0 members (),
116
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#25299 05/13/2005 3:04 PM | Joined: Apr 2005 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 72 | I have a rear end swap question that I hope someone can answer or know where the info might be. I am knew to vehicle restoration and I just bought my dream truck (aka rust bucket basket case) a couple of months ago. I have a 53 chevy with the closed drive and I want to swap out the rear end. I picked up a kit off of one of the memebers of this site that will seal the rear of my 4 speed trans for an open drive line. I measured from the inside of backing plate to backing plate and it is approximately 56 inches. Does anyone know what vehicles (i.e. nova, camero...) and what years of vehicles would have those dimensions for rear ends? Or someone may know where I can research to find this info.
Thank you all for helping a newbie. Dan
If you didn’t skin a knuckle while you were working on your truck, you weren’t working hard enough! 53 5window 1/2 ton54 3window 1/2 ton
#25301 05/13/2005 6:35 PM | Joined: Apr 2005 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 72 | Thank you Houston 54. That was the type of information I was looking for. It appeared that measurements are taken from wheel mounting plate to plate or from the backing plate to backing plate. I think I have a lot of work ahead of me trying to find a good match.
#25302 05/13/2005 8:47 PM | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | i have a 79 nova and it fits nicely 60 1/2" over all (wheel mounting surface). the only draw back is the gear ratio 2.73 it works for me since i have upgraded the engine, dual carbs, dual exhaust and pertonix ing.. also i live on flatland. to change the ring and pinion is expensive, parts 200.00 labor about the same. RON
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
#25303 05/13/2005 9:00 PM | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Dan,
Check with Joker on this site, I think he put an 84 full size Blazer rear under his AD... | | |
#25304 05/13/2005 9:06 PM | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | I put a 1965 1/2 ton 12 bolt rear under mine. Fit great. It measured 61-1/2" wheel to wheel. I'ts got a 3.73 gear and 6 bolt pattern. I wanted the 6 bolt cause the rims I had were in good shape. There are some pics on My Site Good luck | | |
#25305 05/13/2005 9:57 PM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Bullnosebob: It kind of sounds like you guys might be finished talking so I thought it might be OK to jumb in here. I hope it's OK! I noticed, Bob, on one of the pictures of your truck your shock mount. Can I get a better look at that. It may be the stock set up for your truck, but it might also work for my 37. I hate to put you through the trouble, but if you have a picture of that, I would sure appreciate it!! Also, what kind of shocks are you running? Thanks, Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
#25306 05/13/2005 10:24 PM | Joined: Jul 2006 Posts: 232 New Guy | | New Guy Joined: Jul 2006 Posts: 232 | If you dont mind a furd rear end look for an early 70's COugar 9" I put one in mine, 60 1/2" wheel mout to wheel mount. Worked out well. | | |
#25307 05/13/2005 11:47 PM | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | I have a 70 camaro 10 bolt in our 53. Fits just fine with 15x8 inch wheels | | |
#25308 05/14/2005 12:00 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I've got a '73 Chevelle wagon rear under my '55 1st. Fits like it was made for it. Or at least it did after cutting off the coil spring and control arm stuff and welding on spring pads.
I've got a GMC 270 with an SM420 4-speed. With 3.08 gears I can easily run 70+ and it is plenty quick leaving stop lights. However it won't do smokey burn-outs, and if you put a loaded trailer behind it you might wish for deeper gears.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#25309 05/16/2005 2:24 PM | Joined: Apr 2005 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 72 |  You guys are provinding great information. It is nice to have a few options when I go looking for a rear end. When your looking for one specific item and a specific year it makes it difficult. Any one with any other options please let me know. Thanks agian guys, as always you all show why this is the greatest site on the web.
#25310 05/16/2005 3:29 PM | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | air ride technologies offers a kit to put a lincoln mark viii rear end in this truck. it has a 4 link set up and disc brakes. RON
#25311 05/18/2005 9:18 AM | Joined: Dec 2003 Posts: 74 New Guy | | New Guy Joined: Dec 2003 Posts: 74 | Here's more pages with some measurements: http://www.carnut.com/specs/rear.html http://www.novaresource.org/axle.htm I spent the afternoon putting a 10 bolt out of a 1979 Nova on my '52 today, although I didn't get it completely finished. The rear end measures 60.25" from wheel mounting surface to wheel mounting surface AND (big drum roll) the spring perches appear to be in the right places! This is with the stock springs swapped end to end to put the locating pins in the right place. This is a five lug rear, though, so if you're looking to keep all your wheel bolt patterns the same this rear wouldn't be a good choice. While I have it bolted in right now I haven't put the bed back on to see how everthing looks and I haven't figured out what to do for lower shock mounts. Is there any way to make a "sticky" post on converting your truck to an open rear? It seems to be a really common question and I think we all could put together a lot of good information. | | |
#25312 05/18/2005 5:06 PM | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | A rear axle from a Task Force series will fit and it has a 3.70 ratio. They are somewhat older than what has been posted so far. They have the 6 lug axles. | | |
#25313 05/18/2005 5:45 PM | Joined: Apr 2005 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 72 | Keahi,
I found a 1977 Nova rear end today and I may pick it up. Thanks for your info.
