Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
6 members (MTD91, FAST55, frogfarmer, Jon G, cmayna, ndkid275), 121 guests, and 4 robots.
Topics128,288
Posts1,058,570
Members48,492
Page 31 of 177 1 2 … 29 30 31 32 33 … 176 177
Forgot to add that in goes with my gear shift knob which is a vintage glass door knob. I had to grind a little of the shifter, then ran a die down it to match the treads the door knob excepts, the door knob has a set screw to keep it tight. I can also change the knob if I want. I have white and chocolate brown porcelain knobs,other glass knobs and some brass knobs and the iron knob that I made a cast from for the starter button.
1937 Chevy 1/2-Ton
You are one wild and crazy guy!
~Jim
scraped some gunk off the timing gears frown
I love the starter button.
BigChevy4600 says " You are one wild and crazy guy!"
Guess what...Wasat is a girl!!!!
Debra, you make us Southern Stovebolters proud.... and for you guys who have not met Debra your missing out on meeting a talented lady. So much so I think her hubby must have had to build her a shop just for herself so he could reclaim his!! Way to go Debra.
...not to mention her skills with motorcyles restoration and photography!!
Got the Ididit column installed and put an ignition switch in the dash!! Will try to get the original high beam floor switch in today. A very good weekend!
My wiring kit came with a high-beam switch but my original seemed to be in good condition and also looked to be much sturdier, so I put it back in.
~Jim
Still fighting the battle with the brakes. Went to bleed the system and the bleeder sheared off, so I decided it was time for new front calipers. The problem is we don’t have a clue what they came out of. I discovered they looked identical to those on my ’79 donor truck (for the ’53 project). But when I went to bolt on the hose, no go, the bolts are different sizes. So now I’m replacing the hoses as well and since I’m replacing them I’ll replace the steel lines from the proportioning valve to the hoses as well. This way everything is brand new except the rotors which still look like new – they have new inner and outer bearings with less than a few hundred miles on them.
http://s783.photobucket.com/albums/...%20Pickup%20project/?albumview=slideshow
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
John, I knew a guy that noticed his radiator cap was loosing pressure and bought a new one only to find the radiator rusted at the top. He buys a new radiator and sees the hoses need replacing, he replaces the hoses and when installing the new radiator discovers the radiator support was rusted out. He gets a used support and discovers as he is removing the old support the insulation on the old wires running to his headlights and park lights were in very bad shape. This meant a new wiring system. It was not a pretty sight, a grown man crying... grin
~Jim
LOL. That sounds like the way my truck projects go.
Hey, got the new wiring harness for Big Orange today. I guess that does count. Spent the rest of the day unloading daughters moving van....oooooh my back!
Well, i started it after about 4 months and i have plans to drive it to work today. not a big deal but we have had unusually bad weather since November. i only work 4 hrs today and they are day time so i don't mind leaving it parked.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Painted my 261 oil pan, valve cover and pushrod cover plate with "Detroit Deisel-Alpine Green". Need to wire brush the block and head for the same... maybe after I put in the valve guides and assemble the head.
Valve Guides are ordered... I drew up plans for a guide installation tool and had a buddy make it for me. I'm confident it will work well.
Oh. I also won a set of NOS main bearings off Ebay for 14 bucks! A set of connecting rod bearings and a gasket set to go, and I'll be ready for an engine assembly process!
Just bought a "JOBMASTER 261" Valve Cover Decal from Jim Carters.
$2.78 and no shipping charges!
I ordered my Spal 7.5" twin Spal fans today. When we get them installed along with the 165 degree thermostat we'll crank her and see if the temp stays around 180 degree and if the power steering is functioning. Then we will be hanging the grill, splash pan, hood support, and hood. Getting close...
~Jim
Moderator
Happy Birthday Leo
Moderator
We got the panel running today, first time in over 4 years. Didn't run her too long, need to tweak a few things, fan blade is a few mm from the balancer, electrical system got finished, everything works. Need to adjust the hood just a bit. We bypassed the heater for now, need to do that next week but I feel good about having it running!
Way to go Leo. I can see you smile from here.
I did take the wiring harness from the living room to the shop today....hope that counts.
Oh, I did put a heater blower motor on a 50 Ferd today. OK....OK, it was for a dear OLD friend of mine smile
Gave up on Rochesters and bought a $35 YF core on ebay.
threw a kit in it last weekend and installed it on my 53 today (60 235). Darn thing started right up, no leaks, good throttle responce. I'll tune it tomorrow, but I couldnt be happier so far.
