7 members (cmayna, Leo, Hotrod Lincoln, Mike in Sycamore, Gdads51, 1955 1 Series, Bill Trotter),
127
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,113 Posts1,056,280 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | I am lusting after a '39 to '46 1/2 truck. Worked on a '51 today for a friend and the shop talk got around to the passenger compartment size on these years of trucks. My buddy says they are small inside and I would be a tight fit. Well Ok, I'm 6'1" and need a diet bad at a tad less than 300 big ones. It's the beer with all that shop talk. So am I to big to fit into my want-to-be-mine truck? Thanks
| | | | | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Just like a pair of pants....I say find one and try it on for size.... I am betting you will fit. While there is not a whole bunch of adjustment, the stock seat does adjust some. If you found one without the tank under the seat, there is probably even more room or you could change the seat out so every thing that belongs in the cab would fit. | | | | | Joined: Feb 2001 Posts: 80 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2001 Posts: 80 | http://www.brads41-46chevys.com/id17.html This link gives you the spects on the 41-46 cabs. I think the 39 40 had 1" or so less leg room. They are smaller then the 51 cabs. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Same heigth but about half a hundred less. The very best thing I did on my 41 was a small diameter tilt column from a 71 chevy van and mounted as close to the dash as allowed. Just 2" is huge when sliding under the wheel. Could have gained more with an aftermarket smaller wheel.
Evan
| | | | | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | I do know that I don't have enough room in my 46, but I have Jeep seats in mine, and they sit forward a little bit from where the stock seat sat. I'm 5'11" tall and weigh somewhere in the neighborhood of 220 lbs. Though, If I get much fatter, that Pontiac steering wheel is going to cause problems.  | | | | | Joined: Feb 2007 Posts: 513 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 513 | i heard the 41-46 cads are 6 inches narrower than the 47-54 style, and are 8 inches shorter too, i don't know if this is true, but looking at my 49 compared to my cousin's 46 it might be 1949 Chevy 3600 Flatbed all orginal 1964 gmc 4000 1973 gmc 6000 2005 chevy duramax 4x4 1994 chevy 1500 Trucks are GM and Tractors are Orange "I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton | | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | When my seat is all the way back I can not reach the pedals, let alone see the starter, but then I'm only 5'-9 | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | The 41-46 cabs are smaller, but I dont know if they affect that much due to where they are smaller, definatly more narrow. Im 6' and only about 170. No problem fitting into either sizes of trucks. One thing to think about is defiantly changing the column. If your big or heavy set, the old columns are solid while a newer column has that collapsable part so if you got in a front end accident the chances of you getting your chest crushed would go down substantially. Im not worried about that to much, but if I had a little less room between me and the column I might be. Just a thought. | | | | | Joined: Nov 2006 Posts: 180 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 180 | i think you would fit fine. Especially if you found one with (or installed your own) tilt column.
1950 Chevy 3100 5 window "in progress" 1967 Chevelle 300
| | | | | Joined: Dec 2002 Posts: 3,441 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,441 | get a caddy telescoping/tilt column, and you can put it in real deep...
I've got a 39, and although it's not a tight fit, i have to slip in under the column... 70" 190lbs.
my son is 6'3" and he "fits" in there, but he only weighs about 145lbs.
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Where there's a will, there's a way.
| | | | | Joined: Feb 2007 Posts: 5 Junior Member | | Junior Member Joined: Feb 2007 Posts: 5 | I am 6'7" and about 265 and I can drive my 51 with no problem. Haven't found a vehicle yet that fits. | | | | | Joined: Dec 2006 Posts: 184 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 184 | I'm 5-4 and about 150 these days. I think my cab is small. However, I've also sat three across so it is really bigger than it feels. I like the fact that I can reach the pedals without adjusting the seat, but I'm not to up close and personal with the steering wheel. In terms of the height, It' fine for me as long as I remember that speed bumps actually work against older trucks.
Mine's all stock, but with a tilt column and the other things discussed you certainly could make it work. | | | | | Joined: Feb 2007 Posts: 513 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 513 | i managed to put 4 in the cab of my 49 one time(4th guy was sitting on far passanger's lap)but it got us where we need to go 1949 Chevy 3600 Flatbed all orginal 1964 gmc 4000 1973 gmc 6000 2005 chevy duramax 4x4 1994 chevy 1500 Trucks are GM and Tractors are Orange "I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton | | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | when I had my 38 tagged no problem at 6'1" 205 . no problem moving it around the yard at 240 now | | | | | Joined: Feb 2007 Posts: 14 Apprentice | | Apprentice Joined: Feb 2007 Posts: 14 | i have a 39 with a s-10 seat on top of the seat mounts. i am 6"2' 280lbs and all i need to do is put ny right leg in and then my left, then duck my head. no problem!
If at first you don't succede, try try again. Then quit, don't be a darn fool about it.
| | | | | Joined: Nov 2000 Posts: 700 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 700 | I'm same height and when I last parked the '41 I weighed about 175. Like you Beltfed, the years have taken a toll and I now push 210. I don't recall having a problem before and if memory serves me right there was plenty of room between the wheel and my gut. At first I thought your topic was refering to the size of the truck :blat: My 1941 in the Stovebolt Gallery My Photo AlbumBut I tried, didn't I? ... At least I did that. RP McMurphy The past belongs to the future...but only the present can preserve it. Besides the noble art of getting things done, there is a nobler art of leaving things undone. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Well this proves what I have always thought, today's farmers are fatter.
~Jim
