4 members (Maybellene, klhansen, 2 invisible), 87 guests, and 3 robots.
Topics128,211
Posts1,057,468
Members48,471
#208716 05/31/2006 5:38 AM
I
I Offline
I'm posting this here for an opinon, more than a what brand, or how to do it thing. What color did you paint the inside of your truck cab. Did you stick with a more traditional one, or go with the outside color? I wanted to go with a lite gray, but our body shop guys recomended a color that remainds me of what a baby calf leaves behind. I relise the choice is mine. I just want to know what other guys are doing/not doing ,or would like to do. Any one have any good close up pictures of there insides?
Jeff
1947 Chevy 6400 2-ton
1953 3/4-ton
It was fun while it lasted
#208717 05/31/2006 12:05 PM
Its your truck isn't it? I went semigloss black, not a standout type color.
#208718 05/31/2006 1:19 PM
The same color as the rest of the truck and a semi gloss black on the top of the dash will always fit. What color is the rest of the truck? Does the calf $h!t green compliment the color of the exterior and interior? And most of all do you like it? If you have any doubts, don't do it unless you can afford to have it redone.
#208719 05/31/2006 3:20 PM
My 56 interior is tan/brown. I wasn't interested in original colors, only what I liked. Outside color is yet to be determind but probably a dark green some years ahead!
Link to pics is below....
Larry Bear
55.5 Chevy 3100 Panel
#208720 05/31/2006 3:54 PM
I used the stock '54 color in my '51, which is sort of beige. I think the original color was too dark and I didn't want the interior to match the exterior.
#208721 06/01/2006 2:41 AM
I like the light beige metallic paint that is just a shade or two brighter than the original. If I were you, with the money you got, I would just cover it in leather (LOL),
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#208722 06/01/2006 2:45 AM
leather? pff...astroturf!
I had it flat(er) black for the first fix up. But now its going to be exterior color. Do what you want though.
#208723 06/01/2006 3:51 AM
That made up my mind. Dash gloss black, and the rest body color. Colbalt blue................
Tomy
48 Chevy 3100 Shortbox 5 window
"The Big Dog"
#208724 06/01/2006 4:46 AM
I
I Offline
Well the shop wants to paint it, some beige calf poop color. The outside will be Viper red. My trouble with the color they think looks best, is the headliner, door panels, and some of the other things will black. I found a nice liter gray in my tractor paint supplier. It just a simple one step, that I want flatened. They wanted to paint the dash the same outside red. I think it should be the same as the inside color. The shop guys paint a lot of stuff with colors that work well together, I'm just not sure if there completely right on this one. The last thing i wanted is for it to look dorky. I've already had them paint the wheels, front bumper and running boards in this gray color. Does anyone think the gray would make the inside to dark? Most of the orginal paints were kind of on the dark side.
Oh, yes I completely hate anything to do with leather, so theres little chance it will be found inside this truck. If anything i would put in velvet, so I could then use a "dogs playing pool" floor mat.
Jeff
1953 3/4-ton
#208725 06/01/2006 5:17 AM
go with gray....Calf poop beige is no good...
All I can picture is Scours Yellow...yuck.
I am looking at a light gray Ferd tractor paint for the inside. A quart of that stuff is pretty cheap and should cover the panels nicely.
#208726 06/01/2006 5:39 AM
Here are the colors I had mine painted:
http://www.59apache.com/bigwheel.html
The truck's interior is painted in the original interior colors for 1959 - Comanche Gold Metallic and Charcoal Gray.
I like how they turned out! cool
Jim Karras
Orange, CA
'59 Chevy Apache 32 Stepside Pickup
E-mail: [email protected]
Internet: www.59apache.com
#208727 06/01/2006 6:49 AM
Light tan/beige hammer-tone finish. Good color, seems slightly metallic, and the hammered finish gives it some interesting texture and depth. I like it, and that's all that counts.
#208728 06/01/2006 2:56 PM
light gray (or gray) and red look very well together
gray is neutral and goes w/ everything
Jim & Caroline
#208729 06/01/2006 4:39 PM
I'm using some of that new
'hammertone' spray paint on the dash. It looks neat. When dry, it looks like thousands of little hammer-blows massaged the metal. Be careful not to spray on a lot at once. It tend to run if applied too thick.
I also found a spray can of the exact same dark flecked color the dash originally had.
#208730 06/01/2006 7:53 PM
I
I Offline
46,
That excatly the paint I picked out for the wheels. It was suppose to be a close match for the color an early ferd tractor was, before all thered bellys and them there blue color. Not to dark not to lite, just down the middle. Its going to come a little flater as it a one step piant. I just couldnt see painting any of the inside the same as the outside, and i for sure didnt want the dash to be shiny and glare back at me.
Jeff
1953 3/4-ton
#208731 06/01/2006 7:57 PM
I
I Offline
Jim K,
Thats the greastest looking dash I've seen in a while. I hope mine loooks that good when its done. What does the outside look like?
Jeff
1953 3/4-ton
#208732 06/01/2006 9:31 PM
Apache Kid-
What color and manufacturer was the spray can of the stuff that matches the original dash color?
#208733 06/02/2006 4:58 AM
Jeff,
Here is what the outside looks like now:
http://www.59apache.com/completed.html
I think your truck will look much better with a differnt color scheme for the interior than the outside. Also, I think the light gray is going to look awesome!
Jim Karras
Orange, CA
#208734 06/02/2006 8:25 AM
Quote
calf poop beige and OLD TRUCKS kind of go ..together grin
Cliff59
Deluxe \'52, Savoy \'54 Apache59
"She may not be the youngest girl at the ball, but she can still turn a head or two."
#208735 06/02/2006 1:12 PM
I
I Offline
Well the calf color might be fitting as this truck hauled cattle from MO to Ia for about 30 yrs. I dont think that color would grow on me though.
Jim, the outside of your truck is great. Is that a facory color for a 59.
Jeff
1953 3/4-ton
#208736 06/02/2006 8:07 PM
Cliff 59,
If you only knew how much calf poop I have shoveled in my life...the real thing, not BS!!
...anyone using the adjective "calf poop" and any color has a someone skewed view of a nice color for me!... grin grin
I myself will probably look at a brown hammered finish paint for my dash...but I won't call it calf poop! grin
#208737 06/02/2006 9:14 PM
My preference for interior is a medium to light shade of whatever color, two tones are nice. A totally DARK color doesn't show off the interior, with out some chrome or light accents, it's like you're peering into a mine shaft.
1946 1/2-Ton Chevy
#208738 06/03/2006 4:52 AM
Jeff,
Yes, it is. It's Tartan Turquoise with Bombay Ivory trim. I just can't imagine them painting a truck in such a vibriant color after so many years of Onyx Black, Swift Red or Hunter Green. I bet many of the old guys hated some of the bright colors of '55 - '59! grin
Jim Karras
Orange, CA
#208739 06/03/2006 6:53 PM
I
I Offline
Close to me sits a 54 3100, thats painted in a color very close to that Turquoise. The trucks beyound repair but parts of it look pretty in that color.
Jeff
1953 3/4-ton
