4 members (Charles in CA, Shade Baby, Hotrod Lincoln, 46 Texaco), 119 guests, and 3 robots.
Topics128,162
Posts1,056,913
Members48,458
#146873 05/17/2006 1:55 AM
V
V Offline
I've been looking in local junkyards for big bolt trucks without any luck. Do you all find that you have the same problem?
I figured if I could find a donor truck it would be easier to finish off my firetruck. Anyone else share this parts problem? What did you do? I've tried the popular parts catalogs from many venders without luck. Advise?
#146874 05/17/2006 2:14 AM
I've always bought a parts truck.For this truck I've had a few.It's always cheaper then buying seperate pieces at a junkyard.For the rest of what I need I use Jim Carter's or Ebay.
#146875 05/17/2006 2:21 AM
V
V Offline
I've found it impossible around here to find a 2 ton donor. I found one but somebody had already purchased it.
#146876 05/17/2006 3:01 AM
I have several in my backyard "junkyard". I found most of them at farm auctions. Spotted others while out motorcycling and stopped and asked. Haven't been shot at yet. grin
#146877 05/17/2006 3:09 AM
Looking for something in particular?
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#146878 05/17/2006 3:44 AM
At my local junkyard theres tons of big bolts. A lot of the parts fit smaller trucks it's a good place to scrunge.
38 original
48 panel
59 stepside
46 in the back forty
#146879 05/17/2006 3:50 AM
I
I Offline
One of the best places to find a big truck is the place they were built for. Farms around the country still have alot of bolts sitting around. Some of them are still in service. Your out on the east coast, there must be some older truck crop/potato farms out there with one sitting in the fence row.
Jeff
1947 Chevy 6400 2-ton
1953 3/4-ton
It was fun while it lasted
#146880 05/17/2006 5:21 AM
Quite a few of them left down here in North Carolina. Yes it is always wise, to have at least one parts truck. I've got several of them.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
#146881 05/17/2006 5:25 AM
I've seen a fair number of big bolts in wrecking yards, but I think all of them were in yards that cater to older cars and trucks in the first place.
You might need to look around for a speciality yard to find what you are needing.
#146882 05/17/2006 11:34 AM
V
V Offline
Thanks. Your advise seems to reflect what I've discovered. Around here, the farm lands have mostly gone to new houses and the junkyards are now filled with crashed cars. However only a few miles out is lots of farmland. I'll take a little drive to the western part of the state and look around.
I'll let you know what I find.
I need one bolt at the moment but I figure it would be nice to have a parts truck in case something breaks in the future. The bolt is 4.25 inch in lenght and it is the longer of the four bolts on the brake mount plate. And it is the one with the steering arm attached. Any help would be greatly appreciate. First person to contact me with a bolt and an address will get a check out to them today! I've looked in all the parts catalogs without success but nobody seems to stock it for a big bolt.
Here is a picture of it:
http://www.iaffl2924.com/brakewheelbolt.jpg
#146883 05/17/2006 12:56 PM
From your picture it looks like a standard SAE stud not a bolt.Try a parts store for a grade 8 exhaust manifold stud.
Wanted Good Woman:
Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
#146884 05/17/2006 5:01 PM
a replacement piece can be made with rod and 2 nuts. drop by a friendly machine shop
#146885 05/17/2006 7:04 PM
V
V Offline
Thanks. I'd really like to have an original bolt just to be safe.
Also, I'd still like to have a parts truck for future use. I'm going to take a drive in the next day or so to see what I can find a few miles outside Virginia Beach. Thanks for the advise.
#146886 05/18/2006 12:20 AM
I thought I had one for you but it looks like mine is a hair more then 1/4" shorter then yours.On the short side mines 7/8" and on the long side it's 2 5/8". Total length is 4 1/8". Diameter is 1/2" I think,it took 3/4" nuts
#146887 05/18/2006 2:09 AM
V
V Offline
It is about 4.25" in lenght. The one you have might be the top bolt. There are four bolts on the plate. The top two are about 3.75" in lenght and the bottom two are 4.25". The bottom ones are longer because the steering linkage attaches at that point to the back side of the front wheel supports.
I'll keep looking as I can't put the left front wheel back on until I find one that matches. I'm headed out to Suffolk Virginia in the morning to search a few junkyards. Wish me luck!
#146888 05/18/2006 3:05 AM
Mines a bottom,it's just out of a much older truck.Good luck
#146889 05/18/2006 2:02 PM
V
V Offline
I'm looking for a 1948-53 bolt... I'll keep looking!
#146890 05/18/2006 9:49 PM
I have a 1 1/2 ton dually flatbed. Will it work?
http://www.stovebolt.com/gallery/vandenberg_steve_1951.html
#146891 05/18/2006 10:13 PM
Riding in the Passing Lane
Check your local heavy equipment dealer. They carry a good selection of grade 8 hardware in large sizes.
1972 Chevy c10 Cheyenne Super
#146892 05/18/2006 11:03 PM
V
V Offline
As somebody suggested: I visited a local machine shop and they made the bolt for me. I pick it up on Friday afternoon! I'm back in business!!
Thanks to everyone who offered advise. I know you folks are the best!
