2 members (2-Ton, Bill Hanlon),
82
3
Mod | | | Forums66 Topics128,142 Posts1,056,485 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2014 Posts: 892 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 892 | These GM steering boxes are the recirculating ball type. They use a lighter weight grease than some others such as cam-and-lever. Make sure you sue the specified grease. As I recall cornhead grease comes in several viscosities; the heavier ones not only won't run out of the box through leaking seals, they won't lube the balls in the recirculating mechanism. 1951 3800 1-ton"Earning its keep from the get-go"In the DITY Gallery1962 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971. | | | |
Entire Thread
Steering Wheel Slop, where do I start
| JoeDude | 11/16/2023 4:24 PM |
Re: Steering Wheel Slop, where do I start
| WICruiser | 11/16/2023 8:52 PM |
| Wrenchbender Ret. | 11/16/2023 9:08 PM |
| JoeDude | 12/02/2023 10:44 PM |
| Otto Skorzeny | 11/16/2023 11:07 PM |
| Guitplayer | 11/17/2023 11:57 AM |
| JoeDude | 11/17/2023 5:36 PM |
| hcb3200 | 11/20/2023 8:02 PM |
| MNSmith | 11/17/2023 6:04 PM |
| Guitplayer | 11/17/2023 7:17 PM |
| Fibonachu | 11/17/2023 7:30 PM |
| Hanks custodian | 11/17/2023 7:33 PM |
| 52Carl | 11/21/2023 1:41 AM |
Re: Joe dudes issue.
| Guitplayer | 11/26/2023 3:38 PM |
| 1Ton_tommy | 12/01/2023 8:47 PM |
| Hotrod Lincoln | 12/01/2023 9:25 PM |
| klhansen | 12/01/2023 11:58 PM |
| Hanks custodian | 12/02/2023 3:08 AM |
| Phak1 | 12/02/2023 3:18 AM |
| klhansen | 12/02/2023 3:56 AM |
| Hotrod Lincoln | 12/02/2023 5:37 AM |
| Phak1 | 12/02/2023 1:24 PM |
| Otto Skorzeny | 12/02/2023 11:55 PM |
| Fibonachu | 12/03/2023 12:59 AM |
| 1Ton_tommy | 12/05/2023 6:19 PM |
| Jon G | 12/05/2023 10:35 PM |
| Jon G | 12/05/2023 11:43 PM |
| JoeDude | 12/06/2023 12:14 AM |
| Jon G | 12/06/2023 12:38 AM |
| JoeDude | 12/07/2023 5:48 PM |
| Jon G | 12/06/2023 1:41 AM |
| Mike B | 12/06/2023 1:58 AM |
| klhansen | 12/06/2023 2:21 AM |
| JoeDude | 12/06/2023 5:59 PM |
| klhansen | 12/06/2023 8:53 PM |
| JoeDude | 12/06/2023 9:03 PM |
| Mike B | 12/07/2023 3:35 AM |
| JW51 | 12/07/2023 6:16 PM |
| klhansen | 12/07/2023 7:59 PM |
| Jon G | 12/07/2023 8:19 PM |
| Jon G | 12/07/2023 8:39 PM |
| JoeDude | 12/08/2023 2:50 AM |
| Jon G | 12/08/2023 2:59 AM |
| 1Ton_tommy | 12/08/2023 6:20 PM | |
