| | | Forums66 Topics128,266 Posts1,058,140 Members48,482 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2015 Posts: 273 Shop Shark | | Shop Shark Joined: Feb 2015 Posts: 273 | I suppose you could cut about 1/2" out of the center and weld it back together. The Ford ones should be real cheap in a junkyard though.
Or swap springs from a 1.5 (or 2) ton, they're 2.5" wide already and fit the spring hangers and shackles. I actually want to do this but have not found a good set, so I'll use what I already have.
I haven't started looking for plain simple US made lug nuts yet. Euclid might make some. Here's a set. http://www.ebay.com/itm/41-42-46-47-48-49-50-51-52-53-54-CHEVY-GMC-1-1-2-2-TON-TRUCK-REAR-LEAF-SPRINGS-/141880893513?hash=item2108c2a049:g:z38AAOSwpRRWnUDN&vxp=mtr Larry W.
1953 3800 Dually Flatbed
Entire Thread
14 bolt axle swap Considerations, Brainstorming, and Solutions
| Mrf1002u | 01/19/2016 5:54 AM |
14 bolt axle U-bolt saddle, Also clearance between backing plate & springs
| Grigg | 01/19/2016 7:15 PM |
Re: 14 bolt axle U-bolt saddle, Also clearance between backing plate & springs
| Mrf1002u | 01/21/2016 9:16 PM |
Re: 14 bolt saddle from a Ford - Post I can not find anymore !!!
| Mrf1002u | 01/19/2016 8:14 PM |
| Mrf1002u | 01/19/2016 9:32 PM |
| Grigg | 01/20/2016 1:03 AM |
| Mrf1002u | 01/21/2016 5:30 AM |
| Mrf1002u | 01/20/2016 2:02 AM |
| Mrf1002u | 01/20/2016 2:31 AM |
| Grigg | 01/20/2016 3:15 AM |
| Mrf1002u | 01/20/2016 4:39 AM |
| Grigg | 01/20/2016 5:50 AM |
| Mrf1002u | 01/20/2016 2:27 PM |
| Grigg | 01/20/2016 3:16 PM |
| Mrf1002u | 01/20/2016 3:58 PM |
| Blind1968 | 01/20/2016 4:14 PM |
| Mrf1002u | 01/20/2016 4:41 PM |
| Mrf1002u | 01/20/2016 4:46 PM |
| Mrf1002u | 01/20/2016 5:02 PM |
| Grigg | 01/20/2016 5:32 PM |
| Blind1968 | 01/20/2016 5:38 PM |
| Mrf1002u | 01/20/2016 5:55 PM |
| Mrf1002u | 01/20/2016 5:54 PM |
| Grigg | 01/20/2016 7:25 PM |
| Mrf1002u | 01/20/2016 7:49 PM |
| Mrf1002u | 01/20/2016 8:39 PM |
| Grigg | 01/20/2016 9:07 PM |
| Mrf1002u | 01/20/2016 9:40 PM |
| Mrf1002u | 01/20/2016 10:58 PM |
| Grigg | 01/20/2016 11:24 PM |
| Mrf1002u | 01/21/2016 1:05 AM |
| Mrf1002u | 01/21/2016 2:05 AM |
| Mrf1002u | 01/21/2016 10:15 PM |
| Grigg | 01/22/2016 5:11 AM |
| Mrf1002u | 01/22/2016 5:41 AM |
| Mrf1002u | 01/22/2016 6:04 AM |
| Grigg | 01/22/2016 5:43 AM |
| Mrf1002u | 01/22/2016 5:52 AM |
| Grigg | 01/22/2016 1:17 PM |
| Mrf1002u | 01/22/2016 4:13 PM |
