
#201224 02/16/2006 4:44 AM
If you have concerns about this, there's a product I use in my big block Vette called max lead 2000. It adds actual tetrethyl lead and boosts octane. For the occasional driver, you can add some every 3rd or 4th tankful.
http://www.maxlead2000.com/
You never have enough, til you have too many!
#201225 02/16/2006 5:20 AM
Former Workshop Owner
I wouldn't lose any sleep over it. I burn regular unleaded in my '59, not a problem yet.
Although, I would not burn Ethanol.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
#201226 02/16/2006 6:14 AM
I heard that most of the sixs were such low rev engines it wouldnt be a problem but V8s would be effected, but by the time they were they would be darn near ready for a rebuild anyways. If you hear no pings or knocks go for it!
I recently got a 53 with a 216 and spent about 40$ on gas this last weekend (I just got her road worthy and was a little excited!) running all over town and no pinging and Im not gonna change a thing. -Jeff
My 1953 Chevrolet
1947.1 Gallery
#201227 02/16/2006 6:28 AM
Before I got the 41 I ran my old Rover cars with inline six motors on unleaded gas for years without any problems. I think Jeff hit the nail on the head, these low revving motors driven normally shouldn't be a problem. Think of the muck they used to run on during WW2.Come rebuild time it would be sensible to put in hardened seats while its stripped down. Just my two bobs worth.
Cheers
Bob
#201228 02/16/2006 9:30 AM
I agree with Mozzie. smile
Cliff59
Deluxe \'52, Savoy \'54 Apache59
"She may not be the youngest girl at the ball, but she can still turn a head or two."
#201229 02/16/2006 3:31 PM
The big problem will be if you run your vehicle under extreme load a lot. Running the vehicle hard will have more of a tendancy to wear the seats. As a daily driver you would probably only loose 15% of your valve/seat life. Thats 15,000 miles out of 100,000 miles. Not worth getting excited about unless you are doing an overhaul already.
#201230 02/27/2006 4:35 AM
want to be safe? NAPA has a cheap "lead" subtitute about 1 oz for 5 gallon gas.
"It ain't a truck if you can't hose out the cab."
#201231 02/27/2006 5:41 AM
i met this elderly gent and while we were talkin trucks he was puting fuel in his newer 90's truck he took out a bottle of tranny fluid and put two capfuls in the tank,,,said it helped to keep things lubbed up,,,never tried it myself.
anybody else heard of this...this ol timer swore by it and said he never had to rebuild an engine .his cars and trucks fell apart first
#201232 02/27/2006 5:53 AM
But in this day in age, we're pulling down 2-300,000 mile on an engine with just maintenance like oil changes, nothing major. So how would you know?
Scott
Scott Ward
1 1950 3100
1 1955.1 Chevy 6500
1 1963 K20 (454)
1 1964 C10 (350)
#201233 02/27/2006 9:47 AM
If you have worries about valve seat damage from lack of lubrication with unleaded,add a couple of capfuls of Marvel Mystery Oil to the tank before every other fill up. As a sidenote,it seems to improve the octane of the gas by about a grade. I don't know how it does it,maybe it "fools" the engine into thinking the octane is higher,but it enabled me to run regular no-lead in my old Harley FLH,when it used to ping with anything less than 90 octane.
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
#201234 02/27/2006 10:44 AM
When did they invent leaded gas in the US?
Here in Germany there was no lead in gas till 1957.
So all the pre 1960 engines can handle it without any problem grin
I drove 216s, 235s since years with unleaded and had any kind a problems :rolleyes: but never a valve problem. We even do quatermile with that, never heard about no-lead related problems from my Hotrod friends and we do a lot of abuse.
Frank
#201235 02/28/2006 4:23 PM
I think it was around 1924.
I have a 1960 Apache with a 235 in it. Is it safe to run the 95 octane non ethanol gas in it?
Yes, until your wallet gets empty.
Since that is the closest to what it ran on in the 60's yep. only thing closer is leaded gas. smile
But if you want to help your wallet like Bill is thinking. Then not to worry about running it on standard gas at the pump.
Other than you will want to keep a eye on your fuel lines if they are original. With the ethanol at higher concentrations.
Is there an additive that can be ran with regular 87 to counteract the ethanol?
There is an app for your phone called "Pure Gas" that will list gas stations near you that sell non-ethanol gas. I was told by an old school mechanic (which fits the description for most of this group) that it is more important to have a zinc additive in your oil than it is to have a lead additive in your gas. If you have a rebuilt carburetor the ethanol is probably not an issue as long as you don't let gas sit in the truck for long periods of time, such as winter storage.
Dave from Northern Kentucky
My 54 3100
Think of it this way. If your only driving it on the weekends and not hundreds and hundreds of miles. Fill it up with non-ethanol gas. Less likely to foul the lines or carb. and your wallet will be fine the few times you fill her up.
If its your daily run it on 87. You wont have to worry about the carb it wont have any sitting gas and all you will need to inspect or just go ahead and replace is any old rubber gas lines with modern stock.
The short version anyway.
I've been driving my entire fleet on ethanol fuel since it was mandated in Atlanta in about 2007.
The only problem it ever caused me was ruining the diaphragm in the original fuel pump in my 1956 Cadillac. After an ethanol resistant pump was installed, I had no further issues.
Ethanol is crap but if you drive your truck regularly you won't have any problems with it. The 235 will be just fine on 87 octane corn juice.
I've put over 3000 miles on my 1950 216 running on ethanol.
1950 Chevrolet 3100 (Ol' Roy)
“… ethanol is probably not an issue so long as …”
Beware the qualifiers.
“ Ethanol is crap…”
Words to live by.
Corn is good for:
-Eating
-Popping and eating
-Feeding to cows, (later eating said cows)
-Making likker
-Fishing bait (perch)
Note that which is conspicuously absent from that list.
Moderator, Electrical Bay
Sta-Bil 360 has been working for me. I haven't had any problems since I started using it about 2.5 or 3 years ago. I bought it on Amazon (large bottle) and it has a handy measuring device on the bottle.
~ Jon
