9 members (walterhvogel, Jay R, DadsFirstPickup, moparguy, JW51, Jon G, Gray_Ghost, Stovebolt48, 1 invisible),
59
0
Mod | | | Forums66 Topics128,079 Posts1,055,941 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 262 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 262 | Anybody got any ideas how to get oil up off an asphalt driveway? Had a BAD oil leak and got a couple quatrs of oil on the driveway. Cleaned it up with oilsorb, but would like to get more of it up.
My truck: She may not be the prettiest girl at the dance, but she's all mine!
| | | | | Joined: Oct 2005 Posts: 738 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 738 | Sounds like you might have to get some sort of solvent or soap? I also think that a nice stiff brush would be a useful tool to scrub that crap off your driveway. I hope that someone else is more helpful than me, good luck.
Kyle
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton My Machine | | | | | Joined: Jul 2006 Posts: 24 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 24 | Muriatic acid. It's nasty stuff, the same chemical used in pools to keep 'em clean, but undiluted it'll take everything but the concrete up. Should be available through just about any hardware or home improvement store.
Be careful when you use it! Like I said, it's really nasty stuff. Always keep something between you, your clothes, and it; like heavy rubber gloves, safety goggles, etc.
If your state doesn't allow the purchase of it without a hazardous material license, then go for a good quality engine degreaser and a stiff brush.
If a 'truck' is only used to haul butts to the mall, then it's not a truck - it's a car with a roadster trunk.
Old, rusty and ugly - might be me or my fleet. You decide!
| | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | I like the oil eater they sell at costco, just make sure you wash your hands good, it tends to suck all the oils out of your hands and dry em up.
Ive used this stuff on old railroad ties used as steps and actually got a lot of the creasote out with just a few soakings.
Also when used on an engine and hosed off it just knocks the oil off in clumps, sweep it up and throw it away.
Jeff | | | | | Joined: Jan 2004 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2004 Posts: 70 | Is the driveway asphalt or concrete? Muriatic acid will probably take up the asphalt as well as the oil. I've always had good luck with dawn dishwashing liquid on oil stains, but if it's soaked too far into the asphalt you will probably have to recoat. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | WD40 is supposed to work well Bill | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I can't add anything to the above except that if you are successful in getting the stain out let us know what you used and how you did it.
| | | | | Joined: May 2001 Posts: 709 Shop Shark | | Shop Shark Joined: May 2001 Posts: 709 | I' ve had great success using Castrol Super Cleaner for oil and grease remover. Ok to use on concrete but would try a small spot if the driveway is asphalt. Powerful stuff too and will eat your skin so use with care. Probably not environmentaly friendly either.
Bruce Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten) New Toy: 1962 Impala SS Coupe The Driver: 1990 Toyota truck
| | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | Don't know about asphalt, but Simple Green works well on concrete. And it IS supposed to be environmentally friendly. I know it cleans up with plain water. | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Scrub the area down with minerals spirits and hose it off right away. Use a firm bristle brush and it should be all but gone, but try a small area to see how it will act with the asphalt, Scott | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | You could try spic/span powder soap and a stiff brush.gojo hand cleaner may work for you. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Jun 2006 Posts: 110 Member | | Member Joined: Jun 2006 Posts: 110 | Simple Green or liquid laundry detergent and a stiff brush or broom. I dropped a gallon of oil in my 2 car garage once and was amazed at how much surface area it covered.
Had a 3000HP stationary diesel pop a coupling once. Amazing how fast a 200GPM pump can empty a 150 gal sump.
WD40 will break down the oil-based tar in the asphalt...ask me how I know.
Jim
Good luck with your project!
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | you wont believe this,,,,,,,,,,,,but take some crushed sheet rock, put it on, let it set, then sweep away...........................I will give you my address later for the check Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Nov 2005 Posts: 144 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 144 | TSP (Tri-Sodium Phosphate) will do the job and it's cheap like borscht. | | | | | Joined: Nov 2005 Posts: 140 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 140 | I don't have any sugestions but good luck at getting it up off your driveway
Now boltless but looking 1951 F-1 350/350 1965 Mustang 355 glide 1971 F-100 401 fe it hates me 1972 Maverick 302 c4
| | | | | Joined: Jun 2006 Posts: 110 Member | | Member Joined: Jun 2006 Posts: 110 | Joker,
Never thought of using gypsum. Makes a lot of sense though. I always drys me out. Thanks for the tip.
TSP has been banned in a lot of places and I haven't tried "TSP substitute" yet. I remember reading that Wisk is mainly TSP. We used TSP in boiler water treatment. Cleanest tanks in the plant!
Jim
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | darn it joker,i tried the crushed sheetrock,now i have a $#@!%^& hole in the wall to fix !! LOL !!! 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Jul 2004 Posts: 78 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2004 Posts: 78 | I have had good luck with kitty litter the cheapest you can find. Pour it out and then grind it in with your feet. Good Luck Steve | | | | | Joined: Jun 2006 Posts: 110 Member | | Member Joined: Jun 2006 Posts: 110 | Yup that cheap clay based stuff. The safety clean guy used to sell us speedy dry at several times the cost and then one day I was cleaning the cat box and...........
Jim
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | kitty litter is good,use your work boots and grind it in the mess.sweep it up !!! 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: May 2004 Posts: 124 Member | | Member Joined: May 2004 Posts: 124 | Many years ago when I worked in a gas station we used battery acid out of old batteries. It worked real good on concrete. As for asphalt, it is made of oil so I dont think you can seperate the unwanted oil from the good stuff.
I like old trucks
| | | | | Joined: Feb 2000 Posts: 5,208 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,208 | I use liquid dish soap, brush it in and let it sit till it rains! Concrete powder will also work! | | | | | Joined: Dec 2002 Posts: 3,440 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,440 | I use kitty litter (oil soak), grind it in with my boot, sweep it up, then throw on another scoop and grind it in.. let it sit for a while..
brake cleaner works good on concrete too.
| | | | | Joined: Jul 2005 Posts: 640 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 640 | Sorry, but that oil won't come out, so you'll have to move. Since your driveway is asphalt, I would recommend against using the muriatic acid. The kitty litter idea sounds best. Another idea, and I don't know if this would be effective, is to work some waterless hand cleaner into the area to loosen up and combine with the oil, then hose it off. Follow that up with the dish washing liquid. If none of the ideas work, consider installing sheet linoleum over your driveway. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | special kitty from walmart $2.22 a bag !!! Good kitty !!!!! 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | A peice of 2x4 work very well for grinding in kitty litter. Sure beats getting it on your boots and tracking it all over.
Bill Burmeister | | |