| Grigg | 01/22/2016 4:58 PM |
| Mrf1002u | 01/22/2016 5:12 PM |
| Mrf1002u | 01/22/2016 5:15 PM |
| 69Cuda | 01/22/2016 5:25 PM |
| Mrf1002u | 01/22/2016 5:33 PM |
| Grigg | 01/22/2016 5:27 PM |
| Mrf1002u | 01/22/2016 7:22 PM |
| Grigg | 01/22/2016 10:26 PM |
| Mrf1002u | 01/22/2016 10:53 PM |
| Grigg | 01/23/2016 12:46 AM |
| Mrf1002u | 01/23/2016 12:59 AM |
| Grigg | 01/23/2016 12:59 AM |
| Mrf1002u | 01/23/2016 3:58 AM |
| Mrf1002u | 01/23/2016 1:39 AM |
| Grigg | 01/23/2016 2:24 AM |
| Mrf1002u | 01/23/2016 2:30 AM |
| Grigg | 01/23/2016 4:28 AM |
| Mrf1002u | 01/24/2016 2:28 AM |
| Mrf1002u | 01/24/2016 4:54 AM |
| Blind1968 | 01/25/2016 3:15 PM |
| Mrf1002u | 01/25/2016 3:33 PM |
| Mrf1002u | 01/25/2016 5:36 PM |
| Mrf1002u | 01/25/2016 3:45 PM |
| Grigg | 01/25/2016 3:46 PM |
| Mrf1002u | 01/25/2016 4:31 PM |
| Grigg | 01/25/2016 4:48 PM |
| Mrf1002u | 01/25/2016 5:04 PM |
| Blind1968 | 01/25/2016 5:39 PM |
| Mrf1002u | 01/25/2016 5:39 PM |
| Mrf1002u | 01/25/2016 5:47 PM |
| Mrf1002u | 01/25/2016 6:01 PM |
| Grigg | 01/25/2016 6:23 PM |
| Mrf1002u | 01/25/2016 10:58 PM |
| Blind1968 | 01/25/2016 6:30 PM |
| Blind1968 | 01/25/2016 11:08 PM |
| Mrf1002u | 01/26/2016 2:23 AM |
| Blind1968 | 01/26/2016 3:18 AM |
| Mrf1002u | 01/26/2016 6:22 PM |
| Mrf1002u | 01/26/2016 10:48 PM |
| Blind1968 | 01/27/2016 4:24 PM |
| Mrf1002u | 01/27/2016 7:31 PM |
| Mrf1002u | 01/28/2016 2:01 AM |
| Mrf1002u | 01/28/2016 5:03 AM |
| Grigg | 01/29/2016 9:20 PM |
| Mrf1002u | 01/29/2016 10:26 PM |
| Grigg | 01/29/2016 10:35 PM |
| Mrf1002u | 01/29/2016 11:07 PM |
| Grigg | 01/30/2016 12:25 AM |
| Mrf1002u | 01/30/2016 1:31 AM |
| Mrf1002u | 01/30/2016 1:39 AM |
| Grigg | 01/30/2016 2:17 AM |
| Mrf1002u | 01/30/2016 3:42 AM |
| Mrf1002u | 01/30/2016 3:37 PM |
| Grigg | 01/30/2016 4:14 PM |
| Mrf1002u | 01/30/2016 8:09 PM |
| Grigg | 01/31/2016 5:07 AM |
| Mrf1002u | 01/31/2016 5:46 AM |
| Grigg | 01/31/2016 3:18 PM |
| Mrf1002u | 01/31/2016 7:01 PM |
| Mrf1002u | 01/31/2016 7:37 PM |
| Grigg | 02/01/2016 12:31 AM |
| Mrf1002u | 02/01/2016 1:29 AM |
| Grigg | 02/01/2016 1:14 AM |
| Grigg | 02/01/2016 1:39 AM |
| Mrf1002u | 02/01/2016 1:56 AM |
| Grigg | 02/01/2016 4:24 PM |
| Mrf1002u | 02/01/2016 2:48 AM |
Re: 14 bolt axle swap Considerations, Brainstorming, and Solutions
| Mrf1002u | 02/01/2016 9:49 PM |
| Grigg | 01/05/2018 1:29 AM |
| Grigg | 01/07/2018 7:11 PM |
| VEW | 01/18/2018 4:34 PM | |