#25314 05/18/2005 5:51 PM | Joined: Apr 2005 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 72 | Oldblu49, and Keahi,
You are the first to provide info on an older rear end that has a gear reatio and the 6 lug patern.
I have looked at all the pictures I have seen on the internet of AD trucks and it seems the hot rod trucks are almost all 5 bolt and the restored trucks are 6 bolt lugs.
My initial thought is to stick to 6 bolt. I don't know enough yet or have not researched on the available 5 or 6 bolt after market wheels.
I also don't know how hard it would be to find a Task Force series rear end for reasonable $.
Oldblu49, is the Task Force rear end the same width as the AD trucks?
#25315 05/18/2005 5:53 PM | Joined: Apr 2005 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 72 | Everyone,
Thanks for all the great info and reference sites, you are helping me make a better informed decision on what I am looking for and what I may want.
I am getting a good education on rear ends, vehicle rear ends that is.
Good info for a newbie.
#25316 05/18/2005 6:09 PM | Joined: Mar 2000 Posts: 73 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2000 Posts: 73 | Here is one more option. In my 46 1/2 ton I swapped out the center pumpkin for one from an open driveline 56 1/2 ton. I then welded in new solid type spring perches. It worked good for me because I kept my old housing and the e-brake stayed. I also kept 6 lug all around. The pumpkin has 3:38 gears. I'm running a 283 with a TH350 and it has held up fine so far. | | |
#25317 05/18/2005 8:20 PM | Joined: Dec 2003 Posts: 74 New Guy | | New Guy Joined: Dec 2003 Posts: 74 | If you do decide to go with the 1977 Nova rear look for one out of a Nova with a 350 and a 4 speed - according to one of those websites above that was the only combo that year that had 3.08 gears. Everything else was 2.56 or 2.73.
The 350/4speed cars also had a 8.5" ring gear which is much stronger than the 7.5" (and almost on par with the 12 bolt rear ends). | | |
#25318 05/18/2005 9:28 PM | Joined: Apr 2005 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 72 | Keahi,
I also read the same info and I do want the 8.5 ring gear.
Rick,
Did you swap out the pumpkin or did you have it done? If you had it done, how much did it cost?
I am not sure it is a job for me. I have never worked on a rear end before and I would be better off paying someone to do the job.
Thanks again for new info and options.
Dan
#25319 05/18/2005 11:33 PM | Joined: Mar 2000 Posts: 73 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2000 Posts: 73 | Swapping out the pumpkin is not diffacult. It's a bolt in job. The hard part is welding the new spring perches and that's not too hard. There is no "setting up" the gears. They are set in the pumpkin assembly. | | |
#25320 05/19/2005 12:15 AM | Joined: Apr 2005 Posts: 16 Junior Member | | Junior Member Joined: Apr 2005 Posts: 16 | Rick, I have the same setup you mentioned above on my `54 1/2 ton. Except I was under the impression that the only gear choices were 4:11 (which mine is ) or 3:90 if your lucky! Where did you find a 3:38 third member? Was your donor truck an automatic? Are the `60 thru`64 trucks, "drop out" third members? Finding a "tall" 3rd member like that would solve a lot of problems for me! JD
unless your the lead dog, the view never changes!
#25321 05/19/2005 3:27 AM | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | iv got a caddy rear with disc brakes and monoleafs and lowering kit from obsolet chevy havent got the box on yet but it looks cool | | |
#25322 05/19/2005 1:40 PM | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | I also don't know how hard it would be to find a Task Force series rear end for reasonable $.
Regarding this question....I recently picked up a complete 55 1/2 ton rear in good condition for $100, so they are out there. Also...I think any 55 thru 69 1/2 ton rear will work as far as width goes and will still have the 6 lug pattern. | | |
#25323 05/19/2005 2:44 PM | Joined: Apr 2005 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 72 | So much good information! Imput overload, which way do I go? Cost...availabilty...easiest to swap out...least modifications...? At some point I will have to make a decision/commitment and just go for it.
