0 members (), 102 guests, and 3 robots.
Topics128,186
Posts1,057,319
Members48,469
#178322 09/14/2004 9:33 PM
Junior Member
Junior Member
OK... I need to know whether to Restore my old truck to original or Hot Rod it or maybe something in betwixt the two.
#178323 09/14/2004 9:40 PM
What year, what kind, what shape? Inquiring minds need to know! Then stand back because that can of worms can bring on some wonderful eek discussions.
popcorn The Truth is Out There (Oh I'm going as much stock look until I start it)
#178324 09/14/2004 9:46 PM
Junior Member
Junior Member
Popcorn the 1944 Chevrolet 1/2 ton pickup in fairly good condition overall.. doesnt run but rolls... solid sheet metal "with rust in the normal areas".
#178325 09/14/2004 9:55 PM
Rod it!!! (ducking for cover......)
grin
- Ryan
59 Apache Step
78 El Camino
http://www.wsu.edu/~rsain
#178326 09/14/2004 10:15 PM
Anonymous
Unregistered
Anonymous
Unregistered
Rodsteration is the ticket. All the bennies of IFS, power braking and horsepower with the good looks of old iron - Move over Ryan as I jump into your fox hole with you. grin
#178327 09/14/2004 10:17 PM
Smoky: Sounds like you may a good truck for retsro. usually if the truck is in bad shape rodding is the best option. But, when they are that old and fairly good shape they would be better off as orginal as they can be a better resale if that needed to be done.
We all make decisions what to do or you should before you start what you want it to be. Mine was in pieces, bad shape already had a junk 350 in it. Due to Maws and my age we felt better rodding it for the creature comforts that I can install in the cab. Plus I always have this need for speed. Keeping mine as orginal on the outside as I can if the truck ever get's sold it could be made back to a restoration project.
popcorn The Truth is Out There (Of course you could suicide the doors and climb in it backwards hehee hehee)
#178328 09/14/2004 10:21 PM
Smokey, how do you know your truck is a 1944 model ?
#178329 09/14/2004 11:51 PM
Junior Member
Junior Member
I would go along with the Rodstoration....idea...
Update all the mechanicals...brakes, engine, rearend...yada yada yada..
Then keep the body the same, the Interior the same everything else the same....
You could have the best of two worlds. Plus do you want to be able to drive the truck daily or do you want to drive it once in awhile?
#178330 09/15/2004 12:40 AM
Rusty Rod says to Rod it... how many 44 1/2t pickups are even out there? And how does one know that it's not just a left over 41?
Another quality post.
Real Trucks Rattle
#178331 09/15/2004 2:24 AM
Well if it were mine most likely it would be rodded. But its yours, so build your dream not mine!
#178332 09/15/2004 2:33 AM
Modernize it. More for safety and comfort than speed and cornering. If you can't cruise in it reliably, then it's just a lawn ornament.
Just my opinion, take it with a grain of salt,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#178333 09/15/2004 2:36 AM
We're rodding the '46 of my son's (with a Chrysler big block!!! grin ), because that's what we have and it's his truck. Let your personal preference guide you, then go that route. Ours is actually complete enough to restore, but then, we want something that we can drive on the highway at 70-75 and not just on the side roads at 50!
Pessimist - Sees glass as half-empty. Optimist - Sees glass as half-full. Gov't- Sees glass and takes it from you because you have a glass.
Political Correctness: A philosophical belief system bereft of common sense and logic, that supports and rewards ignorance and stupidity.
#178334 09/15/2004 5:05 AM
IF you have a 44, think about it before you rod it....Only because not too much is left around from 42 to 45....Almost all of them went to Europe or the Pacific and were painted green....
There are lots of worn out 41 and 46s to cut, chop, paste, or do whatever you like....your 44 just might pay some of the bills for a rod project if it were fixed up a little and sold as "restorable" or a running 1944 non army truck.
But if it were me, I'd throw a 261 in it and make it a driver w/o chopping it up too bad....
#178335 09/15/2004 3:46 PM
I am a rodder myself, but if your truck is indeed a 1944 half ton, I would say restore it. 46 in Progress is correct that there are not many 1944 1/2 ton trucks out there. Restore this one and/or find a different year of truck to rod.
Never hold your farts in. They travel up your spine and into your brain...that is where crappy ideas come from.
#178336 09/15/2004 6:25 PM
As rare as that truck is -- if it was mine, I'd take the road to restoration.
