9 members (moparguy, Bill Hanlon, GRNHydra, Otto Skorzeny, mason86, klhansen, Gray_Ghost, mick53, Hawkman), 93 guests, and 2 robots.
Topics128,069
Posts1,055,886
Members48,428
#213076 08/06/2006 6:54 PM
Anybody got any ideas how to get oil up off an asphalt driveway? Had a BAD oil leak and got a couple quatrs of oil on the driveway. Cleaned it up with oilsorb, but would like to get more of it up.
My truck: She may not be the prettiest girl at the dance, but she's all mine!
#213077 08/06/2006 7:07 PM
Sounds like you might have to get some sort of solvent or soap? I also think that a nice stiff brush would be a useful tool to scrub that crap off your driveway. I hope that someone else is more helpful than me, good luck.
Kyle
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton
My Machine
#213078 08/06/2006 8:32 PM
Muriatic acid. It's nasty stuff, the same chemical used in pools to keep 'em clean, but undiluted it'll take everything but the concrete up. Should be available through just about any hardware or home improvement store.
Be careful when you use it! Like I said, it's really nasty stuff. Always keep something between you, your clothes, and it; like heavy rubber gloves, safety goggles, etc.
If your state doesn't allow the purchase of it without a hazardous material license, then go for a good quality engine degreaser and a stiff brush.
If a 'truck' is only used to haul butts to the mall, then it's not a truck - it's a car with a roadster trunk.
Old, rusty and ugly - might be me or my fleet. You decide!
#213079 08/06/2006 9:01 PM
I like the oil eater they sell at costco, just make sure you wash your hands good, it tends to suck all the oils out of your hands and dry em up.
Ive used this stuff on old railroad ties used as steps and actually got a lot of the creasote out with just a few soakings.
Also when used on an engine and hosed off it just knocks the oil off in clumps, sweep it up and throw it away.
Jeff
My 1953 Chevrolet
1947.1 Gallery
#213080 08/06/2006 9:04 PM
Is the driveway asphalt or concrete? Muriatic acid will probably take up the asphalt as well as the oil. I've always had good luck with dawn dishwashing liquid on oil stains, but if it's soaked too far into the asphalt you will probably have to recoat.
#213081 08/06/2006 9:06 PM
WD40 is supposed to work well grin
#213082 08/06/2006 9:26 PM
Ex Hall Monitor
Ex Hall Monitor
I can't add anything to the above except that if you are successful in getting the stain out let us know what you used and how you did it.
#213083 08/06/2006 10:09 PM
I' ve had great success using Castrol Super Cleaner for oil and grease remover. Ok to use on concrete but would try a small spot if the driveway is asphalt. Powerful stuff too and will eat your skin so use with care. Probably not environmentaly friendly either.
Bruce
Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten)
New Toy: 1962 Impala SS Coupe
The Driver: 1990 Toyota truck
#213084 08/06/2006 10:19 PM
Don't know about asphalt, but Simple Green works well on concrete. And it IS supposed to be environmentally friendly. I know it cleans up with plain water.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
#213085 08/06/2006 10:21 PM
Simple green
#213086 08/06/2006 10:21 PM
Scrub the area down with minerals spirits and hose it off right away. Use a firm bristle brush and it should be all but gone, but try a small area to see how it will act with the asphalt,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#213087 08/06/2006 11:08 PM
You could try spic/span powder soap and a stiff brush.gojo hand cleaner may work for you.
1951 3100 Chevrolet
#213088 08/06/2006 11:12 PM
Simple Green or liquid laundry detergent and a stiff brush or broom. I dropped a gallon of oil in my 2 car garage once and was amazed at how much surface area it covered.
Had a 3000HP stationary diesel pop a coupling once. Amazing how fast a 200GPM pump can empty a 150 gal sump.
WD40 will break down the oil-based tar in the asphalt...ask me how I know.
Jim
Good luck with your project!
#213089 08/06/2006 11:52 PM
you wont believe this,,,,,,,,,,,,but take some crushed sheet rock, put it on, let it set, then sweep away...........................I will give you my address later for the check
Redryder pix
My Hotrod
#213090 08/07/2006 12:29 AM
TSP (Tri-Sodium Phosphate) will do the job and it's cheap like borscht.
#213091 08/07/2006 12:34 AM
I don't have any sugestions but good luck at getting it up off your driveway
Now boltless but looking
1951 F-1 350/350
1965 Mustang 355 glide
1971 F-100 401 fe it hates me
1972 Maverick 302 c4
#213092 08/07/2006 12:36 AM
Joker,
Never thought of using gypsum. Makes a lot of sense though. I always drys me out. Thanks for the tip.
TSP has been banned in a lot of places and I haven't tried "TSP substitute" yet. I remember reading that Wisk is mainly TSP. We used TSP in boiler water treatment. Cleanest tanks in the plant!
Jim
#213093 08/07/2006 1:37 AM
darn it joker,i tried the crushed sheetrock,now i have a $#@!%^& hole in the wall to fix !! LOL !!!
1951 3100 Chevrolet
#213094 08/07/2006 2:14 AM
I have had good luck with kitty litter the cheapest you can find. Pour it out and then grind it in with your feet.
Good Luck
Steve
#213095 08/07/2006 2:18 AM
Yup that cheap clay based stuff. The safety clean guy used to sell us speedy dry at several times the cost and then one day I was cleaning the cat box and...........
Jim
#213096 08/07/2006 3:32 AM
kitty litter is good,use your work boots and grind it in the mess.sweep it up !!!
1951 3100 Chevrolet
#213097 08/08/2006 12:20 AM
Many years ago when I worked in a gas station we used battery acid out of old batteries. It worked real good on concrete. As for asphalt, it is made of oil so I dont think you can seperate the unwanted oil from the good stuff.
I like old trucks
#213098 08/08/2006 2:07 AM
I use liquid dish soap, brush it in and let it sit till it rains! Concrete powder will also work!
#213099 08/08/2006 3:27 PM
I use kitty litter (oil soak), grind it in with my boot, sweep it up, then throw on another scoop and grind it in.. let it sit for a while..
brake cleaner works good on concrete too.
Another quality post.
Real Trucks Rattle
#213100 08/09/2006 2:45 AM
Sorry, but that oil won't come out, so you'll have to move. smile
Since your driveway is asphalt, I would recommend against using the muriatic acid. The kitty litter idea sounds best. Another idea, and I don't know if this would be effective, is to work some waterless hand cleaner into the area to loosen up and combine with the oil, then hose it off. Follow that up with the dish washing liquid.
If none of the ideas work, consider installing sheet linoleum over your driveway.
1948 Chevy 1/2-Ton
"Tuesdays with Morris"
In the Legacy Gallery
Find it - Fix it - Drive it
#213101 08/09/2006 2:47 AM
special kitty from walmart $2.22 a bag !!! Good kitty !!!!!
1951 3100 Chevrolet
#213102 08/09/2006 2:52 AM
A peice of 2x4 work very well for grinding in kitty litter. Sure beats getting it on your boots and tracking it all over.
Bill Burmeister