In talking to some local junk yard dogs, if they don't have what your looking for they get on their yard web site and go looking for other yard dogs who may, but they can't seem to get a good answer on gearing. And you are relying on the guy on the other end to provide accurate info. I don't want to buy something and find out I now have to go through the work of getting the gearing changed! Any suggestion to this problem.
Does anyone have good measurements for truck rear ends for the 55-69 years?
#25324 05/19/2005 5:20 PM | | Anonymous Unregistered | | Anonymous Unregistered | JD 54, The 3.38 ratio was an option in '58-'59(maybe just '59) 1/2 ton trucks. The ring and pinion are being reproduced and are available from Patricks and several other vendors. There was also a 3.70 ratio option. | | |
#25325 05/20/2005 4:57 AM | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | 53fivewindow. I don't think there is any great difference in the width of the TF axle over yours. I just put mine in storage for a bit and cannot get to it easily so I can't measure it. As was mentioned above, probably the best way to do it is to swap the center section from one to the other. On the TF axle the spring pads are on top which would have to be changed. Swapping the center section everything else like the e-brake (as was stated) can stay but you have to weld up the hinge pins on the spring mount as you do not want the axle rotating on the spring like it does with the torque tube. The new rear u-joint will take care of that. If you did go to a 5 lug axle then you would have to change the front hubs mainly for appearance sake. you would also need to carry two spare tires. I like my 6 lug wheels. | | |
#25326 05/20/2005 2:11 PM | Joined: Apr 2005 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 72 | Oldblu49,
Thanks for the info. I think I will try to hunt down a TF center pumpkin. I think the treasure hunt is part of the fun in rebuilding this truck.
Once again, all you truck guys are the greatest.
Dan
#25327 05/20/2005 8:12 PM | Joined: Jan 2004 Posts: 223 'Bolter | | 'Bolter Joined: Jan 2004 Posts: 223 | On the Task force rear axles, I believe the stock higher gear ratios where for trucks with automatic trannys. Hence their rarity. I have looked for one for years (not looking hard.) In my experience, almost everyone you will find will be a 3.90 gear ratio. They are out there at swap meets and yards. In the northwest I see them in for a low of $75.00 to a high of $200.00. The question I have is that everyone always talks about the axles under the TF trucks as only being used for the 55-59 TF trucks. Is this true? Or did GM use these same axles into later years? Steve O | | |
#25328 05/20/2005 9:27 PM | Joined: Apr 2005 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 72 | Nifty 50,
I will look for one for a while, but I have a 77 Nova 10 bolt 8.5 rear end lined up if I can't get the pumpkin. Either way I have lot of work and learning ahead of me. I look forward to the challenge.
If anyone knows Nifty 50's questions about years fot TF rear pumpkins I would like to know as well.
Thanks again for filling my knowledge cup a little more.
#25329 05/21/2005 3:59 PM | | Anonymous Unregistered | | Anonymous Unregistered | I think the TF dropout center section type rear axle was used through 1962. After that they went to a Dana/Spicer axle which does not have the dropout center section. The 4wd trucks started using the Dana/Spicer axles starting with the 1960 models. | | |
#25330 09/01/2005 5:08 AM | Joined: Aug 2004 Posts: 90 Member | | Member Joined: Aug 2004 Posts: 90 | I just picked up my 1977 6 lug 12 bolt rebuilt and 3.40 gearing. we cut the spring perches off and hope to find new ones. We have not mounted it to the 51 3100 but will soon I guess we could make them but maybe someone knows who has them made?? thanks guys hey JD there is a great rear end guy in rancho cordova. prentice enterprises. gooday jim
Gooday Jim
small wheel moves by fire and rod, big wheel fires by the grace of god, everytime that wheel turns round, bound to cover just a little more ground.
#25331 09/01/2005 7:17 AM | Joined: Apr 2005 Posts: 16 Junior Member | | Junior Member Joined: Apr 2005 Posts: 16 | Jim, I got my spring perches,and U bolts from from Buffalo Enterprises in Washington. Give them a call (360) 652-7684 They`re pretty knowledgable about our old trucks. I think all they do is `50s stuff. JD
#25332 09/01/2005 2:34 PM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | Seems like I saw something somewhere that pumpkins off of trucks from 36 to 72 were interchangable without too much modification.
I think that there was a warning to only use pumpkins off of the same sized truck, though.
I can't remember where I saw it. If I remember, I'll post the link. | | |
#25333 09/01/2005 7:29 PM | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | I know zilch about 1/2-ton trucks. The 3/4 and 1-ton models are fairly interchangable '47-'72 (some models don't work, but a lot use the Eaton H0xx axle). | | |
#25334 09/02/2005 2:51 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Most farm and fleet stores have perches in their "trailer parts" section. Scott | | |
