| | | Forums66 Topics128,122 Posts1,056,331 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2014 Posts: 4,501 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,501 | I discovered that a rear transmission mount caused noise to telegraph up through the frame and into the cab. Once I removed it (I should add it was a rubber mount) the noise almost went away. In neutral I'll still hear some noise, but I don't believe the transmission has been rebuilt.
I was taught (long ago) to add 1 degree down to the pinion angle for spring wrap. If you have 4 or 500 horsepower or if you are hauling very heavy loads, you may need 2 degrees, but if you have a 235 you won't.
Entire Thread
Issues with T5 swap- vibrations, etc...
| Norcal Dave | 04/07/2023 2:35 PM |
Re: Issues with T5 swap- vibrations, etc...
| EchoBravoSierra | 04/07/2023 2:53 PM |
| Norcal Dave | 04/07/2023 3:08 PM |
| Lugnutz | 04/07/2023 4:02 PM |
| BC59 | 04/07/2023 7:37 PM |
| Norcal Dave | 04/07/2023 10:21 PM |
| Jon G | 04/08/2023 12:37 AM |
| Norcal Dave | 04/08/2023 12:45 AM |
| BC59 | 04/08/2023 2:09 AM |
| Norcal Dave | 04/08/2023 4:32 AM |
| Joe H | 04/08/2023 1:10 PM |
| Lugnutz | 04/08/2023 1:45 PM |
| Jon G | 04/08/2023 2:53 PM |
| BC59 | 04/08/2023 3:29 PM |
| NorthCoast3800 | 04/08/2023 3:42 PM |
| Jon G | 04/08/2023 5:11 PM |
| 52Carl | 04/08/2023 9:14 PM |
| Norcal Dave | 04/09/2023 1:17 AM |
| EdPruss | 04/09/2023 3:42 AM |
| Lugnutz | 04/09/2023 3:49 AM |
| EdPruss | 04/09/2023 11:54 AM |
| DaveV | 04/09/2023 12:32 PM |
| Norcal Dave | 04/09/2023 1:41 PM |
| Lugnutz | 04/09/2023 2:34 PM |
| BC59 | 04/09/2023 7:42 PM |
| Norcal Dave | 04/09/2023 9:11 PM |
| Jon G | 04/09/2023 9:24 PM |
| Norcal Dave | 04/11/2023 4:22 AM |
| Joe H | 04/10/2023 12:25 AM |
| Norcal Dave | 04/11/2023 4:23 AM |
| Norcal Dave | 05/02/2023 4:59 AM |
| Joe H | 05/02/2023 12:43 PM |
| NorthCoast3800 | 05/02/2023 10:44 PM |
| Norcal Dave | 05/02/2023 11:57 PM |
| NorthCoast3800 | 05/03/2023 5:58 PM |
| klhansen | 05/03/2023 8:03 PM |
| Lugnutz | 05/03/2023 6:39 PM |
| Norcal Dave | 05/04/2023 4:56 AM |
| NorthCoast3800 | 05/04/2023 7:54 PM |
| EdPruss | 05/04/2023 10:43 AM |
| Norcal Dave | 05/05/2023 3:10 AM |
| Norcal Dave | 05/06/2023 6:23 PM |
| Norcal Dave | 05/21/2023 11:41 AM |
| WICruiser | 05/21/2023 11:47 AM |
| NorthCoast3800 | 05/21/2023 4:29 PM | |
