7 members (Gdads51, Phak1, Joe H, Youngin' Tut 59, Greg_H, carbking, Wayne67vert),
99
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,137 Posts1,056,430 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | I drove mine to work early today to take a cake i made for breakfast for my co workers.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Aug 2010 Posts: 105 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 105 | I began a rewire of the entire truck in my 52 3600 today. Put in new tail lights, headlights, dimmer switch, turn signal switch. I also rebuilt the carb. | | | | | Joined: Oct 2009 Posts: 164 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 164 | Not much as it's still in the storage yard. I did pick up an original splash pan for between the front grill and bumper for 50 bucks so I was happy. Looking to get hte truck to the house in the next couple of weeks or so.
Joe | | | | | Joined: Sep 2010 Posts: 695 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 695 | I scraped and wire-brushed then primed and painted the Bell Housing. I also applied the new "JOBMASTER 261" Decal onto the Valve Cover. Hopefully today, I can mount the block to the engine stand for the assembly process.
Jerry | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | I brought my truck home on the trailer, drove it on and drove it off. It sure is easy loading it on the trailer with the granny gear. First time driving this truck since I got it 4 1/2 years ago. I can only go up and down the driveway til I get the safety and license done, but I may go for a rip down the road tomorrow. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | You're 6 months ahead of me. I'll be bringing mine on(drive on and off) the trailer Friday afternoon.
~Jim
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I pulled the adjustable main jet off the suburban and put in a standard one. I never could get the adjustable one to run right. Seems to run a lot better this way. | | | | | Joined: Jan 2010 Posts: 166 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 166 | I have the front end completely disassembled. Cleaning the frame and guess what: I found the chassis number on the left front part of the frame. After 1.5 years trying to figure out the exact year of the truck (at least cab and frame) it was my Xmas present. It is a '49. Now I can make a plate with the motor and chassis numbers. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Got Pictures?
~Jim
| | | | | Joined: Dec 2009 Posts: 194 Shop Shark | | Shop Shark Joined: Dec 2009 Posts: 194 | Had a fun time with the temp gauge, some times no indication, sometimes to hot, finally chased it down to bad grounding from the motor to dash. Connected a wire from the motor to the firewall and the temp gauge works well. Rust is not a good conductor!!! | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Fiddled with my rear door latch (thanks for sending that, Alvin). I grabbed a spring that I didn't realize the welder had heated up. I let go real quick, door closes perfectly but doesn't open. | | | | | Joined: Dec 2010 Posts: 280 'Bolter | | 'Bolter Joined: Dec 2010 Posts: 280 | I did not do anything on my bolt...per say but I did try and clean out my shed today and in doing that emptied all of its contents into the backyard. (The shed was full of my stovebolt body panels)....problem is It is now dark and my back yard is full of stovebolt stuff and my shed is not! hope it does not rain for it will be a few days before I can repack the shed and put those parts back to bed till they are needed.
*UNDER CONSTRUCTION* 1953 Chevrolet 3100 1/2 ton-previously abandoned resto. My Project BoltI hate when people leave their brains at home. Seriously when did critical thinking and customer service go out the window? How about common sense and striving to go the extra mile? Idiots, surrounded by idiots it tell you.
| | | | | Joined: Feb 2010 Posts: 323 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 323 | Went to the local spring shop today They had all the spring bushings and pins for my 38 in stock. No shipping. Even saved a few bucks.
1937 Chevy 1/2 ton panel 1953 GMC 2 ton. future car hauler
| | | | | Joined: Jan 2011 Posts: 90 New Guy | | New Guy Joined: Jan 2011 Posts: 90 | Asked at the local parts house I go to for a wheel cylinder rebuild kit cost $12 , then asked how much for the wheel cylinder cost $10.50. I must have had an extremely puzzed look on my face but figured I may as well order 4 brand new cylinders
1954 3600 With 1950's Powers of St Louis Utility Bed. My truck | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Asked at the local parts house I go to for a wheel cylinder rebuild kit cost $12 , then asked how much for the wheel cylinder cost $10.50. I must have had an extremely puzzed look on my face but figured I may as well order 4 brand new cylinders Does that mean you have to rely on brakes made in China? | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Did you ever think about how with a full restore you have a Chinese truck. I think mine must be "nationality schizophrenic".
