1 members (Peggy M),
74
0
Mod | | | Forums66 Topics128,094 Posts1,056,064 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2004 Posts: 11 Junior Member | | Junior Member Joined: Apr 2004 Posts: 11 | OK... I need to know whether to Restore my old truck to original or Hot Rod it or maybe something in betwixt the two. | | | | | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | What year, what kind, what shape? Inquiring minds need to know! Then stand back because that can of worms can bring on some wonderful  discussions. popcorn The Truth is Out There (Oh I'm going as much stock look until I start it) | | | | | Joined: Apr 2004 Posts: 11 Junior Member | | Junior Member Joined: Apr 2004 Posts: 11 | Popcorn the 1944 Chevrolet 1/2 ton pickup in fairly good condition overall.. doesnt run but rolls... solid sheet metal "with rust in the normal areas". | | | | | Joined: Jul 2003 Posts: 179 Member | | Member Joined: Jul 2003 Posts: 179 | Rod it!!! (ducking for cover......) - Ryan
59 Apache Step 78 El Camino http://www.wsu.edu/~rsain
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | Rodsteration is the ticket. All the bennies of IFS, power braking and horsepower with the good looks of old iron - Move over Ryan as I jump into your fox hole with you.  | | | | | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | Smoky: Sounds like you may a good truck for retsro. usually if the truck is in bad shape rodding is the best option. But, when they are that old and fairly good shape they would be better off as orginal as they can be a better resale if that needed to be done.
We all make decisions what to do or you should before you start what you want it to be. Mine was in pieces, bad shape already had a junk 350 in it. Due to Maws and my age we felt better rodding it for the creature comforts that I can install in the cab. Plus I always have this need for speed. Keeping mine as orginal on the outside as I can if the truck ever get's sold it could be made back to a restoration project.
popcorn The Truth is Out There (Of course you could suicide the doors and climb in it backwards hehee hehee) | | | | | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | Smokey, how do you know your truck is a 1944 model ? | | | | | Joined: Jul 2004 Posts: 26 Junior Member | | Junior Member Joined: Jul 2004 Posts: 26 | I would go along with the Rodstoration....idea...
Update all the mechanicals...brakes, engine, rearend...yada yada yada..
Then keep the body the same, the Interior the same everything else the same....
You could have the best of two worlds. Plus do you want to be able to drive the truck daily or do you want to drive it once in awhile? | | | | | Joined: Dec 2002 Posts: 3,441 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,441 | Rusty Rod says to Rod it... how many 44 1/2t pickups are even out there? And how does one know that it's not just a left over 41?
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Well if it were mine most likely it would be rodded. But its yours, so build your dream not mine!
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Modernize it. More for safety and comfort than speed and cornering. If you can't cruise in it reliably, then it's just a lawn ornament. Just my opinion, take it with a grain of salt, Scott | | | | | Joined: Apr 2004 Posts: 543 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 543 | We're rodding the '46 of my son's (with a Chrysler big block!!!  ), because that's what we have and it's his truck. Let your personal preference guide you, then go that route. Ours is actually complete enough to restore, but then, we want something that we can drive on the highway at 70-75 and not just on the side roads at 50!
Pessimist - Sees glass as half-empty. Optimist - Sees glass as half-full. Gov't- Sees glass and takes it from you because you have a glass. Political Correctness: A philosophical belief system bereft of common sense and logic, that supports and rewards ignorance and stupidity.
| | | | | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | IF you have a 44, think about it before you rod it....Only because not too much is left around from 42 to 45....Almost all of them went to Europe or the Pacific and were painted green....
There are lots of worn out 41 and 46s to cut, chop, paste, or do whatever you like....your 44 just might pay some of the bills for a rod project if it were fixed up a little and sold as "restorable" or a running 1944 non army truck.
But if it were me, I'd throw a 261 in it and make it a driver w/o chopping it up too bad.... | | | | | Joined: May 2003 Posts: 328 Shop Shark | | Shop Shark Joined: May 2003 Posts: 328 | I am a rodder myself, but if your truck is indeed a 1944 half ton, I would say restore it. 46 in Progress is correct that there are not many 1944 1/2 ton trucks out there. Restore this one and/or find a different year of truck to rod.
