1 members (baldeagle), 158 guests, and 2 robots.
Topics128,110
Posts1,056,241
Members48,437
#228008 03/14/2007 2:02 AM
I am lusting after a '39 to '46 1/2 truck. Worked on a '51 today for a friend and the shop talk got around to the passenger compartment size on these years of trucks. My buddy says they are small inside and I would be a tight fit. Well Ok, I'm 6'1" and need a diet bad at a tad less than 300 big ones. It's the beer with all that shop talk. So am I to big to fit into my want-to-be-mine truck? Thanks
#228009 03/14/2007 2:08 AM
Just like a pair of pants....I say find one and try it on for size.... grin
I am betting you will fit. While there is not a whole bunch of adjustment, the stock seat does adjust some.
If you found one without the tank under the seat, there is probably even more room or you could change the seat out so every thing that belongs in the cab would fit.
#228010 03/14/2007 2:58 AM
http://www.brads41-46chevys.com/id17.html This link gives you the spects on the 41-46 cabs. I think the 39 40 had 1" or so less leg room. They are smaller then the 51 cabs.
#228011 03/14/2007 3:04 AM
Same heigth but about half a hundred less. The very best thing I did on my 41 was a small diameter tilt column from a 71 chevy van and mounted as close to the dash as allowed. Just 2" is huge when sliding under the wheel. Could have gained more with an aftermarket smaller wheel.
Evan
#228012 03/14/2007 3:06 AM
I do know that I don't have enough room in my 46, but I have Jeep seats in mine, and they sit forward a little bit from where the stock seat sat. I'm 5'11" tall and weigh somewhere in the neighborhood of 220 lbs.
Though, If I get much fatter, that Pontiac steering wheel is going to cause problems. eek
#228013 03/14/2007 3:10 AM
i heard the 41-46 cads are 6 inches narrower than the 47-54 style, and are 8 inches shorter too, i don't know if this is true, but looking at my 49 compared to my cousin's 46 it might be
1949 Chevy 3600 Flatbed all orginal
1964 gmc 4000
1973 gmc 6000
2005 chevy duramax 4x4
1994 chevy 1500
Trucks are GM and Tractors are Orange
"I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton
#228014 03/15/2007 5:04 PM
When my seat is all the way back I can not reach the pedals, let alone see the starter, but then I'm only 5'-9
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
#228015 03/15/2007 5:21 PM
The 41-46 cabs are smaller, but I dont know if they affect that much due to where they are smaller, definatly more narrow. Im 6' and only about 170. No problem fitting into either sizes of trucks. One thing to think about is defiantly changing the column. If your big or heavy set, the old columns are solid while a newer column has that collapsable part so if you got in a front end accident the chances of you getting your chest crushed would go down substantially. Im not worried about that to much, but if I had a little less room between me and the column I might be. Just a thought.
My 1953 Chevrolet
1947.1 Gallery
#228016 03/15/2007 5:38 PM
i think you would fit fine. Especially if you found one with (or installed your own) tilt column.
1950 Chevy 3100 5 window "in progress"
1967 Chevelle 300
#228017 03/15/2007 7:39 PM
get a caddy telescoping/tilt column, and you can put it in real deep...
I've got a 39, and although it's not a tight fit, i have to slip in under the column... 70" 190lbs.
my son is 6'3" and he "fits" in there, but he only weighs about 145lbs.
Another quality post.
Real Trucks Rattle
#228018 03/15/2007 8:32 PM
Ex Hall Monitor
Ex Hall Monitor
Where there's a will, there's a way. grin
#228019 03/15/2007 8:50 PM
Junior Member
Junior Member
I am 6'7" and about 265 and I can drive my 51 with no problem. Haven't found a vehicle yet that fits.
#228020 03/15/2007 9:17 PM
I'm 5-4 and about 150 these days. I think my cab is small. However, I've also sat three across so it is really bigger than it feels. I like the fact that I can reach the pedals without adjusting the seat, but I'm not to up close and personal with the steering wheel. In terms of the height, It' fine for me as long as I remember that speed bumps actually work against older trucks.
Mine's all stock, but with a tilt column and the other things discussed you certainly could make it work.
If it ain't broke, take it apart and figure out why!
39 Chevy in the Gallery
Photobucket Album
#228021 03/15/2007 11:15 PM
i managed to put 4 in the cab of my 49 one time(4th guy was sitting on far passanger's lap)but it got us where we need to go
1964 gmc 4000
1973 gmc 6000
1994 chevy 1500
#228022 03/16/2007 12:48 PM
when I had my 38 tagged no problem at 6'1" 205 . no problem moving it around the yard at 240 now
#228023 03/16/2007 2:44 PM
Apprentice
Apprentice
i have a 39 with a s-10 seat on top of the seat mounts. i am 6"2' 280lbs and all i need to do is put ny right leg in and then my left, then duck my head. no problem!
If at first you don't succede, try try again. Then quit, don't be a darn fool about it.
#228024 03/16/2007 2:51 PM
I'm same height and when I last parked the '41 I weighed about 175. Like you Beltfed, the years have taken a toll and I now push 210. I don't recall having a problem before and if memory serves me right there was plenty of room between the wheel and my gut. At first I thought your topic was refering to the size of the truck :blat:
My 1941 in the Stovebolt Gallery
My Photo Album
But I tried, didn't I? ... At least I did that. RP McMurphy
The past belongs to the future...but only the present can preserve it.
Besides the noble art of getting things done, there is a nobler art of leaving things undone.
#228025 03/17/2007 2:34 AM
Well this proves what I have always thought, today's farmers are fatter. grin
~Jim
