7 members (RdsLessTaken, TUTS 59, Jay R, Otto Skorzeny, 68ironhead, Phak1, 1 invisible),
99
3
Mod | | | Forums66 Topics128,136 Posts1,056,428 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2020 Posts: 451 'Bolter | | 'Bolter Joined: Sep 2020 Posts: 451 | Steering box adjust is certainly the starting place since it is a no cost adjustment. Adjusting is done with pitman arm disconnected at one end or the other, personally I prefer to undo the drag link so you can visually monitor the play for the steering box before the pitman arm starts to rotate. An good tool for setting the tension on the steering box is a trigger pull scale, cheap, available at most sporting/hunting stores, and designed for use in the 2-5 lb range… You should then inspect the various rod ends on steering linkages before driving, they wear loose, also a relatively inexpensive repair….takes time but parts are relatively cheap. Steering and brakes….pretty important….not a place to compromise.
Chuck
Hank: 46 Chev 1/2ton shortbed 2023 Miata RF Club | | | |
Entire Thread
Steering Wheel Slop, where do I start
| JoeDude | 11/16/2023 4:24 PM |
Re: Steering Wheel Slop, where do I start
| WICruiser | 11/16/2023 8:52 PM |
| Wrenchbender Ret. | 11/16/2023 9:08 PM |
| JoeDude | 12/02/2023 10:44 PM |
| Otto Skorzeny | 11/16/2023 11:07 PM |
| Guitplayer | 11/17/2023 11:57 AM |
| JoeDude | 11/17/2023 5:36 PM |
| hcb3200 | 11/20/2023 8:02 PM |
| MNSmith | 11/17/2023 6:04 PM |
| Guitplayer | 11/17/2023 7:17 PM |
| Fibonachu | 11/17/2023 7:30 PM |
| Hanks custodian | 11/17/2023 7:33 PM |
| 52Carl | 11/21/2023 1:41 AM |
Re: Joe dudes issue.
| Guitplayer | 11/26/2023 3:38 PM |
| 1Ton_tommy | 12/01/2023 8:47 PM |
| Hotrod Lincoln | 12/01/2023 9:25 PM |
| klhansen | 12/01/2023 11:58 PM |
| Hanks custodian | 12/02/2023 3:08 AM |
| Phak1 | 12/02/2023 3:18 AM |
| klhansen | 12/02/2023 3:56 AM |
| Hotrod Lincoln | 12/02/2023 5:37 AM |
| Phak1 | 12/02/2023 1:24 PM |
| Otto Skorzeny | 12/02/2023 11:55 PM |
| Fibonachu | 12/03/2023 12:59 AM |
| 1Ton_tommy | 12/05/2023 6:19 PM |
| Jon G | 12/05/2023 10:35 PM |
| Jon G | 12/05/2023 11:43 PM |
| JoeDude | 12/06/2023 12:14 AM |
| Jon G | 12/06/2023 12:38 AM |
| JoeDude | 12/07/2023 5:48 PM |
| Jon G | 12/06/2023 1:41 AM |
| Mike B | 12/06/2023 1:58 AM |
| klhansen | 12/06/2023 2:21 AM |
| JoeDude | 12/06/2023 5:59 PM |
| klhansen | 12/06/2023 8:53 PM |
| JoeDude | 12/06/2023 9:03 PM |
| Mike B | 12/07/2023 3:35 AM |
| JW51 | 12/07/2023 6:16 PM |
| klhansen | 12/07/2023 7:59 PM |
| Jon G | 12/07/2023 8:19 PM |
| Jon G | 12/07/2023 8:39 PM |
| JoeDude | 12/08/2023 2:50 AM |
| Jon G | 12/08/2023 2:59 AM |
| 1Ton_tommy | 12/08/2023 6:20 PM | |