Never hold your farts in. They travel up your spine and into your brain...that is where crappy ideas come from.
| | | | | Joined: Oct 2003 Posts: 185 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 185 | As rare as that truck is -- if it was mine, I'd take the road to restoration. | | | | | Joined: Nov 2003 Posts: 285 Shop Shark | | Shop Shark Joined: Nov 2003 Posts: 285 | And I agree again, with Norse, 100%!  | | | | | Joined: May 2004 Posts: 27 Junior Member | | Junior Member Joined: May 2004 Posts: 27 | Make that four for restore! If it is truely a '44 then that needs to be saved. If you want to rod, then pick a somewhat sold shell of a common year. "Leave the solid rides to the restorers and what ever is left over to the rodders". Ok, now it's my turn to run...  | | | | | Joined: Mar 2001 Posts: 21 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 21 | Since Oly know's more then I do about hot rodding, he is going to show me how to restore a hot rod. 1949 chevy panel half ton with a 3 speed on the column, I would afto find a mustang two front end clip with a 350 - 350 combo
Times are changing-By Bob Dylan Cindy in Oregon 1945 GMC COE Victory Truck 5ton COE- NOT FOR SALE 1955 Chevy First series 5 window p/u
1947 Antique Husband only series
| | | | | Joined: Aug 2002 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2002 Posts: 127 | If it were mine I would SELL it. That is assuming I could confirm to a buyer that it was indeed a 1944. Then with the money I made off of it (because of its oddball war year) I would buy another year and start chopping. | | | | | Joined: Aug 2002 Posts: 117 Shop Shark | | Shop Shark Joined: Aug 2002 Posts: 117 | a 1944??,,definetly a restore project,,how many 1944 Chevs do you see on the road,,,rare as hens teeth,,if it truly is a 44,you have something there,dont cut it up... :p | | | | | Joined: Mar 2002 Posts: 553 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 553 | I thought 45's were rare but, I didn't think there was any 44's at all. :confused: | | | | | Joined: Apr 2004 Posts: 543 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 543 | If you can prove it's a '44, keep it and restore it, by all means! I was thinking about that and the year didn't click until now. In 1944, what little civilian pickup production there was, was strictly for civil defense and limited farm and commercial sales. Production was only a few hundred, at most, from what I read several years ago. I remember a '44 1/2-ton in Tacoma, Washington in 1981 that a guy had. Came off his Dad's farm near Enumclaw, so it was a one-family owed truck at that time. They're out there somewhere!
| | | | | Joined: Nov 2005 Posts: 5 Junior Member | | Junior Member Joined: Nov 2005 Posts: 5 | I have a 45 according to the tile, and a 46, 46 in very good condition, 45 no rust fenders need lots of work. I have a 230 in the bed, #'s indicate its 62-69 and a 235 that runs good. Also 46 has a 216 under hood that is suppose to run. Body on 46 has been redone as has the fenders hood, found very good fenders and running boards. Son wants to put mustang 11 under 46 and 6 in 45. He wants 350 in 46, but I have a good 4.3. Would like to know which to restore and which to rod and how hard to put clip in, as well as bigger engine. Any sights for clip instalation? if so would like email at [email protected] thanks | | | | | Joined: Nov 2005 Posts: 5 Junior Member | | Junior Member Joined: Nov 2005 Posts: 5 | Just like to add that 46 is an easy restore since all major componets are excellent and there. Son is the welder and blackmails me that he will only do it his way. 45 has all the data plates. Was told to put 235 in with S10 5sp tranny and Nova rear end, and to keep original front end. Any opinions. Also told to put dual carbs on 235 and dual exhaust. Why should I not use the 4.3 chev that was for my flat fender jeep? | | | | | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | AFAIK, there were no 1/2 ton civilian model trucks built in the 1944 production year.
They didn't build any in the 1943 production year, either.
They built 23703 in the 1942 production year, and they built 6202 in the 1945 production year, so perhaps it is one from those years, or a military contract order that was indeed a '44.
What's the VIN? We could probably tell you right quick what year it is.
If it really is a '44, then I'm with the Restoration guys. If it's not, then I say go for whatever makes you happiest. Personally, I'd keep it looking stock on the outside, but maybe do some upgrades. | | | | | Joined: Apr 2005 Posts: 313 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 313 | I HOPE THAT YOU CHOOSE TO RESTORE THE FORTY-FOUR! However, it is your baby, and you can do whatever you want to do to it. | | | | | Joined: Oct 2005 Posts: 15 Junior Member | | Junior Member Joined: Oct 2005 Posts: 15 |
You never really learn to swear until you learn to drive.
| | | | | Joined: Dec 2000 Posts: 163 'Bolter | | 'Bolter Joined: Dec 2000 Posts: 163 | Rod or restore,it's no ones choice but yours! Build it the way that you want! | | | | | Joined: Sep 2003 Posts: 324 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 324 | Ryan, Did you feel the cross hairs on your back? Or was it the red dot on your forhead? | | | | | Joined: Dec 2002 Posts: 3,441 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,441 | I wonder what became of Smokeys truck... the Camp Pendleton mobility museum has a 41-46 military pickup... it has the flat fenders ect on it.. but the cab looks the same as a civvy truck.