#146893 05/19/2006 2:12 AM
I
I Offline
highwayman
If you're out an about at your local junkyard can you look for rear fenders for a 39-46 1 ton? The kind that go on a 9' pickup box.
#146894 05/19/2006 12:57 PM
Va fire truck there are 2 ad trucks sitting at the courtland va salvage yard on 58. one is a 54/55 1st series the other is a 47/53 ad. I've been going to stop as i could use a good 54 cab but haven't gotten to it.
#146895 05/19/2006 1:05 PM
Courtland would be about an hour west of Va beach
#146896 05/19/2006 4:20 PM
I saw those two trucks, looked pretty decent from the highway.
Spanky Hardy
1950 GMC 250 1-Ton
#146897 05/19/2006 9:06 PM
V
V Offline
I know where that is. I'll take a drive out to Courtland ASAP! Thanks.
#146898 05/19/2006 9:50 PM
i decided to let my fingers do the walking and called the yard. owner said 1 was drivable the other was being restored when the gentleman passed away. He wants to sell them as a pair. I thought his price to much for my budget perhaps in person you can get him to bargain a little or seperate them. they do look good from the road.
#146899 05/25/2006 3:12 PM
Quote
I typically find quite a few at autions.
Try I find this to be a good farm auction site page
Tempest
"Find Your Inner Truck"
Silly Boys! - Trucks are for Girls!
1945 2-ton
1946 3/4-ton
1951 Chevy 2-Ton
Redliners Auto Club
What\'z It
Snow Cruisers
#146900 05/26/2006 1:56 AM
I stopped in at our local junkyard today and was going to inquire how much they wanted for a 47-53 Chev Big Bolt grille that I had seen there. The grille was in perfect shape not a dent on it. wasn't chrome it was painted but today when a walked to the back to go find it I got a little surprise it was trashed. I guess they used the loader to push the truck around and they wrecked the whole front end of the truck. That's to bad
38 original
48 panel
59 stepside
#146901 05/28/2006 12:25 AM
V
V Offline
I drove out to Courtland this afternoon only to find the junkyard closed at 1 PM. I did look at both the trucks and they are both in really great shape. I'm not willing to take trucks in that great shape apart just for parts. I could see where the 1953 was being restored before its owner died.
I have been told by several local junkyard owners, they have crushed the older trucks because the price of steel has risen in recent years...
#146902 05/28/2006 2:56 PM
Don't feel bad about taking it apart, cause it will get crushed with steel at today's prices. At the risk of taking a pummeling, they fact is that not all of these trucks will find a home and leaving a truck alone that can help you finish yours is a good deed that will not go unpunished by the uncaring yard owner when the crusher comes.
#146903 05/28/2006 4:15 PM
Something to think about is that most junkyards have a "hot line" that they get on to find parts that they themselves don't have. If you can make "friends" with someone at the junkyard they can get on the hot line and ask if anyone within a reasonable driving distance has your year model that your looking for. You may be surprised at how many can be found this way. Then get a roll back or trailer and go get it before they are truly all gone....and in most cases you are then able to help some other bolter and even re-coup some of your investment.
#146904 05/28/2006 11:00 PM
V
V Offline
I'll give the hotline a try.
As for the Courtland trucks, they seem to be high priced enough that the yard might not be willing to crush them. I'm going to try to get out there this week (when it is open) to see if I can get a cheaper price.
#146905 05/29/2006 12:25 PM
possibly he will have some others in back if he won't talk reasonable or seperate the pair. I would think if you point out how the cab parts do not match perhaps he'll decide to move them as they've been setting there for quite some time. The open cab I sent you an email on quite a while ago is gone now. Good luck.
#146906 06/07/2006 2:12 AM
I am a little farther away but there is a mostly complete 48 in my buddys junk yard.
#146907 06/10/2006 8:55 PM
I find most of the junkyard stuff now days is rusty bad and shot up, and the same parts you need are also bad on them. These trucks always need the same areas fixed. PLus, windows out and dash all wrecked because of that, engines stuck, the good tires are taken off with a torch even. The ones in private yards or farms might be better. Auctions and ebay for running ones! Check all the for sale books and web sites, etc. I have found Bow Tie Bits to be better source for big used parts. He's down South somewhere I believe. Best to call him, he hates Web, but has a site.
G.L. Grumpy's
Old Iron Ranch
Huntington, IN 46750
MM R tractor, Speedex
and Power King tractors
#146908 06/11/2006 11:18 PM
V
V Offline
GLPerry: I think you are correct about yards & farms. I drove to NYC this week (Yankee's Baseball games) up the Eastern Shore of Va, MD and Maryland. I saw a few old trucks in the back yards and fields along the way. I might stop on my way home to ask about them.
#146909 06/12/2006 3:35 AM
Junior Member
Junior Member
1 Offline
BowTie Bits is in Wichita, Kansas his number is 316-941-9331 he can find about any part.
My 1959 Chevy Apache Stepside
One just isn't enough
#146910 06/19/2006 7:14 PM
I live in mass. and finding it extremely hard finding parts for my 66 C50 wrecker. I need both front fenders and you are right the same parts are rusted out on all of them here in the rust belt.(salt- rain-humidity )I live in the conn. valley that has always been farm land. but everything in the fields have the same problem. I would be interested if anybody knows of some good ones. either in driving distance or possibly shipping.
