| | | Forums66 Topics128,266 Posts1,058,140 Members48,482 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2015 Posts: 273 Shop Shark | | Shop Shark Joined: Feb 2015 Posts: 273 | Wouldn't have thought to try it unless you mentioned it. Glad you did.
Yeah, I edited that post a few minutes ago, after I realized that if the spacer I.D. is the size of the pilot (asked, not answered yet)then there is no material to turn a pilot from.
If available in the right thickness, and the I.D. is made to fit the pilot, then I may see if they can make me a set of male/female spacers in the right width. Even if they want double the asking price for the custom work, it will likely be cheaper than my local guy from scratch. I needed a transmission shaft years ago. Maybe 3" long, turned down to 1/2" at each end from about 3/4" thick and it was $80.00!
If I had access to the machine tools, I would definitely just make them.
Such is life,
Larry W.
1953 3800 Dually Flatbed
Entire Thread
14 bolt axle swap Considerations, Brainstorming, and Solutions
| Mrf1002u | 01/19/2016 5:54 AM |
14 bolt axle U-bolt saddle, Also clearance between backing plate & springs
| Grigg | 01/19/2016 7:15 PM |
Re: 14 bolt axle U-bolt saddle, Also clearance between backing plate & springs
| Mrf1002u | 01/21/2016 9:16 PM |
Re: 14 bolt saddle from a Ford - Post I can not find anymore !!!
| Mrf1002u | 01/19/2016 8:14 PM |
| Mrf1002u | 01/19/2016 9:32 PM |
| Grigg | 01/20/2016 1:03 AM |
| Mrf1002u | 01/21/2016 5:30 AM |
| Mrf1002u | 01/20/2016 2:02 AM |
| Mrf1002u | 01/20/2016 2:31 AM |
| Grigg | 01/20/2016 3:15 AM |
| Mrf1002u | 01/20/2016 4:39 AM |
| Grigg | 01/20/2016 5:50 AM |
| Mrf1002u | 01/20/2016 2:27 PM |
| Grigg | 01/20/2016 3:16 PM |
| Mrf1002u | 01/20/2016 3:58 PM |
| Blind1968 | 01/20/2016 4:14 PM |
| Mrf1002u | 01/20/2016 4:41 PM |
| Mrf1002u | 01/20/2016 4:46 PM |
| Mrf1002u | 01/20/2016 5:02 PM |
| Grigg | 01/20/2016 5:32 PM |
| Blind1968 | 01/20/2016 5:38 PM |
| Mrf1002u | 01/20/2016 5:55 PM |
| Mrf1002u | 01/20/2016 5:54 PM |
| Grigg | 01/20/2016 7:25 PM |
| Mrf1002u | 01/20/2016 7:49 PM |
| Mrf1002u | 01/20/2016 8:39 PM |
| Grigg | 01/20/2016 9:07 PM |
| Mrf1002u | 01/20/2016 9:40 PM |
| Mrf1002u | 01/20/2016 10:58 PM |
| Grigg | 01/20/2016 11:24 PM |
| Mrf1002u | 01/21/2016 1:05 AM |
| Mrf1002u | 01/21/2016 2:05 AM |
| Mrf1002u | 01/21/2016 10:15 PM |
| Grigg | 01/22/2016 5:11 AM |
| Mrf1002u | 01/22/2016 5:41 AM |
| Mrf1002u | 01/22/2016 6:04 AM |
| Grigg | 01/22/2016 5:43 AM |