#178337 09/16/2004 9:39 PM
And I agree again, with Norse, 100%! grin
#178338 09/20/2004 7:19 AM
Junior Member
Junior Member
Make that four for restore! If it is truely a '44 then that needs to be saved. If you want to rod, then pick a somewhat sold shell of a common year. "Leave the solid rides to the restorers and what ever is left over to the rodders". Ok, now it's my turn to run... eek grin
#178339 09/20/2004 7:54 AM
Since Oly know's more then I do about hot rodding, he is going to show me how to restore a hot rod. 1949 chevy panel half ton with a 3 speed on the column, I would afto find a mustang two front end clip with a 350 - 350 combo
Times are changing-By Bob Dylan
Cindy in Oregon
1945 GMC COE Victory Truck 5ton COE- NOT FOR SALE
1955 Chevy First series 5 window p/u
1947 Antique Husband only series
#178340 09/20/2004 10:43 PM
If it were mine I would SELL it. That is assuming I could confirm to a buyer that it was indeed a 1944. Then with the money I made off of it (because of its oddball war year) I would buy another year and start chopping.
#178341 09/21/2004 12:05 AM
a 1944??,,definetly a restore project,,how many 1944 Chevs do you see on the road,,,rare as hens teeth,,if it truly is a 44,you have something there,dont cut it up... :p
#178342 09/21/2004 12:16 AM
I thought 45's were rare but, I didn't think there was any 44's at all. :confused:
#178343 09/21/2004 12:24 AM
If you can prove it's a '44, keep it and restore it, by all means! I was thinking about that and the year didn't click until now. In 1944, what little civilian pickup production there was, was strictly for civil defense and limited farm and commercial sales. Production was only a few hundred, at most, from what I read several years ago. I remember a '44 1/2-ton in Tacoma, Washington in 1981 that a guy had. Came off his Dad's farm near Enumclaw, so it was a one-family owed truck at that time. They're out there somewhere!
#178344 11/10/2005 6:18 PM
Junior Member
Junior Member
I have a 45 according to the tile, and a 46, 46 in very good condition, 45 no rust fenders need lots of work. I have a 230 in the bed, #'s indicate its 62-69 and a 235 that runs good. Also 46 has a 216 under hood that is suppose to run. Body on 46 has been redone as has the fenders hood, found very good fenders and running boards. Son wants to put mustang 11 under 46 and 6 in 45. He wants 350 in 46, but I have a good 4.3. Would like to know which to restore and which to rod and how hard to put clip in, as well as bigger engine. Any sights for clip instalation? if so would like email at [email protected] thanks
#178345 11/10/2005 6:24 PM
Junior Member
Junior Member
Just like to add that 46 is an easy restore since all major componets are excellent and there. Son is the welder and blackmails me that he will only do it his way. 45 has all the data plates. Was told to put 235 in with S10 5sp tranny and Nova rear end, and to keep original front end. Any opinions. Also told to put dual carbs on 235 and dual exhaust. Why should I not use the 4.3 chev that was for my flat fender jeep?
#178346 11/10/2005 7:58 PM
AFAIK, there were no 1/2 ton civilian model trucks built in the 1944 production year.
They didn't build any in the 1943 production year, either.
They built 23703 in the 1942 production year, and they built 6202 in the 1945 production year, so perhaps it is one from those years, or a military contract order that was indeed a '44.
What's the VIN? We could probably tell you right quick what year it is.
If it really is a '44, then I'm with the Restoration guys. If it's not, then I say go for whatever makes you happiest. Personally, I'd keep it looking stock on the outside, but maybe do some upgrades.
#178347 11/10/2005 9:40 PM
I HOPE THAT YOU CHOOSE TO RESTORE THE FORTY-FOUR! However, it is your baby, and you can do whatever you want to do to it.
#178348 11/10/2005 11:06 PM
Junior Member
Junior Member
Rod it!!
You never really learn to swear until you learn to drive.
#178349 11/10/2005 11:27 PM
Rod or restore,it's no ones choice but yours! Build it the way that you want!
Come to the Great Lakes GABfest
Get all the details here!
#178350 11/10/2005 11:53 PM
2 Offline
Ryan, Did you feel the cross hairs on your back? Or was it the red dot on your forhead?
#178351 11/11/2005 3:12 AM
I wonder what became of Smokeys truck... the Camp Pendleton mobility museum has a 41-46 military pickup... it has the flat fenders ect on it.. but the cab looks the same as a civvy truck.