| | | | | Joined: Nov 2004 Posts: 2,409 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,409 | I am in favor of restoration, as it is a rare find. But like some of the others have said, it is your truck, and you should be able to do what you want. I also agree that there is a lot of iron out there that is very rod worthy. If you want to build a rod, there are many that have been started, but not completed. I only suggest that you really think it through before you start chopping it up. That is the easy part. If it will be your first rod, here are a few things to consider. Do you have the garage space available that you won't need for an extended period? It could take a couple years, unless you have a lot of extra time. Do you have a plan of what you would want to do to it? Have you figured in all of the cost's that you will incur? Do you have the patience to stay with it all the way to the finish? It would be a shame,if after all the disassembly and chopping that you would lose interest and it would end up being another butchered project to be sold (usually at a loss). On the otherhand, a mild restoration can be carried out in phases. Can be done rather cheaply. And for a lot of peple, it can be a very rewarding hobby. You would work on it when you have the time, and extra money. If it were made somewhat road worthy first, it could be moved around, so you would still be able to use the space for other things if needed. If it was mine, I would try to keep it mostly original, or sell it to someone to restore, and buy a project that someone had given up on, to build a rod. Whichever you decide, good luck. Now how about some photo's.
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Nov 1995 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 1995 Posts: 1,159 | You all might get a kick out of this old, old page from the site. I had just come across it during the week as we are trying to update the old pages. It's not even dated and I'm not sure if the links work. But was a pretty good piece on rod / not rod / and a good "middle of the road." Also ... gives you another glance of our old stuff. Peg
~ One of many.
| | | | | Joined: Feb 2005 Posts: 355 Member | | Member Joined: Feb 2005 Posts: 355 | If your truck really is a '44, I vote to restore it, if your skills, pocketbook, and patience is up to it. If not, I recommend a solid rebuild until such a time as it is ready for a restoration. Rebuilding a truck is a terrific way to learn about your truck, enjoy it, and yet preserve the truck as a rare piece of history.
Tom Brownell's book, "How to Restore Your Chevrolet Pickup" has a great section on the rod/rebuild/restore debate.
Personally, I don't see a darn thing wrong with rodding a vehicle and none of my own have been restored. However, the war-year trucks are special and I would treat them differently than the more common trucks.
Most importantly, do what is going to make you happy! It is your truck. | | | | | Joined: Jan 2005 Posts: 394 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 394 | make it a driver that you will enjoy. the way you want it to look is all up to you. if its a solid old truck i would try to keep it that way. fix,drive,enjoy...mike j | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | My two prides and joy are 1946 trucks and both have lived their lives as farm trucks.. and that's the way they'll stay.
There will undoubetebly come a day with the 216 in the 1/2 ton will give up the ghost, and I doubt i'll put a 216 back in it.. probably a 261 with a updated rear and 5 speed tranny.
Not sure if that's what you'd call a rod or a restore, but for me it's all about function before fashion.
A '44 truck would be a rare bird.. i'd probably sell it and use the proceeds to buy a '41 or '46 thats a little closer to what you're looking for.
But in the end, it's your truck.. do to it what you need to do so it'll do what you need it to do.
| | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | True.. but somebody else with a simular situation might come along and find the information usefull.
| | | | | Joined: Jan 2005 Posts: 305 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 305 | im in the same delima i have a 42 1/2 ton
ya I know a few rednecks.Thay all drive chevys to, Proud member of the Old Dominion Stovebolt Society AND A MARINE trucks range from 1942 1/2 ton to 1965 fire engine
| | | | | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | Mine is a no problem answer, 1955 first series GMC that is a 74,000 mile original not restored. Just a good cleanup, even buffed the stock 50 yr. old paint and it shines. I have had over 40 vehicles and always rodded everything but this one is too good to do anything but drive! The problem is yours but with such a rare find, if it is in fair shape either restore it or sell it to someone that will and buy what you want. My $.02 | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | As an old fart that was actually around in 44 I remember several things that may clarify the scene. All 43 and 44 models were actually 42's because the automakers had converted to war production. GM was a tank builder, Ford built the B-24 bomber, Kaiser ships, and Packard the PT boat engines. Of course they produced many other items also. One of the few civilians that could purchase a new truck was a veterinarian because production of meat was a vital war effort and a rampant disease among livestock could not be allowed. These few trucks going into civilian hands were registered as the current year even though they were 42 models. Remember this is coming from an "elderly" brain and maybe some others can fill in the gaps. Evan
Evan