| Mrf1002u | 01/22/2016 5:52 AM |
| Grigg | 01/22/2016 1:17 PM |
| Mrf1002u | 01/22/2016 4:13 PM |
| Grigg | 01/22/2016 4:58 PM |
| Mrf1002u | 01/22/2016 5:12 PM |
| Mrf1002u | 01/22/2016 5:15 PM |
| 69Cuda | 01/22/2016 5:25 PM |
| Mrf1002u | 01/22/2016 5:33 PM |
| Grigg | 01/22/2016 5:27 PM |
| Mrf1002u | 01/22/2016 7:22 PM |
| Grigg | 01/22/2016 10:26 PM |
| Mrf1002u | 01/22/2016 10:53 PM |
| Grigg | 01/23/2016 12:46 AM |
| Mrf1002u | 01/23/2016 12:59 AM |
| Grigg | 01/23/2016 12:59 AM |
| Mrf1002u | 01/23/2016 3:58 AM |
| Mrf1002u | 01/23/2016 1:39 AM |
| Grigg | 01/23/2016 2:24 AM |
| Mrf1002u | 01/23/2016 2:30 AM |
| Grigg | 01/23/2016 4:28 AM |
| Mrf1002u | 01/24/2016 2:28 AM |
| Mrf1002u | 01/24/2016 4:54 AM |
| Blind1968 | 01/25/2016 3:15 PM |
| Mrf1002u | 01/25/2016 3:33 PM |
| Mrf1002u | 01/25/2016 5:36 PM |
| Mrf1002u | 01/25/2016 3:45 PM |
| Grigg | 01/25/2016 3:46 PM |
| Mrf1002u | 01/25/2016 4:31 PM |
| Grigg | 01/25/2016 4:48 PM |
| Mrf1002u | 01/25/2016 5:04 PM |
| Blind1968 | 01/25/2016 5:39 PM |
| Mrf1002u | 01/25/2016 5:39 PM |
| Mrf1002u | 01/25/2016 5:47 PM |
| Mrf1002u | 01/25/2016 6:01 PM |
| Grigg | 01/25/2016 6:23 PM |
| Mrf1002u | 01/25/2016 10:58 PM |
| Blind1968 | 01/25/2016 6:30 PM |
| Blind1968 | 01/25/2016 11:08 PM |
| Mrf1002u | 01/26/2016 2:23 AM |
| Blind1968 | 01/26/2016 3:18 AM |
| Mrf1002u | 01/26/2016 6:22 PM |
| Mrf1002u | 01/26/2016 10:48 PM |
| Blind1968 | 01/27/2016 4:24 PM |
| Mrf1002u | 01/27/2016 7:31 PM |
| Mrf1002u | 01/28/2016 2:01 AM |
| Mrf1002u | 01/28/2016 5:03 AM |
| Grigg | 01/29/2016 9:20 PM |
| Mrf1002u | 01/29/2016 10:26 PM |
| Grigg | 01/29/2016 10:35 PM |
| Mrf1002u | 01/29/2016 11:07 PM |
| Grigg | 01/30/2016 12:25 AM |
| Mrf1002u | 01/30/2016 1:31 AM |
| Mrf1002u | 01/30/2016 1:39 AM |
| Grigg | 01/30/2016 2:17 AM |
| Mrf1002u | 01/30/2016 3:42 AM |
| Mrf1002u | 01/30/2016 3:37 PM |
| Grigg | 01/30/2016 4:14 PM |
| Mrf1002u | 01/30/2016 8:09 PM |
| Grigg | 01/31/2016 5:07 AM |
| Mrf1002u | 01/31/2016 5:46 AM |
| Grigg | 01/31/2016 3:18 PM |
| Mrf1002u | 01/31/2016 7:01 PM |
| Mrf1002u | 01/31/2016 7:37 PM |
| Grigg | 02/01/2016 12:31 AM |
| Mrf1002u | 02/01/2016 1:29 AM |
| Grigg | 02/01/2016 1:14 AM |
| Grigg | 02/01/2016 1:39 AM |
| Mrf1002u | 02/01/2016 1:56 AM |
| Grigg | 02/01/2016 4:24 PM |
| Mrf1002u | 02/01/2016 2:48 AM |
Re: 14 bolt axle swap Considerations, Brainstorming, and Solutions
| Mrf1002u | 02/01/2016 9:49 PM |
| Grigg | 01/05/2018 1:29 AM |
| Grigg | 01/07/2018 7:11 PM |
| VEW | 01/18/2018 4:34 PM | |
