3 members (klhansen, 3800GUY, 1 invisible), 63 guests, and 3 robots.
Topics128,153
Posts1,056,847
Members48,456
#841300 04/05/2012 2:19 AM
Hi all, I am fairly stumped on something that I thought should be pretty simple. When I drive my 58, 3600 there is always a clanging sound behind the drivers seat. Sounds like it is coming from closer to the far left of the cab. I have checked for something loose but nothing. Thought of something in the gas tank but that produce different sounds depending on gas level. Any thoughts?
Rick
Rick
58 3600 4 on the floor
remove the entire seat top and bottom and drive around..
I like fixing stuff.
Gremlins?
My 1953 Chevrolet
1947.1 Gallery
May be the gas level float in the tank?
Kurt
a baffle broken loose inside the tank isn't affected by fuel level unless the tank is right near empty, just clunks around randomly
Well I guess it is possible it has something to do with the gas tank because the gauge doesn't really work. When I start the truck the the needle jumps up to the empty line and thats it when I turn it off it goes down
Rick
time to pull the sender and see if the float is still attached to it wink
mother in law?
Craig
Crusing in the Passing Lane
Did you read the post about the snake along for the ride?
Make sure the tank is secure and not moving in its brackets.
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
Big Bolt Forum Co-moderator
Well I found a ping pong ball and some unrelated hardware in my external tank on my 2 ton.
1948 Chevy 2-Ton
Its that beer bottle hanging on a string your buddy left you.
1937 Chevy 1/2 ton panel
My Dad in his drinking days used to stash his empty beer bottles behind the seat on his 46 1 ton. In fact, I believe part of the inner body panel had been removed, leaving room between the inner and outer body. When we used to clean that out periodically, there were usually enough empties in there to fill a whole case! When I read the title of this thread, that was my first thought!
chug
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Bill and Kurt I am guessing you guys might be on the right track. To check the float do I pull that circular disk off the middle of the top of the tank. What will I be looking for when I do this. And if the float is off what do I do about it. Oh it wasn't a beer bottle, gremlins, mother in law, snake or a ping pong ball. Thanks for all the good ideas though. Its driving me nuts. I even took the door panel off. Nothing!
Rick
Rick
yes, that 'disk' is the base of the sending unit, looks like this with the float missing - you could try to spot the float and fish it out [brass if original], or buy a new float to replace it and put up with the clanging grin but don't be surprised if it's a loose baffle, I've had it happen
Come on now Bill... Lets be honest here. It going to look like THIS Sending unit truth! wink
Give me ambiguity
or give me something else
Could it be an old lug wrench between the tank and cab?
You said the left side (back). Check down the back side of the cab, too. There is a cavity between the rear floor panel and the outside. There may be a wrench or bottle that may have fallen down and is rattling around.
Dennis
Well, they haven't found Jimmy Hoffa yet.... ohwell
1948 Chevy 1/2-Ton
"Tuesdays with Morris"
In the Legacy Gallery
Find it - Fix it - Drive it
Don't look into your gas tank with a lighter or match for light...Just sayin.
I'd pull the seat out and see if I could fish around behind the tank with a coat hanger or something.
1956 Chevy 3200
Pull the tank already... by the time your done fishing it will have rusted away... Besides how else are you gonna get use to drilling out broken off bolts and screws, busting off easy outs or recovering the 78 cents in loose change and 2 stale Pall Malls that have rolled under there?
Give me ambiguity
loose nut behind the wheel???
You guys are all to funny. The truck is pretty darn clean. Cavity, hoffa, etc. I'm starting to deduct that it must be the tank. Although I am reluctant to start that til I have exhausted all the easy things like Hoffa. I had Monday off and decided to do a couple of things to the truck. I started 4 jobs and fixed 0. So I just took it for a spin.
Thanks Rick
Rick
Any one else notice the threads with the most action are the ones with the most mystery about what the answer is? ohwell
Give me ambiguity
Its the challenge
Rick
I'm just glad its not always me that has the weird problems, seems like we all do...
My tank will make noise when its empty or if my fuel filter plugs. Sounds likes it "oil canning". Hope that helps. Taking off the cap to equalize pressure helps.
Eric
http://s1199.photobucket.com/user/sparky234/library/My%2057%20Chevy%20Stepside?sort=3&page=1
'57 Chevy 3100 (Little Red)
'81 RD350 LC - Fun, Fun, Fun
'83 GS1100E - Pocket Rocket
hey guess what? the noise disappeared
Rick
It's just hiding,cuz it knows it's about to get caught....
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
