5 members (NJC, baldeagle, tclederman, 1955 1 Series, 1 invisible), 56 guests, and 5 robots.
Topics128,016
Posts1,055,337
Members48,419
#885975 09/30/2012 10:09 PM
My differential carrier gasket was leaking, so I took it off and used Permatex to make a gasket and installed it. Also reinstalled the axles. It seems that I have now have a larger backlash then I had before my work. It is about 1/8 to 3/16 of an inch. Any ideas how this happened? And suggestions on how to fix it?
Brimmer
54 Chevy 3/4 ton
ODSS Lawman
ODSS Lawman
Is this the stock open driveline?
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
What backlash are you talking about? The work you have done would have no affect on anything except the oil leak.
1951 1 Ton Completed
Brimmer #886275 10/01/2012 10:33 PM
Did you install a new crush sleeve and torque to proper settings?
1949 Chevy 3600
1975 W-25 Hurst Olds
1970 GMC 1/2 ton Fleetside
2010 Chevy Silverado
I did not do anything except take off the differential carrier, put on the gasket and then put the differential carrier back. I made no adjustment. What I think backlash is, is when you hold the axles firm and then rotate the u-joint coming out the differential. There is about a 1/8 to 1/4 of a inch of play.
It seemed less before I fixed the gasket.
Brimmer
Is this the original rearend?
What did you use for gasket material? Did you make your own or buy a pre-made one?
Jeff
My 1953 Chevrolet
1947.1 Gallery
Brimmer #886742 10/03/2012 10:13 PM
The original post says that he used Permatex to make a gasket.
I don't think you should worry about that much rotational driveshaft movement with the wheels blocked.
Brimmer #886842 10/04/2012 12:17 PM
I have seen a LOT worse, Drive it. It'll last another 50 years just don't "snatch it" when going from forward to reverse or vise-versa.
