Here are pages from the 47-55 Factory Assembly Manual. Hope this helps a little. I scanned them in using normal resolution. I can go higher for better detail if needed.
"Adding CFM to a truck will only help at engine speeds you don't want to use." "I found there was nothing to gain beyond 400 CFM."
