4 members (51sub, Jon G, 2 invisible),
121
Mod | | | Forums66 Topics128,288 Posts1,058,571 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 190 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2006 Posts: 190 | Forgot to add that in goes with my gear shift knob which is a vintage glass door knob. I had to grind a little of the shifter, then ran a die down it to match the treads the door knob excepts, the door knob has a set screw to keep it tight. I can also change the knob if I want. I have white and chocolate brown porcelain knobs,other glass knobs and some brass knobs and the iron knob that I made a cast from for the starter button. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Forgot to add that in goes with my gear shift knob which is a vintage glass door knob. I had to grind a little of the shifter, then ran a die down it to match the treads the door knob excepts, the door knob has a set screw to keep it tight. I can also change the knob if I want. I have white and chocolate brown porcelain knobs,other glass knobs and some brass knobs and the iron knob that I made a cast from for the starter button. You are one wild and crazy guy!
~Jim
| | | | | Joined: Sep 2008 Posts: 84 New Guy | | New Guy Joined: Sep 2008 Posts: 84 | scraped some gunk off the timing gears  | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I love the starter button. | | | | | Joined: Dec 2001 Posts: 14,526 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,526 | BigChevy4600 says " You are one wild and crazy guy!" Guess what...Wasat is a girl!!!!
Debra, you make us Southern Stovebolters proud.... and for you guys who have not met Debra your missing out on meeting a talented lady. So much so I think her hubby must have had to build her a shop just for herself so he could reclaim his!! Way to go Debra.
...not to mention her skills with motorcyles restoration and photography!!
| | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | Got the Ididit column installed and put an ignition switch in the dash!! Will try to get the original high beam floor switch in today. A very good weekend! | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | My wiring kit came with a high-beam switch but my original seemed to be in good condition and also looked to be much sturdier, so I put it back in.
~Jim
| | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | Still fighting the battle with the brakes. Went to bleed the system and the bleeder sheared off, so I decided it was time for new front calipers. The problem is we don’t have a clue what they came out of. I discovered they looked identical to those on my ’79 donor truck (for the ’53 project). But when I went to bolt on the hose, no go, the bolts are different sizes. So now I’m replacing the hoses as well and since I’m replacing them I’ll replace the steel lines from the proportioning valve to the hoses as well. This way everything is brand new except the rotors which still look like new – they have new inner and outer bearings with less than a few hundred miles on them. John http://s783.photobucket.com/albums/...%20Pickup%20project/?albumview=slideshow
My Fleet: 19411953195919651966 1953 Willy's Pickup John Vegetarian- old Indian word for bad hunter
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | John, I knew a guy that noticed his radiator cap was loosing pressure and bought a new one only to find the radiator rusted at the top. He buys a new radiator and sees the hoses need replacing, he replaces the hoses and when installing the new radiator discovers the radiator support was rusted out. He gets a used support and discovers as he is removing the old support the insulation on the old wires running to his headlights and park lights were in very bad shape. This meant a new wiring system. It was not a pretty sight, a grown man crying...
~Jim
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | John, I knew a guy that noticed his radiator cap was loosing pressure and bought a new one only to find the radiator rusted at the top. He buys a new radiator and sees the hoses need replacing, he replaces the hoses and when installing the new radiator discovers the radiator support was rusted out. He gets a used support and discovers as he is removing the old support the insulation on the old wires running to his headlights and park lights were in very bad shape. This meant a new wiring system. It was not a pretty sight, a grown man crying...  LOL. That sounds like the way my truck projects go. | | | | | Joined: Dec 2001 Posts: 14,526 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,526 | Hey, got the new wiring harness for Big Orange today. I guess that does count. Spent the rest of the day unloading daughters moving van....oooooh my back! | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | Well, i started it after about 4 months and i have plans to drive it to work today. not a big deal but we have had unusually bad weather since November. i only work 4 hrs today and they are day time so i don't mind leaving it parked.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Sep 2010 Posts: 695 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 695 | Painted my 261 oil pan, valve cover and pushrod cover plate with "Detroit Deisel-Alpine Green". Need to wire brush the block and head for the same... maybe after I put in the valve guides and assemble the head. Valve Guides are ordered... I drew up plans for a guide installation tool and had a buddy make it for me. I'm confident it will work well. Oh. I also won a set of NOS main bearings off Ebay for 14 bucks! A set of connecting rod bearings and a gasket set to go, and I'll be ready for an engine assembly process! Just bought a "JOBMASTER 261" Valve Cover Decal from Jim Carters. $2.78 and no shipping charges!
