1 members (Ole49GMC),
109
0
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2016 Posts: 916 'Bolter | | 'Bolter Joined: Oct 2016 Posts: 916 | Thanks for responding lugnutz- I’m going to read your DIY write-up on checking the bellhousing and check my pilot bushing ID.
I was told by a hotrod shop to add another 2 degrees down to my pinion angle, so that when the truck accelerated the pinion would come up and be at the right angle. I spent a lot of time measuring the angles of the pinion and the trans yoke before welding on the perches….they gave me some really bad advice!! I’m not drag racing… I should have just set it up like you said- equal angles (parallel). I need to find someone who can make me some shims that won’t break the bank!
I should have thought about that a little more before welding on my spring perches. I can fix the angle with axle/leaf spring shims. I still think the tail housing bushing is worn though.
I have to stick with my adapter plate, otherwise I’m going to have to $pend again to build a longer driveshaft. Custom driveshafts have gotten really expensive (like everything else).
BC59-
I’ve got brand new u-joints, and checked this early on- u-joints checked out okay.
~ Dave 1950 Chevrolet 3600 3/4-ton with 261 engine & T5 Transmission | | | |
Entire Thread
Issues with T5 swap- vibrations, etc...
| Norcal Dave | 04/07/2023 2:35 PM |
Re: Issues with T5 swap- vibrations, etc...
| EchoBravoSierra | 04/07/2023 2:53 PM |
| Norcal Dave | 04/07/2023 3:08 PM |
| Lugnutz | 04/07/2023 4:02 PM |
| BC59 | 04/07/2023 7:37 PM |
| Norcal Dave | 04/07/2023 10:21 PM |
| Jon G | 04/08/2023 12:37 AM |
| Norcal Dave | 04/08/2023 12:45 AM |
| BC59 | 04/08/2023 2:09 AM |
| Norcal Dave | 04/08/2023 4:32 AM |
| Joe H | 04/08/2023 1:10 PM |
| Lugnutz | 04/08/2023 1:45 PM |
| Jon G | 04/08/2023 2:53 PM |
| BC59 | 04/08/2023 3:29 PM |
| NorthCoast3800 | 04/08/2023 3:42 PM |
| Jon G | 04/08/2023 5:11 PM |
| 52Carl | 04/08/2023 9:14 PM |
| Norcal Dave | 04/09/2023 1:17 AM |
| EdPruss | 04/09/2023 3:42 AM |
| Lugnutz | 04/09/2023 3:49 AM |
| EdPruss | 04/09/2023 11:54 AM |
| DaveV | 04/09/2023 12:32 PM |
| Norcal Dave | 04/09/2023 1:41 PM |
| Lugnutz | 04/09/2023 2:34 PM |
| BC59 | 04/09/2023 7:42 PM |
| Norcal Dave | 04/09/2023 9:11 PM |
| Jon G | 04/09/2023 9:24 PM |
| Norcal Dave | 04/11/2023 4:22 AM |
| Joe H | 04/10/2023 12:25 AM |
| Norcal Dave | 04/11/2023 4:23 AM |
| Norcal Dave | 05/02/2023 4:59 AM |
| Joe H | 05/02/2023 12:43 PM |
| NorthCoast3800 | 05/02/2023 10:44 PM |
| Norcal Dave | 05/02/2023 11:57 PM |
| NorthCoast3800 | 05/03/2023 5:58 PM |
| klhansen | 05/03/2023 8:03 PM |
| Lugnutz | 05/03/2023 6:39 PM |
| Norcal Dave | 05/04/2023 4:56 AM |
| NorthCoast3800 | 05/04/2023 7:54 PM |
| EdPruss | 05/04/2023 10:43 AM |
| Norcal Dave | 05/05/2023 3:10 AM |
| Norcal Dave | 05/06/2023 6:23 PM |
| Norcal Dave | 05/21/2023 11:41 AM |
| WICruiser | 05/21/2023 11:47 AM |
| NorthCoast3800 | 05/21/2023 4:29 PM | |
