BUSY BOLTERS Are you one? The Shop Area
| | Click on image for the lowdown.
| | Forums66 Topics126,777 Posts1,039,267 Members48,100 | Most Online2,175 Jul 21st, 2025 | | | Joined: Sep 2009 Posts: 41 'Bolter | 'Bolter Joined: Sep 2009 Posts: 41 | Hi Bolters,
I searched this topic and found some info, but not specifically what I wanted, so forgive me if I'm beating a dead horse.
I'm getting ready to start painting the frame of my AD truck and was wondering what you all used for undercoat. This will be a hot rod/work truck. I would like it to look nice, but my priority is protection and durability. If you have any advice or opinions, I'm all ears. Thanks as always for your help Bolters.
- Daniel | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I use POR15. Tough as nails. | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | Master Gabster Joined: Oct 2006 Posts: 4,983 | Sand blasted, primed and painted black with DuPont epoxy
~Jim
| | | | Joined: Jul 2005 Posts: 946 'Bolter | 'Bolter Joined: Jul 2005 Posts: 946 | Sandblasted and sprayed with Eastwoods Epoxy Primer, then top coated with Chassis Black. Now they have an Epoxy based top coat. | | | | Joined: Jan 2002 Posts: 866 'Bolter | 'Bolter Joined: Jan 2002 Posts: 866 | POR 15 worked fine for me! | | | | Joined: Sep 2009 Posts: 41 'Bolter | 'Bolter Joined: Sep 2009 Posts: 41 | Thanks for the feedback Bolters!!!!!!!!!! | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | 'Bolter Joined: Mar 2008 Posts: 3,750 | 'Nuther vote for POR-15. Someone else mentioned on another thread concerning chassis painting,it's lasted the best part of 60 years with fairly basic protection,so anything you do will probably outlast most of us....!
1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | Joined: Sep 2009 Posts: 41 'Bolter | 'Bolter Joined: Sep 2009 Posts: 41 | Jockbolter50, did you brush, roll or spray on the POR-15? The photos of your truck look great!
| | | | Joined: Mar 2008 Posts: 3,750 'Bolter | 'Bolter Joined: Mar 2008 Posts: 3,750 | Thanks for the compliment. That was brushed on,it flows out,covers well and drys to a real nice gloss. It's much safer than spraying and less mess,assuming you wear gloves and something with long sleeves.(mandatory!) I only had a few little dust problems.
Probably the main downside of POR is it's UV sensitivity. Although you can top coat it. I opted not to. As I said before,I'm relying on the fact it's all basically hidden by bodywork and have absolutely no intention of it seeing the sun! If it does I'll have bigger problems to worry about than fading paint!
| | | | Joined: Sep 2010 Posts: 252 Shop Shark | Shop Shark Joined: Sep 2010 Posts: 252 | Previous posts have mentioned blasting and priming before POR 15 but, I have decent paint on the frame but, it needs an update because it looks rough. Mostly it is just dirty and worn down. Should I clean up and paint with coat of POR 15 or do you have any better suggestions? Thanks Peter | | | | Joined: Dec 2004 Posts: 91 Wrench Fetcher | Wrench Fetcher Joined: Dec 2004 Posts: 91 | I hand painted Zero Rust. | | | | Joined: Mar 2010 Posts: 78 Shop Shark | Shop Shark Joined: Mar 2010 Posts: 78 | sprayed dupont etching primer then eastwood ceramic chassis black 2years ago and still fine. Lou.
1951 chevy 3100 short bed frame off resto.
| | | | Joined: Aug 2011 Posts: 1 New Guy | New Guy Joined: Aug 2011 Posts: 1 | Someone told me to use "CHASSIS SAVER" from Magnet Paints. It is supposed to be easier to use and safer than POR-15. Is anyone familiar with it? | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | Shop Shark Joined: Jun 2009 Posts: 2,201 | I am curious. What did the factory treat the frame with? My truck (53 Chevy) had a little bit of surface rust but very little pitting. It looked like bare steel to me so I wire brushed and painted it black.
After giving it some thought, I think I should have left it alone. It lasted just fine for over 50 years without my black paint. | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | Master Gabster Joined: Oct 2006 Posts: 4,983 | I am not aware of any factory painted frame. It you think about it, no one sees the frame and rust won't hurt steel that thick. that would be just an unreasonable expense for the manufacturer.
~Jim
| | | | Joined: May 2011 Posts: 23 New Guy | New Guy Joined: May 2011 Posts: 23 | my frame came clean with wire brush and soap water then rattle caned it semi gross black looks great
1962 chevy stepside 2002 chevy stepside
