6 members (WICruiser, Goach2, Phak1, Oswald, Hambone, jmoore), 80 guests, and 5 robots.
Topics128,184
Posts1,057,271
Members48,467
My radiator is about to give up on me. I was going to replace it with a brass one from JC. I saw an aluminum radiator from Champion on E Bay that is cheaper and they say that it cools better than brass. Will the alum last as long as brass? Just though I would get some other Stovebolters opinion.
An aluminum radiator is likely to have crimped on plastic tanks and is not repairable. I think my '41 has copper fins on brass tubes soldered to brass tanks. Over the long haul I would choose brass if I wanted an original look and toughness and repairability. I don't think there is a significant difference in the thermal transfer ability of brass and aluminum. The thing to check also,is the thickness of the core. i.e. the number of rows of tubes.
Opportunity is missed by most people because it is dressed in overalls
and looks like work. - Thomas Edison
1941 AL 3/4 ton 125-1/4 WB, bought by my Great Uncle Matt in 1942. Still in the family.
Mine is a all aluminum replacement type. Not a direct bolt-in since its for a '37, but it fit close enough for me. If it was black, the average person could not tell it wasn't original. It cools much better then the recored stock one I had, it also holds more coolant.
Joe
Crusing in the Passing Lane
Ron's advice is good. Brass is repairable, Al/plastic is not.
Champion's are all alum and are repairable. I love the Champion in my '65 and plan on buying one for the '66 when I start the restoration.
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
back yard wrench turner
Larry, what year is your truck? I know a guy that has an inventory of NOS radiators from the 30's and 40's. Prices are quite reasonable.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
My pickup is a 1951 3100 with a 1956 235 in it
The market has swung to aluminum due to its light weight and cost. So that is what is out there. I'd imagine only specialty companies deal with brass/copper radiators. Many tend to think they are better and more efficient. Truth is a copper/brass radiator dissipates heat better and I believe is a bit more sturdier(fins), not to mention what has already been said.
1941 G506
More
1946 3800
Pic
More
1946 3600
Pic
More
1924 Ford Model T Fordor
Thanks for all the input. I have got to replace the radiator before summer and I am thinking that the brass/copper will last longer.
I will suggest making an asessment of the original radiator. If it can be repaired,check the cost. A new replacement does infact look good, but if the vertical mount on the sides are not right on the money, it may not give you the correct clearance from rad / fan. It may be in that ''give-up''but is of good quality material. brass.
The difference between brass and aluminum can't be measured in product life. Both products most likely will outlast our ownership.
Would he have one for a '37 GMC T18H? Can provide px and/or dims.
Thank you.
Take your old radiator to a radiator shop. They can re-core it using the old tanks. I've done it a few times.
go with brass, they are better in almost every respect, one of the reasons that aluminum radiator mentioned above cools better is also stated in that post. "Holds more coolant", meaning that something is bigger, more tubes or something, giving you more cooling surface. They are more expensive, but if you are playing in this game you gonna have to get used to it.
thats what I said, the brass was more expensive. which is academic for me, as I don't need a radiator. But when I do I will go with brass. The aluminum seems to work fine in the new cars, I just don't want one.
Wayne
1989 Silverado
how long you gonna keep her??? aluminum is fine , but brass lasts longer...kev
The problem with my recored original was the old top and bottom tanks. The core cooled good enough, but the top tank was worn out. The seam would not hold due to thin brass always flexing during heat and cool cycles. No amount of solder was going to keep it from flexing at the seam, it was repaired four or five times for the same problem. I had enough money in it I could have bought two new replacements!
My aluminum replacement has a thicker core, way better air flow, hold more coolant, cost less then the recored old unit, holds way more pressure, weighs less, and cools better. Thats good enough for me!
Joe
Wayne, Thanks, called him, getting him info.