1953 Chevrolet 3100
striped the 38's chassis some more and got it ready for a coat of KBS looks good also banged my head on the wall trying to work out imperial bolt sizes always a little bigger than metric.
also trying to find some U bolts that are long enough for the mass of 14 leafs at the back need 8" long ones =/
Going to put the high beam dimmer switch back into the floor. Need to wire the switch from our new Ididit column.
Went to the junkyard and got the harmonic balancer to send in to be rebuilt.
I drove my burb 70 miles to a show and took first place in under construction class.
Nice one Cletis well done ,What did I get done today changed the inside colour from the faded original Too cardinal red Insulated
the back of the cab, coated the floors with rubber underseal then baked it hard, put tank and seat back plugs back in filled it with fluids and started First press of the starter , Sat purring away on my Drive for 30 mins No fluid leaks, all gauges workng perfect. Have a question while I am typing Does anyone know On the Vintage Air Ac/Heat if You buy the inside package you can later add Ac to it after if you wish too ?
1954 3600 With 1950's Powers of St Louis Utility Bed.
My truck
Last night I got the nova rear end bolted in the 38. A perfect fit! Now for spring bushings. think I'll try to find some urethane bushings instead of the old steel ones.
1937 Chevy 1/2 ton panel
Ryan:
My Crate engine came with the air compressor and I have added the condenser in front of the radiator.
I will be looking to do the same as you, a part at a time.
~Jim
Took "ole blue" to a show Saturday. The ole boy showed he can still kick his heels after all these years with a first place trophy..... and yes, I had to smoke the tires once or twice!!
1 Offline
I FINALLY broke down and bought a real nice under bed fuel tank, with a new GM in tank pump, sending unit, everything !! "three years after the build"
I took out the bed wood and started fabrication !!! Whooo Hooo !!
Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs.
1951 3100 350 TBI Gallery Toddzilla... "$old"
Thanks Big Chevy Yeah I kinda want too go piece at a time, And possibly use some parts I allready have as well.
My truck
Moderator
Happy Birthday Leo
Moderator
Found the oil filter gasket on the bench after oil leaked out of the canister when we started her up.
Changed the oil in the rear-end of my 59 apache. Finally warming up here in the midwest.
1956 Chevy 3100 Stepside Shortbox
More pix on Photobucket
Decided to shake the winter off the 38 - took a good cruise on a nice day with no problems. Sure do need some 3.55 gears tho! Need to start savin' up.
WELL, it's about time Todd!!! lol
~Jim
24601
24601
Just got in from a 20 mile, end-of-the-weekend cruise in the 9500. Just to drive it and listen to that 2-cycle Detroit sing to me a little. Ahhhhhhhhhhhhhh.
smile
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Hey Alvin, instead of just kicking up her heels let out for a run to KC.
2017 Buick Encore
See more pix
I didn't get as much done as I hoped,spent 3 hours in Accident and Emergency getting my right hand stitched up.
I was cutting back a bracket on my chassis and got a kick back from the grinder.
A 1mm thick cutting disc,12000rpm and skin,not a good combination..... nono
smile
What? NO video?
More pix on Flickr.
Dang Jock, that's no way to end a weekend.
How's that National Health Service these days?
~Jim
I broke two of my new exhaust valve guides over the weekend trying to install them. I finally got the hang of hammering them in, and all the other guides were installed successfully. My arm was like soft rubber afterwards though!
3 more guides are now on the way from "Rock Auto" (one extra for just in case)!
I also snagged an ignition switch on Ebay for $13 and just now bought a set of connecting rod bearings on Ebay for $30.
My Ebay purchased main bearing set arrived over the weekend and the "Jobmaster" decal from "Carter's" should be arriving soon.
I still need a gasket set, starter bendix, throw-out bearing and some paint.
I'm getting closer to finishing that power plant and getting more excited.
Oh... I thought this was kinda funny and worth sharing.
The connecting Rod Bearing Set I just bought on Ebay was originally $34.95 or Make Offer with $14.95 shipping.
I offered $25. (around $40 total with the shipping).
The seller countered with $30... and $10 shipping.
headscratch
OK buddy, if you insist... shake
And they vote. Now that's scary.
~Jim
Actually it's not too bad BIG,I just keep payin' my National Insurance.
One downside is,i'm down to one typing finger at the moment instead of the usually impressive two!
This reply took about 5 mins to type!
Thankfully I'm left handed so i'm not totally out of commission. grin
More pix on Flickr.
I can emphasize with you buddy. Politically speaking, "I can feel your pain". I can't go a week without busting, or cutting, or breaking or burning some part of me.
I should live near a hospital.
~Jim
