2 members (GMCJammer51, RLB),
148
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,285 Posts1,058,278 Members48,483 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 11,262 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,262 | Oddly, the face of it is not flat- it is cone-shaped……..the inner segment of the flywheel surface is “higher” than the outer segment. It is significant- laying a machinists square on the section where the clutch disc sits reveals that the flywheel surface “cones” upwards towards the center of the flywheel. I’m bringing it back to the machinist tomorrow. Cone shaped flywheel surfaceThat could be correct. When I had a flywheel resurfaced for my diesel truck, they asked if it was supposed to be flat or tapered (cone shaped). I had checked the specs and on that particular setup the flywheel surface is completely flat. A cone shaped flywheel would make the disk engage first in the center (on yours), and then compress against the outer edges of the flywheel. That may be done for a smoother engagement. But I have no idea what the proper specs (flat or coned) would be for your truck. The machinist (if he's worth his salt) should know the proper setup.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | |
Entire Thread
Issues with T5 swap- vibrations, etc...
| Norcal Dave | 04/07/2023 2:35 PM |
Re: Issues with T5 swap- vibrations, etc...
| EchoBravoSierra | 04/07/2023 2:53 PM |
| Norcal Dave | 04/07/2023 3:08 PM |
| Lugnutz | 04/07/2023 4:02 PM |
| BC59 | 04/07/2023 7:37 PM |
| Norcal Dave | 04/07/2023 10:21 PM |
| Jon G | 04/08/2023 12:37 AM |
| Norcal Dave | 04/08/2023 12:45 AM |
| BC59 | 04/08/2023 2:09 AM |
| Norcal Dave | 04/08/2023 4:32 AM |
| Joe H | 04/08/2023 1:10 PM |
| Lugnutz | 04/08/2023 1:45 PM |
| Jon G | 04/08/2023 2:53 PM |
| BC59 | 04/08/2023 3:29 PM |
| NorthCoast3800 | 04/08/2023 3:42 PM |
| Jon G | 04/08/2023 5:11 PM |
| 52Carl | 04/08/2023 9:14 PM |
| Norcal Dave | 04/09/2023 1:17 AM |
| EdPruss | 04/09/2023 3:42 AM |
| Lugnutz | 04/09/2023 3:49 AM |
| EdPruss | 04/09/2023 11:54 AM |
| DaveV | 04/09/2023 12:32 PM |
| Norcal Dave | 04/09/2023 1:41 PM |
| Lugnutz | 04/09/2023 2:34 PM |
| BC59 | 04/09/2023 7:42 PM |
| Norcal Dave | 04/09/2023 9:11 PM |
| Jon G | 04/09/2023 9:24 PM |
| Norcal Dave | 04/11/2023 4:22 AM |
| Joe H | 04/10/2023 12:25 AM |
| Norcal Dave | 04/11/2023 4:23 AM |
| Norcal Dave | 05/02/2023 4:59 AM |
| Joe H | 05/02/2023 12:43 PM |
| NorthCoast3800 | 05/02/2023 10:44 PM |
| Norcal Dave | 05/02/2023 11:57 PM |
| NorthCoast3800 | 05/03/2023 5:58 PM |
| klhansen | 05/03/2023 8:03 PM |
| Lugnutz | 05/03/2023 6:39 PM |
| Norcal Dave | 05/04/2023 4:56 AM |
| NorthCoast3800 | 05/04/2023 7:54 PM |
| EdPruss | 05/04/2023 10:43 AM |
| Norcal Dave | 05/05/2023 3:10 AM |
| Norcal Dave | 05/06/2023 6:23 PM |
| Norcal Dave | 05/21/2023 11:41 AM |
| WICruiser | 05/21/2023 11:47 AM |
| NorthCoast3800 | 05/21/2023 4:29 PM | |
