| | | Forums66 Topics128,266 Posts1,058,140 Members48,482 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Wow, that's ridiculous. They must think you really need them...
We're not talking about much of a difference in axle tube diameter here. I just used a pair of calipers and carefully measured axle tube diameters. 14 bolt 3-3/8" Eaton 3-1/4"
The original GM saddles and the bolt hole spacing may just clear the 3-3/8" axle tube on the 14 bolt. I don't have or can't find a clean set to measure just yet. U-bolts are 5/8" so spacing needs to be 4" minimum up to perhaps 4-1/4" center to center.
This means with just 1/8" difference in diameter or 1/16" per side a little machine work could adapt the original saddles (for 2" wide springs) to the 14 bolt. Similarly you could scavenge 2" wide spring perches from an old Eaton housing.
Entire Thread
14 bolt axle swap Considerations, Brainstorming, and Solutions
| Mrf1002u | 01/19/2016 5:54 AM |
14 bolt axle U-bolt saddle, Also clearance between backing plate & springs
| Grigg | 01/19/2016 7:15 PM |
Re: 14 bolt axle U-bolt saddle, Also clearance between backing plate & springs
| Mrf1002u | 01/21/2016 9:16 PM |
Re: 14 bolt saddle from a Ford - Post I can not find anymore !!!
| Mrf1002u | 01/19/2016 8:14 PM |
| Mrf1002u | 01/19/2016 9:32 PM |
| Grigg | 01/20/2016 1:03 AM |
| Mrf1002u | 01/21/2016 5:30 AM |
| Mrf1002u | 01/20/2016 2:02 AM |
| Mrf1002u | 01/20/2016 2:31 AM |
| Grigg | 01/20/2016 3:15 AM |
| Mrf1002u | 01/20/2016 4:39 AM |
| Grigg | 01/20/2016 5:50 AM |
| Mrf1002u | 01/20/2016 2:27 PM |
| Grigg | 01/20/2016 3:16 PM |
| Mrf1002u | 01/20/2016 3:58 PM |
| Blind1968 | 01/20/2016 4:14 PM |
| Mrf1002u | 01/20/2016 4:41 PM |
| Mrf1002u | 01/20/2016 4:46 PM |
| Mrf1002u | 01/20/2016 5:02 PM |
| Grigg | 01/20/2016 5:32 PM |
| Blind1968 | 01/20/2016 5:38 PM |
| Mrf1002u | 01/20/2016 5:55 PM |
| Mrf1002u | 01/20/2016 5:54 PM |
| Grigg | 01/20/2016 7:25 PM |
| Mrf1002u | 01/20/2016 7:49 PM |
| Mrf1002u | 01/20/2016 8:39 PM |
| Grigg | 01/20/2016 9:07 PM |
| Mrf1002u | 01/20/2016 9:40 PM |
| Mrf1002u | 01/20/2016 10:58 PM |
| Grigg | 01/20/2016 11:24 PM |
| Mrf1002u | 01/21/2016 1:05 AM |
| Mrf1002u | 01/21/2016 2:05 AM |
| Mrf1002u | 01/21/2016 10:15 PM |
| Grigg | 01/22/2016 5:11 AM |
| Mrf1002u | 01/22/2016 5:41 AM |
| Mrf1002u | 01/22/2016 6:04 AM |
| Grigg | 01/22/2016 5:43 AM |
| Mrf1002u | 01/22/2016 5:52 AM |
| Grigg | 01/22/2016 1:17 PM |