~Jim
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Way to go Leo, I can see your smile from here!!
yesterday I started the engine up for the second time. This time was to check the oil pressure guage,temp guage, and the tranny. Since I had it on jack stands I also checked the speedo!! So far so good.
Today, I finally got MAD enough to tackle the new grille once again. With pliers, punches, sockets, all kinds of wrenches, a floor jack and a piece of wood I think I can say I finally got it at least "close"!! Oh, I forgot about a few choice words along with the other tools.
If all goes well, I'll put the hood on it Friday...or saturday. Man, I hope at least it will go on good. | | | | | Joined: Jul 2005 Posts: 640 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 640 | I took mine out for some exercise today. It was about 60 and sunny. A great day for it. | | | | | Joined: Sep 2010 Posts: 695 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 695 | I ordered 2 more cans of Detroit Deisel Alpine Green paint and my gasket set for the 261 rebuild... I'll pick up the paint today. The gaskets should be in, Tuesday. I also received and installed the remaining Exhaust Valve Guides for my 261 head... since I broke two, during the initial installation of the set! While I was in that process, a UPS truck stopped and the driver delivered my connecting rod bearings. SWEET! I brought home 2 steel strap clamps (from work) to adapt the frappin HF engine stand mounting plate to my bell housing. Hopefully this weekend I can mount the engine & bell housing assembly onto the stand, paint the block and install the crank, piston assemblies and cam. I'm getting closer!
| | | | | Joined: Jan 2011 Posts: 90 New Guy | | New Guy Joined: Jan 2011 Posts: 90 | Well inside is taking shape still loads more too do , Tore the Brakes apart now have too wait on parts :o( my Chevy
1954 3600 With 1950's Powers of St Louis Utility Bed. My truck | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | It looks like the alternator is not ginning. I'll check the wiring on my schematic tomorrow.
~Jim
| | | | | Joined: Jul 2006 Posts: 190 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2006 Posts: 190 | Not exactly today, but this week. Still working on the doors, but getting real close to smooth. Pull the wheels and drums today, made up parts list for new wheel cylinders and few minor parts. Master cylinder cleaned. The dollar store equal of CLR really nails the rust but WAY cheaper, going to order rebuild kit (bore is pristine). Got new shocks on back (mine already had the shock conversion kit on it from who knows when). After some searching at Napa I found Napa sensatrac 37188 to be length match to what was on it (no numbers stamped at all) Interesting thing is these were made to get rid of the hideous Cadillac self leveling system, so they come with mounting hardware for that. Bought a front mount shock system on line that does not require any drilling to the frame to mount front shocks and got them on. Got a parts list for an order in the a.m. and then its back to those GDang doors again while I wait for parts to have brakes again! Just a good reason to put that motor back in and stop pushing that thing in and out of the garage,
| | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | Put the ignition switch back into the dash! Finally got rid of the Chrysler key that we had to use. | | | | | Joined: Mar 2003 Posts: 1,132 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 1,132 | Started on the headliner. Its going to be a long process.
Weeds | | | | | Joined: Feb 2010 Posts: 323 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 323 | Replaced the old rear spring bushings and pins today. The rear frame shackle bushings are a bear to install.I used a piece of 1/2"grade #5 fine thread rod as a puller. Ran it through the mount and the bushing and tightened nuts on both ends with washers and old king pin thrust bearings. Still had to heat up the frame mount to pull the bushings in but it worked out fine. The bushings were much easier to install in the springs.And no I didn't heat the springs
| | | | | Joined: Feb 2011 Posts: 34 New Guy | | New Guy Joined: Feb 2011 Posts: 34 | Installed my 250 I6...using Langdon's side mount kit .Also installed my TH350 while I was at it, now i need to tear it all down and prep the frame for paint....!!!Good start for the weekend.
