2 members (46 Texaco, sron48), 146 guests, and 0 robots.
Topics128,119
Posts1,056,313
Members48,439
Hi Bolters,
I searched this topic and found some info, but not specifically what I wanted, so forgive me if I'm beating a dead horse.
I'm getting ready to start painting the frame of my AD truck and was wondering what you all used for undercoat. This will be a hot rod/work truck. I would like it to look nice, but my priority is protection and durability. If you have any advice or opinions, I'm all ears. Thanks as always for your help Bolters.
- Daniel
I use POR15. Tough as nails.
Sand blasted, primed and painted black with DuPont epoxy
~Jim
Sandblasted and sprayed with Eastwoods Epoxy Primer, then top coated with Chassis Black. Now they have an Epoxy based top coat.
POR 15 worked fine for me!
Thanks for the feedback Bolters!!!!!!!!!!
'Nuther vote for POR-15.
Someone else mentioned on another thread concerning chassis painting,it's lasted the best part of 60 years with fairly basic protection,so anything you do will probably outlast most of us....!
More pix on Flickr.
Jockbolter50, did you brush, roll or spray on the POR-15? The photos of your truck look great!
Thanks for the compliment.
That was brushed on,it flows out,covers well and drys to a real nice gloss.
It's much safer than spraying and less mess,assuming you wear gloves and something with long sleeves.(mandatory!)
I only had a few little dust problems.
Probably the main downside of POR is it's UV sensitivity.
Although you can top coat it.
I opted not to.
As I said before,I'm relying on the fact it's all basically hidden by bodywork and have absolutely no intention of it seeing the sun!
If it does I'll have bigger problems to worry about than fading paint!
More pix on Flickr.
Previous posts have mentioned blasting and priming before POR 15 but, I have decent paint on the frame but, it needs an update because it looks rough. Mostly it is just dirty and worn down.
Should I clean up and paint with coat of POR 15 or do you have any better suggestions?
Peter
1951 Chevy 3100 5-Window
"Howard"
More pix on Photobucket
1 Offline
I hand painted Zero Rust.
sprayed dupont etching primer then eastwood ceramic chassis black 2years ago and still fine. Lou.
1951 chevy 3100 short bed frame off resto.
Someone told me to use "CHASSIS SAVER" from Magnet Paints. It is supposed to be easier to use and safer than POR-15. Is anyone familiar with it?
I am curious. What did the factory treat the frame with? My truck (53 Chevy) had a little bit of surface rust but very little pitting. It looked like bare steel to me so I wire brushed and painted it black.
After giving it some thought, I think I should have left it alone. It lasted just fine for over 50 years without my black paint.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
I am not aware of any factory painted frame. It you think about it, no one sees the frame and rust won't hurt steel that thick. that would be just an unreasonable expense for the manufacturer.
~Jim
2 Offline
my frame came clean with wire brush and soap water then rattle caned it semi gross black looks great
1962 chevy stepside
2002 chevy stepside