| Mrf1002u | 01/22/2016 4:13 PM |
| Grigg | 01/22/2016 4:58 PM |
| Mrf1002u | 01/22/2016 5:12 PM |
| Mrf1002u | 01/22/2016 5:15 PM |
| 69Cuda | 01/22/2016 5:25 PM |
| Mrf1002u | 01/22/2016 5:33 PM |
| Grigg | 01/22/2016 5:27 PM |
| Mrf1002u | 01/22/2016 7:22 PM |
| Grigg | 01/22/2016 10:26 PM |
| Mrf1002u | 01/22/2016 10:53 PM |
| Grigg | 01/23/2016 12:46 AM |
| Mrf1002u | 01/23/2016 12:59 AM |
| Grigg | 01/23/2016 12:59 AM |
| Mrf1002u | 01/23/2016 3:58 AM |
| Mrf1002u | 01/23/2016 1:39 AM |
| Grigg | 01/23/2016 2:24 AM |
| Mrf1002u | 01/23/2016 2:30 AM |
| Grigg | 01/23/2016 4:28 AM |
| Mrf1002u | 01/24/2016 2:28 AM |
| Mrf1002u | 01/24/2016 4:54 AM |
| Blind1968 | 01/25/2016 3:15 PM |
| Mrf1002u | 01/25/2016 3:33 PM |
| Mrf1002u | 01/25/2016 5:36 PM |
| Mrf1002u | 01/25/2016 3:45 PM |
| Grigg | 01/25/2016 3:46 PM |
| Mrf1002u | 01/25/2016 4:31 PM |
| Grigg | 01/25/2016 4:48 PM |
| Mrf1002u | 01/25/2016 5:04 PM |
| Blind1968 | 01/25/2016 5:39 PM |
| Mrf1002u | 01/25/2016 5:39 PM |
| Mrf1002u | 01/25/2016 5:47 PM |
| Mrf1002u | 01/25/2016 6:01 PM |
| Grigg | 01/25/2016 6:23 PM |
| Mrf1002u | 01/25/2016 10:58 PM |
| Blind1968 | 01/25/2016 6:30 PM |
| Blind1968 | 01/25/2016 11:08 PM |
| Mrf1002u | 01/26/2016 2:23 AM |
| Blind1968 | 01/26/2016 3:18 AM |
| Mrf1002u | 01/26/2016 6:22 PM |
| Mrf1002u | 01/26/2016 10:48 PM |
| Blind1968 | 01/27/2016 4:24 PM |
| Mrf1002u | 01/27/2016 7:31 PM |
| Mrf1002u | 01/28/2016 2:01 AM |
| Mrf1002u | 01/28/2016 5:03 AM |
| Grigg | 01/29/2016 9:20 PM |
| Mrf1002u | 01/29/2016 10:26 PM |
| Grigg | 01/29/2016 10:35 PM |
| Mrf1002u | 01/29/2016 11:07 PM |
| Grigg | 01/30/2016 12:25 AM |
| Mrf1002u | 01/30/2016 1:31 AM |
| Mrf1002u | 01/30/2016 1:39 AM |
| Grigg | 01/30/2016 2:17 AM |
| Mrf1002u | 01/30/2016 3:42 AM |
| Mrf1002u | 01/30/2016 3:37 PM |
| Grigg | 01/30/2016 4:14 PM |
| Mrf1002u | 01/30/2016 8:09 PM |
| Grigg | 01/31/2016 5:07 AM |
| Mrf1002u | 01/31/2016 5:46 AM |
| Grigg | 01/31/2016 3:18 PM |
| Mrf1002u | 01/31/2016 7:01 PM |
| Mrf1002u | 01/31/2016 7:37 PM |
| Grigg | 02/01/2016 12:31 AM |
| Mrf1002u | 02/01/2016 1:29 AM |
| Grigg | 02/01/2016 1:14 AM |
| Grigg | 02/01/2016 1:39 AM |
| Mrf1002u | 02/01/2016 1:56 AM |
| Grigg | 02/01/2016 4:24 PM |
| Mrf1002u | 02/01/2016 2:48 AM |
Re: 14 bolt axle swap Considerations, Brainstorming, and Solutions
| Mrf1002u | 02/01/2016 9:49 PM |
| Grigg | 01/05/2018 1:29 AM |
| Grigg | 01/07/2018 7:11 PM |
| VEW | 01/18/2018 4:34 PM | |
