1 members (SandraD),
56
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 35 New Guy | | New Guy Joined: Jan 2011 Posts: 35 | My differential carrier gasket was leaking, so I took it off and used Permatex to make a gasket and installed it. Also reinstalled the axles. It seems that I have now have a larger backlash then I had before my work. It is about 1/8 to 3/16 of an inch. Any ideas how this happened? And suggestions on how to fix it?
Brimmer 54 Chevy 3/4 ton | | | | | Joined: Aug 2004 Posts: 1,417 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,417 | Is this the stock open driveline?
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | What backlash are you talking about? The work you have done would have no affect on anything except the oil leak. | | | | | Joined: Jun 2010 Posts: 301 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 301 | Did you install a new crush sleeve and torque to proper settings?
1949 Chevy 3600 1975 W-25 Hurst Olds 1970 GMC 1/2 ton Fleetside 2010 Chevy Silverado
| | | | | Joined: Jan 2011 Posts: 35 New Guy | | New Guy Joined: Jan 2011 Posts: 35 | I did not do anything except take off the differential carrier, put on the gasket and then put the differential carrier back. I made no adjustment. What I think backlash is, is when you hold the axles firm and then rotate the u-joint coming out the differential. There is about a 1/8 to 1/4 of a inch of play.
It seemed less before I fixed the gasket.
Brimmer | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Is this the original rearend?
What did you use for gasket material? Did you make your own or buy a pre-made one?
Jeff | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The original post says that he used Permatex to make a gasket.
I don't think you should worry about that much rotational driveshaft movement with the wheels blocked. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I have seen a LOT worse, Drive it. It'll last another 50 years just don't "snatch it" when going from forward to reverse or vise-versa. | | |