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I ordered my Spal 7.5" twin Spal fans today. When we get them installed along with the 165 degree thermostat we'll crank her and see if the temp stays around 180 degree and if the power steering is functioning. Then we will be hanging the grill, splash pan, hood support, and hood. Getting close...
~Jim
| | | | | Joined: Mar 2007 Posts: 4,217 Moderator | | Moderator Joined: Mar 2007 Posts: 4,217 | We got the panel running today, first time in over 4 years. Didn't run her too long, need to tweak a few things, fan blade is a few mm from the balancer, electrical system got finished, everything works. Need to adjust the hood just a bit. We bypassed the heater for now, need to do that next week but I feel good about having it running! | | | | | Joined: Dec 2001 Posts: 14,526 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,526 | Way to go Leo. I can see you smile from here. I did take the wiring harness from the living room to the shop today....hope that counts. Oh, I did put a heater blower motor on a 50 Ferd today. OK....OK, it was for a dear OLD friend of mine  | | | | | Joined: Mar 2005 Posts: 94 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 94 | Gave up on Rochesters and bought a $35 YF core on ebay. threw a kit in it last weekend and installed it on my 53 today (60 235). Darn thing started right up, no leaks, good throttle responce. I'll tune it tomorrow, but I couldnt be happier so far.
1953 Chevrolet 3100
| | | | | Joined: Feb 2011 Posts: 23 New Guy | | New Guy Joined: Feb 2011 Posts: 23 | striped the 38's chassis some more and got it ready for a coat of KBS looks good also banged my head on the wall trying to work out imperial bolt sizes always a little bigger than metric.
also trying to find some U bolts that are long enough for the mass of 14 leafs at the back need 8" long ones =/ | | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | Going to put the high beam dimmer switch back into the floor. Need to wire the switch from our new Ididit column. | | | | | Joined: Feb 2003 Posts: 1,391 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,391 | Went to the junkyard and got the harmonic balancer to send in to be rebuilt. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I drove my burb 70 miles to a show and took first place in under construction class. | | | | | Joined: Jan 2011 Posts: 90 New Guy | | New Guy Joined: Jan 2011 Posts: 90 | Nice one Cletis well done ,What did I get done today changed the inside colour from the faded original Too cardinal red Insulated the back of the cab, coated the floors with rubber underseal then baked it hard, put tank and seat back plugs back in filled it with fluids and started First press of the starter , Sat purring away on my Drive for 30 mins No fluid leaks, all gauges workng perfect. Have a question while I am typing Does anyone know On the Vintage Air Ac/Heat if You buy the inside package you can later add Ac to it after if you wish too ?
1954 3600 With 1950's Powers of St Louis Utility Bed. My truck | | | | | Joined: Feb 2010 Posts: 323 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 323 | Last night I got the nova rear end bolted in the 38. A perfect fit! Now for spring bushings. think I'll try to find some urethane bushings instead of the old steel ones.
1937 Chevy 1/2 ton panel 1953 GMC 2 ton. future car hauler
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Does anyone know On the Vintage Air Ac/Heat if You buy the inside package you can later add Ac to it after if you wish too ? Ryan: My Crate engine came with the air compressor and I have added the condenser in front of the radiator. I will be looking to do the same as you, a part at a time.
~Jim
| | | | | Joined: Dec 2001 Posts: 14,526 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,526 | Took "ole blue" to a show Saturday. The ole boy showed he can still kick his heels after all these years with a first place trophy..... and yes, I had to smoke the tires once or twice!! | | | | | Joined: Nov 2006 Posts: 677 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 677 | I FINALLY broke down and bought a real nice under bed fuel tank, with a new GM in tank pump, sending unit, everything !! "three years after the build" I took out the bed wood and started fabrication !!! Whooo Hooo !!
Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs. 1951 3100 350 TBI Gallery Toddzilla... "$old" | | | | | Joined: Jan 2011 Posts: 90 New Guy | | New Guy Joined: Jan 2011 Posts: 90 | Thanks Big Chevy Yeah I kinda want too go piece at a time, And possibly use some parts I allready have as well.
1954 3600 With 1950's Powers of St Louis Utility Bed. My truck | | | | | Joined: Mar 2007 Posts: 4,217 Moderator | | Moderator Joined: Mar 2007 Posts: 4,217 | Found the oil filter gasket on the bench after oil leaked out of the canister when we started her up. | | | | | Joined: Apr 2009 Posts: 350 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 350 | Changed the oil in the rear-end of my 59 apache. Finally warming up here in the midwest. | | | | | Joined: Aug 2010 Posts: 255 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 255 | Decided to shake the winter off the 38 - took a good cruise on a nice day with no problems. Sure do need some 3.55 gears tho! Need to start savin' up. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I FINALLY broke down and bought a real nice under bed fuel tank, with a new GM in tank pump, sending unit, everything !! "three years after the build" I took out the bed wood and started fabrication !!! Whooo Hooo !! WELL, it's about time Todd!!! lol
~Jim
| | | | | Joined: Nov 1995 Posts: 5,762 24601 | | 24601 Joined: Nov 1995 Posts: 5,762 | Just got in from a 20 mile, end-of-the-weekend cruise in the 9500. Just to drive it and listen to that 2-cycle Detroit sing to me a little. Ahhhhhhhhhhhhhh.  John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | Hey Alvin, instead of just kicking up her heels let out for a run to KC.
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | I didn't get as much done as I hoped,spent 3 hours in Accident and Emergency getting my right hand stitched up. I was cutting back a bracket on my chassis and got a kick back from the grinder. A 1mm thick cutting disc,12000rpm and skin,not a good combination.....  Just got in from a 20 mile, end-of-the-weekend cruise in the 9500. Just to drive it and listen to that 2-cycle Detroit sing to me a little. Ahhhhhhhhhhhhhh.  John What? NO video? 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I didn't get as much done as I hoped,spent 3 hours in Accident and Emergency getting my right hand stitched up. I was cutting back a bracket on my chassis and got a kick back from the grinder. A 1mm thick cutting disc,12000rpm and skin,not a good combination.....  Dang Jock, that's no way to end a weekend. How's that National Health Service these days?
~Jim
| | | | | Joined: Sep 2010 Posts: 695 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 695 | I broke two of my new exhaust valve guides over the weekend trying to install them. I finally got the hang of hammering them in, and all the other guides were installed successfully. My arm was like soft rubber afterwards though! 3 more guides are now on the way from "Rock Auto" (one extra for just in case)! I also snagged an ignition switch on Ebay for $13 and just now bought a set of connecting rod bearings on Ebay for $30. My Ebay purchased main bearing set arrived over the weekend and the "Jobmaster" decal from "Carter's" should be arriving soon. I still need a gasket set, starter bendix, throw-out bearing and some paint. I'm getting closer to finishing that power plant and getting more excited. | | | | | Joined: Sep 2010 Posts: 695 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 695 | Oh... I thought this was kinda funny and worth sharing. The connecting Rod Bearing Set I just bought on Ebay was originally $34.95 or Make Offer with $14.95 shipping. I offered $25. (around $40 total with the shipping). The seller countered with $30... and $10 shipping.  OK buddy, if you insist...  | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | And they vote. Now that's scary.
~Jim
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | I didn't get as much done as I hoped,spent 3 hours in Accident and Emergency getting my right hand stitched up. I was cutting back a bracket on my chassis and got a kick back from the grinder. A 1mm thick cutting disc,12000rpm and skin,not a good combination.....  Dang Jock, that's no way to end a weekend. How's that National Health Service these days? Actually it's not too bad BIG,I just keep payin' my National Insurance. One downside is,i'm down to one typing finger at the moment instead of the usually impressive two! This reply took about 5 mins to type! Thankfully I'm left handed so i'm not totally out of commission.  1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I can emphasize with you buddy. Politically speaking, "I can feel your pain". I can't go a week without busting, or cutting, or breaking or burning some part of me. I should live near a hospital.
~Jim
