| | | Forums66 Topics128,118 Posts1,056,305 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2014 Posts: 4,500 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,500 | I’ve mentioned this before but in AD trucks the front cab mount pads are usually a noise problem. The old ones are flattened letting the cab rest on the frame. The replacement pads are made from the wrong rubber and consequently go flat rapidly allowing the same problem. Solution is to get pvc shower liner material and a small can of the special adhesive used with it. Cut replacement pieces and cut hole for bolt and glue/laminate until you get the right height to keep the cab at least one eighth inch off the frame. This is the best answer I’ve found and will reduce transmitted noise quite a bit…and I ought to add that noise transmitted at the front of the cab can be horrible.
As for the T5 you can run without a rear mount just fine.
Entire Thread
Issues with T5 swap- vibrations, etc...
| Norcal Dave | 04/07/2023 2:35 PM |
Re: Issues with T5 swap- vibrations, etc...
| EchoBravoSierra | 04/07/2023 2:53 PM |
| Norcal Dave | 04/07/2023 3:08 PM |
| Lugnutz | 04/07/2023 4:02 PM |
| BC59 | 04/07/2023 7:37 PM |
| Norcal Dave | 04/07/2023 10:21 PM |
| Jon G | 04/08/2023 12:37 AM |
| Norcal Dave | 04/08/2023 12:45 AM |
| BC59 | 04/08/2023 2:09 AM |
| Norcal Dave | 04/08/2023 4:32 AM |
| Joe H | 04/08/2023 1:10 PM |
| Lugnutz | 04/08/2023 1:45 PM |
| Jon G | 04/08/2023 2:53 PM |
| BC59 | 04/08/2023 3:29 PM |
| NorthCoast3800 | 04/08/2023 3:42 PM |
| Jon G | 04/08/2023 5:11 PM |
| 52Carl | 04/08/2023 9:14 PM |
| Norcal Dave | 04/09/2023 1:17 AM |
| EdPruss | 04/09/2023 3:42 AM |
| Lugnutz | 04/09/2023 3:49 AM |
| EdPruss | 04/09/2023 11:54 AM |
| DaveV | 04/09/2023 12:32 PM |
| Norcal Dave | 04/09/2023 1:41 PM |
| Lugnutz | 04/09/2023 2:34 PM |
| BC59 | 04/09/2023 7:42 PM |
| Norcal Dave | 04/09/2023 9:11 PM |
| Jon G | 04/09/2023 9:24 PM |
| Norcal Dave | 04/11/2023 4:22 AM |
| Joe H | 04/10/2023 12:25 AM |
| Norcal Dave | 04/11/2023 4:23 AM |
| Norcal Dave | 05/02/2023 4:59 AM |
| Joe H | 05/02/2023 12:43 PM |
| NorthCoast3800 | 05/02/2023 10:44 PM |
| Norcal Dave | 05/02/2023 11:57 PM |
| NorthCoast3800 | 05/03/2023 5:58 PM |
| klhansen | 05/03/2023 8:03 PM |
| Lugnutz | 05/03/2023 6:39 PM |
| Norcal Dave | 05/04/2023 4:56 AM |
| NorthCoast3800 | 05/04/2023 7:54 PM |
| EdPruss | 05/04/2023 10:43 AM |
| Norcal Dave | 05/05/2023 3:10 AM |
| Norcal Dave | 05/06/2023 6:23 PM |
| Norcal Dave | 05/21/2023 11:41 AM |
| WICruiser | 05/21/2023 11:47 AM |
| NorthCoast3800 | 05/21/2023 4:29 PM | |
