6 members (GIJOE298, delky, Bill Hanlon, moparguy, Peggy M, Southerntruck), 101 guests, and 1 robot.
Topics128,131
Posts1,056,723
Members48,454
I am looking to add matching mirrors to my truck.
Never really have liked the look of two different style of stock mirrors. Interested to hear what everyones using...pictures would be great!!
Chuck
Blue 50
1950 3100 w/57 235
Patrick’s Saginaw 4 speed and 3:55 rear end
blue 50, i am using the peep style and i like them i like the uncluttered look. i did have to ad a glue on convex to the passengers side. look at my webshots, i don't know how to post pictures. ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Two round black mirrors in the stock location using the two different arm designs. I like them but they do stick out and I am forever hooking on them as I walk by.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
I use chrome stock on mine,,you just have to look real good before you make a move,,,,,,Fred
Redryder pix
My Hotrod
Small west coast mirrors w/ fisheye, blinker light (both) plus a round upper door mounted 'peep' on drivers side. My inside is a modern auto dim, compass, temp gauge mounted under an upper boxed in compartment, (radio in center, two pigeon holes on the sides) w/ courtesy lamps.
gooday
jim
Gooday
Jim
small wheel moves by fire and rod,
big wheel fires by the grace of god,
everytime that wheel turns round,
bound to cover just a little more ground.
Peep mirrors,3".may want to use 4"
dan-pa
My '50 3100 came with a rectangular mirror on the driver side, mounted to what appears to be the original arm.
The mirror was cracked, and I replaced it with a 4" round mirror I scored in a box with a bunch of other junk from the auction for a buck.
I dont have a mirror on the passenger side. The rearview mirror.. don't know if it's stock, but it looks like it is.. it's kind of narrow, and hard to really get a full view out the back window, so i'll probably replace it with something a little wider.
Socket Breaker
Socket Breaker
several of the vendors offer universal mirrors or mirrors that will mount up other than the stock style.
try a parts store and look at replacement mirrors... or check if they have a catalog, Then you can flip through it and check 'em out.
Try google.com image search for your model truck and see what comes up.
just a few ideas...
-W
I have 2-6" round painted stock mirrors on my '60 GMC.
Jake
1960 GMC 305A V-6 Gallery Page
Remember, the government cannot give --anything to anyone --that they have not first taken away from someone else.
BUY AMERICAN http://www.stillmadeinusa.com/index.html
I have round mirrors on both sides. Got them from Chevy Duty I think. One problem is that the center bolt rusts easily.. ya think they'd use stainless!!
Also added a 3" peep to drivers side. Helps get over the side mount spare. Put in an interior day/night mirror from one of the catalogs... it pretty much sucks. It really doesn't do the "night" part of it's function.
Larry Bear
55.5 Chevy 3100 Panel
Quote
Same deal here on two diff trucks, guess there's no stainless in China,,Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
I had 4X6 mirrors on the 49. Looked kind of goofy. The PO put a driver side arm on the passenger side so the mirror was right behind the post. So, I ordered the correct arm for the pass side and some round mirrors. I tried to put on the pass side arm and the PO must have drilled the holes in the wrong place cause I still couldn't see it. I think I'm gonna weld up the holes on the pass side and just keep the driver side mirror. I have a 5 window cab, so I really don't need a pass side mirror.
Socket Breaker
Socket Breaker
Quote
Get it clean - paint it with clear fingernail polish...
or use one of those model paint pens in clear...
-W
Junior Member
Junior Member
Any of you 60-66 owners have pics of the round mirrors? I'd like to see what they look like. Also, what's the diameter?
1966 SWB
Mine are 5 inch round, stock arms,,kinda small but I really don't care where I've been, just who's in front. Brian
Junior Member
Junior Member
Well, i've been driving w/out one.. left lane changes suck wink
1966 SWB
Chuck,
I plan on having the tall rectangle ones. My truck came with left bracket only and no mirror. Mine looks similar to this one or this one . Any one know what these are called?
Quote
Originally posted by StukThrtl: Any of you 60-66 owners have pics of the round mirrors?
Mirrors from LMC
Rance
66 C10 FS/LB 292/4-spd manual (I also enjoy Hang Gliding)
I'm too sexy for my hair, that's why it isn't there
Im going for different. Everyone uses peep mirrors, and they are small for a Burb. Im using 1961 Studebaker Avanti mirrors, $65 each reman.
John Kennedy
1950 Suburban street rod
Pics in the Gallery.......
new site up!
http://home.joimail.com/~kennedyjp/
Junior Member
Junior Member
Running full size West Coast on both sides w/spot on bottom outside RH. When I first got the beast I was thinking "It's not a REAL truck, it's just a pick-em-up." After about a week of driving it I revised my opinion and decided that a 66 GMC 3/4 ton long-bed with a 292 most certainly IS a real truck-'cause it darn sure wasn't going to tolerate being driven any other way. So I replaced the half-assed WC's it had with proper full loops plus brace and separate mirrors all in stainless.
IF YOU DIDN'T TEST IT, IT DOESN'T WORK
I've got a rectangular aftermarket mirror on the left and I think i've got the original round one from the left side on the right. Seeing as the round one is cracked, I'm going to have it replaced with an "Objects in Mirror are closer than they appear" mirror. That one is crappy for backing up.
I have no mirror on the inside, but I am going to see if I can score one from an AD... or maybe a later one. If not, I'll probably buy one from American Classic Truck Parts. They've got a nice metal one that looks like it could have been in my truck originally.
What are west coast mirrors? are they the big ones that run vertical and attatch above and below window? I'm kinda thinking of those. I have a 3-window and need all the help seeing I can get.
Blue 50
1950 3100 w/57 235
Tab Offline
I bought one peep mirror for the drivers side and I attached a flat mirror to my sun visor that works surprisingly well.
delete my account and pictures
And now for something completely different,... I am using mirrors from a Volvo 240 mounted on chrome stock arms. I had to grind off the original mounts, but since they are solid aluminium, plishing the the cut is no big deal. I used the tensioner screw to mount the mirror. The shape is similar to the original pre-54 tail lights, but 4 times the size. Look nice.
I have a single 5" round mirror on the driver's side of my '66 C-10.
Junior Member
Junior Member
Peep mirrors on my 53. Think I got them from Jim Carter.
I use the stock round mirror on the drivers side only, but very seriously considering adding a peep mirror to get a better view around the side mount spare. Inside mirror stock.
Apprentice
Apprentice
One drivers side peep mirror on mine.
fifty-one half-ton