1949 Chevy 1/2 ton | | | | | Joined: Dec 2010 Posts: 24 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2010 Posts: 24 | This being the 1st nice day in months, I was able to do some rattle can painting today. I painted the bellhousing, starter, front brake backing plates and the oil filter canister, all gloss black, with the exception of the oil filter lid, which I painted Chevy engine orange.Waiting on king pins which will be here Monday, then I can start putting the front end back together to include spring shackles & rear eye bolts, kingpins, tierod ends, & brakes to include new shoes, lines, & wheel cylinders. Terry
'52 Chevy 3600 '03 Chevy 2500HD '64 Pontiac Grand Prix '93 Jeep Wrangler
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Well said Terry. Well said Terry. lol
~Jim
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Rather than mechanical work on my Bolt, I did some research for future work I'll be performing in the next month or two. I did this research out at the Texas Motor Speedway where the Spring Goodguys show was going on. I've been to rod shows before but this took the cake. Thousands of street rods and all kinds of classics were being shown. Of course my eyes caught each and every Advance Design pickup. I was able to get some ideas of all the different ways to finish out my truck. Mainly cosmetic issues but also issues of cooling and wheels and upholstery. I also got the chance to meet Cletis (Charley Hardin)and his bride in person after all these years. http://www.classicshoptalk.com/content/1078-spring-lone-star-nationals.html
~Jim
| | | | | Joined: Dec 2010 Posts: 280 'Bolter | | 'Bolter Joined: Dec 2010 Posts: 280 | did some wire brushing on the frame today. rolled out the frame to the driveway for some fun in the sun!
| | | | | Joined: Nov 2006 Posts: 677 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 677 | I got the sending units installed in the New Tank and it's coming along fine so far...but had to stop for repairs to Thumb, "Yep cut it bad"  Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs. 1951 3100 350 TBI Gallery Toddzilla... "$old" | | | | | Joined: Mar 2005 Posts: 94 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 94 | New muffler came today. My 235 has been running rough, almost as though its missing, noticable through the exhaust but not so much while listening up front. Anyway, new plugs and wires, new muffler (to remedy a poor decision to use a glass pack), rebuilt YF (one of three carbs I've switched out). I pulled the roter this evening and it looked a little fried along the edge, and two the contacts in the cap had some junk on them. cleaned everything up...still missing a bit. Tomorrow it gets a new roter and points, dist cap on order. I have some slight ticking in the valve train so I'll try to adjust those too. I miss driving my truck.
1953 Chevrolet 3100
| | | | | Joined: Sep 2009 Posts: 45 New Guy | | New Guy Joined: Sep 2009 Posts: 45 | I drove my '55 1st to the local farmer's market, and loaded up the bed with avocado's, iceberg lettuce, an orchid, bananas, macaroon brownies, brussel sprouts, chiles, strawberries, and a custard pizza. Then I came home. Thus I ensured that adequate lubrication is spread around vital metal truck parts until next week. That wore me out, so I'm going in to eat that custard pizza. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Dang jivermo you're going to over do it if you're not careful. lol
~Jim
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Finished up tidying up the strut rod mount that I was in the process of removing,before I was rudly interupted by the cutting disc hitting my finger last week! I also finished painting my drivers side front fender. Also,as a correction to my previous thread, the paint job is a 30 footer,rather than the 20 feet I mentioned earlier.........  1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Jul 2006 Posts: 190 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2006 Posts: 190 | Make harmonic balancer tool and installed harmonic balancer on the 216. Also put my fan back on, the rest of the day was dedicated to moving things to the scrap pile to scrap man tomorrow. (Nothing old) Next three pics, http://s111.photobucket.com/albums/...LD/?action=view¤t=DSC08633.jpg | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I fixed the transmission on the '56 today. I started to the Goodguys show in Fort Worth yesterday and it was shifting rough. So I brought it home and took another vehicle. Today I found the culprit. The vacuum line had come off the modulator valve. | | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | | | | | | Joined: Jan 2007 Posts: 29 New Guy | | New Guy Joined: Jan 2007 Posts: 29 | Finally got around to drilling out the broken bolt that held the steering arm to the spindle on the drivers side. Installed the new kingpin. Mounted the updated brake backing plate (off a 57) and repacked the wheel bearings on that side (same stuff was done to the right side a few months ago) just need to find all the parts to do the brakes now
Too Many Projects, not enough time
| | | | | Joined: Jul 2010 Posts: 89 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 89 | I wrastled with the doors putting all new rubber seals in. Done now, but what an ordeal. There's gotta be a quick easy way to do it that i'm not aware of. Can't believe they did it on the assembly line like i tried. 6+ hours!! bunch of screws that haven't been off in decades/or missing altogether that i had to get/find in the 5lb coffee can. glad it's done now though!!!! lots less ratteling and wind noise.
it ain't YOURS 'till it ain't stock!
1951 chevy 3100
