0 members (),
234
9
Mod | | | Forums66 Topics128,078 Posts1,056,052 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 217 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 217 | I don't know where to post this so here goes. It is simple question, how do you heat your garage with the possible combustables?
| | | | | Joined: Feb 2008 Posts: 217 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 217 | Just wanted to know how you heat your garage??? Rick.. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Heat? A garage with heat???  I'm not that fortunate. I have a 100 lb. propane bottle with a double head heater that I put where I'll be working. It actually works quite well.
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | I just put on an insulated coverall. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | you need heat in Texas?? wimp wear carharts and keep movin Bill | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I use a gas furnace robbed from a house. | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | i use a coal stove with a little blower on it. $300 for two tons which lasts from nov to late april. i haul it and store it in my big bolt dump. when the truck is empty winters over and time to haul in a load of stone to fix the drive from snow plowing. the garage on average is maintained @60. during the late spring and early fall if need be i can burn wood in it to either take the chill off or lower the humidty. i keep all combustibles away from the stove. i paint with spray bombs at the other end of the shop and hang painted parts off door tracks or close to the heat for quick drying time. should i need a fire extingusher i a dry chem and a co2 mounted on the ashton and a pressurized water can sitting between the front doors. | | | | | Joined: Nov 2009 Posts: 220 Shop Shark | | Shop Shark Joined: Nov 2009 Posts: 220 | Garbage can heater from Northern Tools. Gets the shop warm in a hurry. About $100.
Chris | | | | | Joined: Oct 2010 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 62 | Un hook the dryer vent,BEWARE- (upsets) the women when it's running full blast and nothing's inside! Don J
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | if I were in San Tone I would not worry about it.. your right,this post is in the wrong place Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Feb 2006 Posts: 428 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 428 | 51 ashton,thank you for your post as it made me smile. I remember my grandfather cussin the coal company for RAISING the rate to 30$ a ton for coal!! | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | In floor radiant heat, propane fired boiler. | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Too many of you don't have the problem. Remember Tempest? She had cold till july 4th | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Wood fired boiler from Central Boiler. Combustion is 120 feet from the shop. It's 70 degrees at all times and the lack of humidity isn't a problem, it doesn't burn the air within the shop, Scott | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | In my Dads garage (where I rebuilt the '55 and the '48 8N now resides) we have an old coal stove that came out of the hose my Dad lived in when he was a kid. Grandpa kept it when he sold the house, and had it tucked away in the barn at the farm he lived on. We burn wood in it. In my garage, I have a 5000 watt electric barn heater, which is way overkill for a 28x32 garage, but it works and I got it cheap!
Bill Burmeister | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I have one of those cheap double 55 gal drum wood stove kits and it works really well. It sits kind of in the middle of the machine shop and I leave the door open between the shop and house, and if I want the garage warm I leave the door open between shop and garage. It will get to be about 70 in the shop and 68 or so in the house, and something a little cooler in the garage, which is just fine for working.
Otherwise pulling the warm car in the garage and closing the door knocks the chill off a little. Also have one of those big gray cube shaped propane heaters hanging in the corner of the garage, only ever used it once to see if it worked, the wood stove does a great job so far.
Grigg | | | | | Joined: Apr 2010 Posts: 474 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 474 | I close the doors ,put on a jacket and turn on the propane Mr.Heater for 15 minutes .My 100 lb bottle will last at least 2 years  rarely have to use it here in Tx .A/C would be the really nice luxury here besides my fan. | | | | | Joined: Mar 2008 Posts: 283 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 283 | Well I just had a new garage built this summer and I'm still moving in. It's tall - 14' so I can put in a lift, so I was worried about heat. Bought an Eden Pure heater - infra-red, so heater does not get hot, but on lowest setting has kept it very comfortable all winter, and it's been cold - and wet. It's just a small portable thing - on wheels and I'm amazed at how effective and how safe it is. Dale | | | | | Joined: Dec 2008 Posts: 899 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 899 | People with wood burners in your garage, I would go and talk to your insurance people. Around here if your garage catches fire and you have a wood burner, guess what????? You're not covered.
