There is a bit of confusion here, the carburetor is not a YF 684s. 684s was a W-1.
Jon.
Good carburetion is fuelish hot air The most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes! The Carburetor Shop