Real Trucks Rattle
#178352 11/11/2005 6:33 AM
Former Workshop Owner
I am in favor of restoration, as it is a rare find. But like some of the others have said, it is your truck, and you should be able to do what you want. I also agree that there is a lot of iron out there that is very rod worthy. If you want to build a rod, there are many that have been started, but not completed.
I only suggest that you really think it through before you start chopping it up. That is the easy part. If it will be your first rod, here are a few things to consider. Do you have the garage space available that you won't need for an extended period? It could take a couple years, unless you have a lot of extra time. Do you have a plan of what you would want to do to it? Have you figured in all of the cost's that you will incur? Do you have the patience to stay with it all the way to the finish?
It would be a shame,if after all the disassembly and chopping that you would lose interest and it would end up being another butchered project to be sold (usually at a loss).
On the otherhand, a mild restoration can be carried out in phases. Can be done rather cheaply. And for a lot of peple, it can be a very rewarding hobby. You would work on it when you have the time, and extra money. If it were made somewhat road worthy first, it could be moved around, so you would still be able to use the space for other things if needed.
If it was mine, I would try to keep it mostly original, or sell it to someone to restore, and buy a project that someone had given up on, to build a rod.
Whichever you decide, good luck. Now how about some photo's.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
#178353 11/11/2005 1:24 PM
You all might get a kick out of this old, old page from the site.
I had just come across it during the week as we are trying to update the old pages.
It's not even dated and I'm not sure if the links work. But was a pretty good piece on rod / not rod / and a good "middle of the road."
Also ... gives you another glance of our old stuff.
Peg
~ One of many.
#178354 11/12/2005 4:08 AM
If your truck really is a '44, I vote to restore it, if your skills, pocketbook, and patience is up to it. If not, I recommend a solid rebuild until such a time as it is ready for a restoration. Rebuilding a truck is a terrific way to learn about your truck, enjoy it, and yet preserve the truck as a rare piece of history.
Tom Brownell's book, "How to Restore Your Chevrolet Pickup" has a great section on the rod/rebuild/restore debate.
Personally, I don't see a darn thing wrong with rodding a vehicle and none of my own have been restored. However, the war-year trucks are special and I would treat them differently than the more common trucks.
Most importantly, do what is going to make you happy! It is your truck.
~ Kimberly
My '54 ... and my '63 and a '59 F100
#178355 11/12/2005 4:28 AM
make it a driver that you will enjoy. the way you want it to look is all up to you. if its a solid old truck i would try to keep it that way. fix,drive,enjoy...mike j
Drive with Pride. mike j
family pic
#178356 11/12/2005 4:48 AM
My two prides and joy are 1946 trucks and both have lived their lives as farm trucks.. and that's the way they'll stay.
There will undoubetebly come a day with the 216 in the 1/2 ton will give up the ghost, and I doubt i'll put a 216 back in it.. probably a 261 with a updated rear and 5 speed tranny.
Not sure if that's what you'd call a rod or a restore, but for me it's all about function before fashion.
A '44 truck would be a rare bird.. i'd probably sell it and use the proceeds to buy a '41 or '46 thats a little closer to what you're looking for.
But in the end, it's your truck.. do to it what you need to do so it'll do what you need it to do.
#178358 11/12/2005 4:45 PM
True.. but somebody else with a simular situation might come along and find the information usefull.
#178359 11/13/2005 3:59 PM
im in the same delima i have a 42 1/2 ton
ya I know a few rednecks.Thay all drive chevys to,
Proud member of the Old Dominion Stovebolt Society
AND A MARINE
trucks range from 1942 1/2 ton to 1965 fire engine
#178360 11/13/2005 5:29 PM
Mine is a no problem answer, 1955 first series GMC that is a 74,000 mile original not restored. Just a good cleanup, even buffed the stock 50 yr. old paint and it shines. I have had over 40 vehicles and always rodded everything but this one is too good to do anything but drive! The problem is yours but with such a rare find, if it is in fair shape either restore it or sell it to someone that will and buy what you want. My $.02
#178361 11/13/2005 6:17 PM
As an old fart that was actually around in 44 I remember several things that may clarify the scene. All 43 and 44 models were actually 42's because the automakers had converted to war production. GM was a tank builder, Ford built the B-24 bomber, Kaiser ships, and Packard the PT boat engines. Of course they produced many other items also. One of the few civilians that could purchase a new truck was a veterinarian because production of meat was a vital war effort and a rampant disease among livestock could not be allowed. These few trucks going into civilian hands were registered as the current year even though they were 42 models. Remember this is coming from an "elderly" brain and maybe some others can fill in the gaps. Evan
Evan