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Dec 2006 Posts: 720 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 720 | I have a car port, so I cant help you there,... However! Lately our whole base has been converting the aircraft hangar heating systems to radiant tube heaters. Basicly long tubes with reflectors above them, they have a natural gas burner every 30' or so and an exhaust fan at the end blows it outside. No interior ignition source so you dont have to worry about combustible fumes anyway. They dont heat the air, but the objects in the line of sight of the heater wich in turn heat the air. Works like a champ, can get the in several different sizes as well. Here's a pretty decent sized one from Northern Tool: http://www.northerntool.com/shop/tools/product_200455636_200455636 1956 GMC 370 dump " 'Tater "1970 VW Volksrod "the Black Bomber" 2007 Chevy Avalanche 2020 Jeep Cherokee Trailhawk, 2005 Harley Davidson FLHTCUI I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things. But thats just MY opinion! :P
| | | | | Joined: Jan 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 502 | I heat it with wood. A big huge wood fire right inside Herby, my nickname for this wood burning SS outside stove....a Hardy.
The hardy heats water which is fed underground to the house and the shop to a coil in a air handler, then it's forced air.
An added plus is that it also heats the house water prior to going thru the water heater, which cuts back on energy to heat water.
The downside....I have to go get the wood and split it. Dan
Remember your freedom - US Veterans provided it. 101st Screaming Eagles
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | | | | | | Joined: Jun 2010 Posts: 215 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 215 | I don't have any heat right now, but have been looking at diesel powered radiant heaters they just look like they would do a good job, but they are kind of pricey. I worked in a shop with the gas overhead radiant tube heaters, they work great, the only thing that was annoying was the noise from the stainless steel reflectors forever expanding and contracting every time it warmed up and cooled down, it was really annoying. | | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | I use my 60-watt shop light. No CFL in that puppy. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Sep 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 461 | Got a mr. Heater propane set up from amazon. Puts out 80,000 btu& use a twenty pound cylinder. Works great so far keeps it around fifty on colder days. Cost was a hundred bucks.
| | | | | Joined: Feb 2007 Posts: 434 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 434 | Mine is sheetrocked and insulated. The apartment overhead is heated, I've never seen it drop below 52 in the garage underneath, with outside temps in the teens. In the 50's, moving around working and it feels fine. If i'm just standing around I have a small jet propane heater--haven't used all of a tank in 10 years.
Harder part around here is cooling in the summer, I've got a 2400BTU 220V window AC that I cut a whole in the wall for. It works pretty good.
R-Bo
1959 Apache 1/2 ton Big Window, Short bed Fleetside (under reconstruction) 1966 GMC 305V6 in the family
| | | | | Joined: Aug 2010 Posts: 368 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 368 | I needed a new furnace for the house,so I took the old one and put it in the corner of my shop. I live in the Mtns. so I tee'ed off my propane tank and ran a line to the shop. vented the heater stack, and used a 12" open tube at ceiling level. It doesn't snow here but being near the cost and living in the wettest area in ca. I need this heater. It works almost too well...being made for a 2800 sq. ft home and being stuffed into a 800 sq. ft shop. I'ts only one for about 5 minutes before I either have to turn it off or work in my BVD's . I choose to turn it off due to scaring the wildlife when they pass by the shop windows. It was very easy to set up, just find a home thats getting torn down or contact a furnace company to get one that still works but the person wanted an updated version. Alot easier to go the wall and slide a switch to get the room to 70 than carry and store wood Oh yea Ashes too. Nothing worse than cracking a knuckle when its cold. I can remember the days of wrenching on my back in the cold on the driveway..only warmth was the lightbulb near my head so I could see..
Take Care and have a Great Holiday | | | | | Joined: Aug 2004 Posts: 242 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 242 | I have radiant floor heating in the shop. I use a propane fired 40 gallon hot water heater to heat the water. I keep the shop at 60 degrees.
