7 members (Gdads51, Phak1, Joe H, Youngin' Tut 59, Greg_H, carbking, Wayne67vert),
99
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,137 Posts1,056,430 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 453 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 453 | I'm just about finished with the rear end on my 6400. The end caps on the end of the axle and the "pumpkin cover", can I use black silicone or does it have to be a gasket. Not sure if I'll find matching gaskets. Thanks all! | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | Hey Ron, I like gaskets, cut your own.
Bruce | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | I used black on the pumpkin cover and the gaskets on the axle ends. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy mummdogg,the Fel-Pro numbers are RDS5049 for the diff , and RDS4062 for the cover side on a single speed rear axle, and the two speed numbers are RDS5050 for the cover side, and RDS11855 for the diff side, that is providing no one has swapped rear axles in the last 57 years, hope that helps. | | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | Consider the Permatex product "The Right Stuff" that comes in a standard caulking tube. It is a rubber elastomer product that does not require a gasket. In my experience it seals much better than silicone without any leaks and is quick and easy to apply. The only downside is it is a bit hard to remove the sealed part due to its adhesive properties. | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | being in the steam generation business i like a real gasket on everything. im not a fan of snot(unless its coming out of my nose) but in certain applications i will use it on my trucks. the problems with gaskets is they tend to stick to one or both sides of what is pressing against them. when the time comes to seperate them, a couple of things can happened but ultimely the the gasket is destroyed. some people like to glue (gasket sealer) one side to a paticular surface for ease of removal but maintaining its position for reassembly. there is no guarentee that the gasket still wont fail. what we do is to add never seize to both sides of the gasket and the mating surfaces. even under extreme pressure (process) and temp the gaskets don't stick to the mating surfaces nor are they detroyed in the process should disassembly take place. i like to do this on uncommon gaskets such as axle flanges where they are hard to find replacements. | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | I like the gorilla snot on the pumkin cover after the gasket surfaces are clean as a whistle. The gasket will tend to weep. Not too often does the rear end lube get changed.
I do like the gaskets on the outside flanges. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I use a gasket anywhere one was originally used, and most often use Permatex #2 lightly on both sides, just enough to not ooze out. (knock on wood, but so far my new "Driptroit" Diesel hasn't dripped..)
For valve cover gaskets I use contact cement and stick the gasket to the cover, and nothing on the other side. It's stuck in pace and reusable for many valve adjustments.
Some if not all newer rear axles use some type of silicone goop on the housings, I've used it too and it works. But I still prefer to use a gasket if one was used originally.
Grigg | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | I always use a gasket if one is available or make my own at times. I've found that if you clean the bolt holes and the bolts real good sometimes a bit of sealer on the threads of the bolt will help with the seepage that if often noticed. | | | | | Joined: Apr 2006 Posts: 453 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 453 | Thanks to all. I too would rather use a gasket if possible. I really haven't had time to see if any were available yet. Thanks 3B for the numbers. I used the black silicone in the past with good results. I figured since the rear axle isn't pressurized or heated, it shouldn't matter, but I wanted to ask the tribal elders first. The gaskets on the outside caps are gonna be fun to cut if I decide to make my own! | | | | | Joined: Apr 2006 Posts: 78 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 78 | Howdy mummdogg,
A lot of times I have to make my own gaskets to save time and money for my customers. Harbor Freight has a set of cutout punches to make the bolt holes. It's been a while since I bought the set, but they weren't more than $10. NAPA has rolls of gasket material and the left over will come in handy later. On machined surfaces I use a ball peen hammer to cut the gasket against the part, and anything else marker and scissors. Who said kindergarden's over! Torque your bolts for even squish and a gasket's only enemy will be heat or age which ever comes first.
"The Marines I have seen around the world have the cleanest bodies, the filthiest minds, the highest morale, and the lowest morals of any group of animals I have ever seen. Thank God for the United States Marine Corps!" Elanor Roosevelt
1966 c-10 stepside 1966 c-10 fleetside 1964 c-10 fleetside 1964 c-10 short bed 1964 c-30 flat bed 1964 c-60 dump truck 1968 Impala 1969 Nova 1971 Nova 1975 LUV 1976 C-30 1977 K-20 1966 SS El Camino
| | | | | Joined: Jan 2008 Posts: 227 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 227 | If you can get a gasket, smear a THIN layer of black goo on one side of the gasket and let it fully cure. Then put a THIN smear on the opposite side and allow it to cure until tacky. Assemble the two parts finger tight and allow an extra hour or so to fully cure and then torque up the bolts. This makes a great seal, yet allows the parts to be disassembled without wrecking the gasket.
If you run without a gasket, coat both surfaces evenly and allow to 3/4 cure. Assemble the parts finger tight and allow full cure, then torque to specs. This creates a good even seal and will come apart with ease, possibly with the black goo "Gasket" in one piece. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | If you can get a gasket, smear a THIN layer of black goo on one side of the gasket and let it fully cure. Then put a THIN smear on the opposite side and allow it to cure until tacky. Assemble the two parts finger tight and allow an extra hour or so to fully cure and then torque up the bolts... I used to use that method, Now I use Permatex #2 on the gasket, a thin smear both sides, just enough to not ooze out. I'm having much better results with the Permatex than I had with the silicone. Grigg | | | | | Joined: Jan 2008 Posts: 227 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 227 | I'm with you there Grigg! It's a bit hard to translate the actual product you are all talking about. Here we have a product called "Ultra-Blue". It is not a silicone based sealant, but is the best compound to use on all things mechanical that need sealing. At the end of the day, the method still remains the same! Hopefully it helps out  | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Here's the info on Permatex #2 it's a "Slow-drying, non-hardening sealant designed for sealing cut gaskets and stamped parts. Allows for easy disassembly if required. Temperature range -65°F to 400°F (-54°C to 204°C); resists common shop fluids and fuels. Use where sealing is more important than adhesion." Looks like tooth paste but black and a little stickier. Grigg | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | Here's the info on Permatex #2 it's a "Slow-drying, non-hardening sealant designed for sealing cut gaskets and stamped parts. Allows for easy disassembly if required. Temperature range -65°F to 400°F (-54°C to 204°C); resists common shop fluids and fuels. Use where sealing is more important than adhesion." Looks like tooth paste but black and a little stickier. Grigg we used it in the navy deep down in the propulsion plants. we'd get in jumbo tubes and used it on almost everything. the part that its "non hardening" is B.S. but then we went over the upper temp range by 2. when dealing with 1200 psi @950* steam you want something that does the job and ole #2 did it. we hated it and i now only use it in certain applications because i still hate it but i will choose this over snot anyday. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ..... I must admit that for years Permatex is all that I would ever use...and I still prefer it over most stuff. But, what I think we're really saying is that there is a better choice today than years ago. Products today are more specific to one job..... its just tough sometimes deciphering what it is really the best at since all the manufacturers want you to think THEIR product is the cure for all ills!
.... but I still love my Permatex products!! | | |
