1 members (Hotrod Lincoln),
130
2
Mod | | | Forums66 Topics128,143 Posts1,056,494 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 11,078 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,078 | If you have stock tie-rod ends, I would follow the shop manual, which does say back them off a little. If the spring is fully compressed, then the spools (for lack of a better term) will be contacting the cups around the balls and if the balls are not completely spherical, then things will bind up as you turn the wheels. The springs are there to allow a little movement, but keep the cups in contact with the balls.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | |
Entire Thread
Steering Wheel Slop, where do I start
| JoeDude | 11/16/2023 4:24 PM |
Re: Steering Wheel Slop, where do I start
| WICruiser | 11/16/2023 8:52 PM |
| Wrenchbender Ret. | 11/16/2023 9:08 PM |
| JoeDude | 12/02/2023 10:44 PM |
| Otto Skorzeny | 11/16/2023 11:07 PM |
| Guitplayer | 11/17/2023 11:57 AM |
| JoeDude | 11/17/2023 5:36 PM |
| hcb3200 | 11/20/2023 8:02 PM |
| MNSmith | 11/17/2023 6:04 PM |
| Guitplayer | 11/17/2023 7:17 PM |
| Fibonachu | 11/17/2023 7:30 PM |
| Hanks custodian | 11/17/2023 7:33 PM |
| 52Carl | 11/21/2023 1:41 AM |
Re: Joe dudes issue.
| Guitplayer | 11/26/2023 3:38 PM |
| 1Ton_tommy | 12/01/2023 8:47 PM |
| Hotrod Lincoln | 12/01/2023 9:25 PM |
| klhansen | 12/01/2023 11:58 PM |
| Hanks custodian | 12/02/2023 3:08 AM |
| Phak1 | 12/02/2023 3:18 AM |
| klhansen | 12/02/2023 3:56 AM |
| Hotrod Lincoln | 12/02/2023 5:37 AM |
| Phak1 | 12/02/2023 1:24 PM |
| Otto Skorzeny | 12/02/2023 11:55 PM |
| Fibonachu | 12/03/2023 12:59 AM |
| 1Ton_tommy | 12/05/2023 6:19 PM |
| Jon G | 12/05/2023 10:35 PM |
| Jon G | 12/05/2023 11:43 PM |
| JoeDude | 12/06/2023 12:14 AM |
| Jon G | 12/06/2023 12:38 AM |
| JoeDude | 12/07/2023 5:48 PM |
| Jon G | 12/06/2023 1:41 AM |
| Mike B | 12/06/2023 1:58 AM |
| klhansen | 12/06/2023 2:21 AM |
| JoeDude | 12/06/2023 5:59 PM |
| klhansen | 12/06/2023 8:53 PM |
| JoeDude | 12/06/2023 9:03 PM |
| Mike B | 12/07/2023 3:35 AM |
| JW51 | 12/07/2023 6:16 PM |
| klhansen | 12/07/2023 7:59 PM |
| Jon G | 12/07/2023 8:19 PM |
| Jon G | 12/07/2023 8:39 PM |
| JoeDude | 12/08/2023 2:50 AM |
| Jon G | 12/08/2023 2:59 AM |
| 1Ton_tommy | 12/08/2023 6:20 PM | |