John Gott 1942 G5106 1.5-ton Chevy cargo dump Gallery pageOld Dominion Stovebolt Society T/Sgt. Gott (28 years of service with the USPP) 1940 Chevy G506 4112 cargo dump 1942 Diamond T G509 969A 4 ton wrecker 1942 Ward LaFrance G116 series 2 10 ton wrecker 1944 Ward LaFrance G116 series 5 10 ton wrecker 1931 Ford AA with a WEAVER crane 1944 Sterling HC 165 tractor 1944 Autocar U7144T w/ 10 ton trailer
| | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | I used to heat my shop with a natural gas furnace,but it got too expensive.I now have a wood burning stove in my shop which works out very well.Get up early in the morning,then go out there and get a fire going.Come back in the house for coffee and breakfast,and back out to the shop where it is getting nice and warm.Works for me.Oh yeah and I buy slab wood from a local saw mill,so it is pretty cheap to heat with.
| | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | Wall unit Ac/Heat 220V sized for 1,000 SF, garage only 720 SF. in about 15 minutes chilli s gone, and in 30 it t-shirt waether (except laying on the concrete floor) | | | | | Joined: Mar 2007 Posts: 863 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 863 | Reverbaray Infrared overhead Natural gas heater....
only problem it has at that it heats the truck up, not the cold concrete under the truck.... | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | It's hard to beat a radiant in floor heat. You can open the doors and after you close them the whole floor is a giant radiator and warms the shop back up in minutes. Your feet always stay warm too. | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | I use a Glenwood Parlor stove casted in 1899, I burn Anthracite coal in it ..it is ALWAYS TOASTY in the shop.
| | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | i have been thinking about this NOW THAT WINTER IS HERE! been making it good so far. i prob spend about 5 or 6 hours every day in my shop, even longer if it's a day off. i hate the thought of heating it up and leaving about the time it gets warm (i work 2nd shift). i like wood heat but don't want to fire it up then leave. don't want to spend a fortune either. i have a propane heater with a big blower on it i have used in the past before i built this shop. i am only 3 sheets away from getting the ceiling done and then i will insulate up there. i want to get that done before i try to heat it. the joy of working on a budget, i bet noone else has to do that! this is only my 2nd year in the new building and i still am enjoying just being dry and out of the mud. i guess i will wait till the new wears off that to wory about being warm. | | | | | Joined: Aug 2008 Posts: 403 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 403 | I am really lucky that I have two 180,000 BTU radiant propane heaters I got when this plant was being dismantled. You can work out in the open and be nice in toasty. Just keep it about 5'from you and if you work inside it takes about 10 minutes and you shut it off. If you run it 8hrs. a day the seven gallon tanks last a week which is not too bad. Most tanks will last me about 30 to 40 days. I haven't filled up my tanks this last year as my Sinus Infection I had made feel tired from the meds I was taking. 62Blue Don
62Blue 62Chevy in progress You've never been lost until you've been lost at Mach3" Paul F Crichmore (Test Pilot)
| | | | | Joined: Aug 2005 Posts: 341 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 341 | I use a 30,000 BTU space heater but would rather have a wood stove. My shop is 30x40 pole building with R9 insulation, no ceiling with a 6/12 pitch roof so it takes a while to move the thermometer.
Allan ----- 1951 GMC 1/2-ton Two 1953 Chevy 3100 5-window | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I getting a 95% efficiency furnace put in the house. I'm considering putting the old furnace in the garage. The big downside is having to run a gas line to the garage.
| | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | i guess i'm just too tight, but i hate the thoughts of heating the garage with propane or natural gas. i know the price on both will have to go up again and i don't want to stuck payin' fer it. i don't mind supplimenting with it but i don't want no $200 heatin' bills for the garage! | | | | | Joined: Aug 2009 Posts: 295 Shop Shark | | Shop Shark Joined: Aug 2009 Posts: 295 | i guess i'm just too tight, but i hate the thoughts of heating the garage with propane or natural gas. i know the price on both will have to go up again and i don't want to stuck payin' fer it. i don't mind supplimenting with it but i don't want no $200 heatin' bills for the garage! Ok here is free energy to heat garage 1. Invite 3 politicians to garage 2. Get em started on an argument 3. Put on earmuffs to save on the noise (get ones with radio in em) 4. After about 20 minute go to work. 5. When done working tell em to leave. Dan Bentler | | |
