5 members (1955 1 Series, Southerntruck, tclederman, Rusted Nut, Peggy M), 38 guests, and 8 robots.
Topics128,010
Posts1,055,308
Members48,419
#60375 05/11/2006 10:42 PM
Hello all, I was wondering how to set the pinion angle on my rear end. I have a 41 chevy with a 10 bolt gm posi rear end. I plan on putting in a 350 with a 700r4 tranny.I need to weld in the saddles thanks for the help. James
If it was easy, everybody would be doing it.
#60376 05/11/2006 11:25 PM
It should be very close to the same angle as the transmission,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#60377 05/12/2006 12:43 AM
That is what I always thought too but some people have since suggested the differential pinion angle should be a few degrees down to compensate for axle wind up. I don't know much more about this.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#60378 05/12/2006 1:50 AM
I've heard "parallel to the transmision for normal street use and about two degrees down angle for better launches".
#60379 05/12/2006 2:47 AM
If you'd do a search of this forum you'd find several references to this site.
#60380 05/12/2006 3:35 AM
just replaced my old 350 tranny with a 700R4 in my 37 and while I was at it I "reset" my pinion angle since it was to high. I was lucky as my nephew borrowed a digital guage from Freightliner and helped me set it. First you need to level the chassis then check the angle of the tranny. Set the pinion 2 degree's negative or "low". The gizmo he had we placed on the tranny and got the reading then on the rear housing. I have always heard there is an "angle guage" to do it with but never seen one or know where you can get one...... I would not trust "eyeballing" it as that is what I did originally and it was to high giving me a little vibration. Just FYI hope it helps get you in the right direction.
#60381 05/12/2006 11:54 AM
2 Offline
You can get a angle guage at Home Depot for 15 or 20 bucks. FYI
#60382 05/12/2006 7:36 PM
I read another thread here last night, don't know which forum, but it said Sears had one for 10 bucks.
#60383 05/12/2006 7:38 PM
Harbor Freight has one for about $5-
I've heard a couple of degrees downward of parallel in a truck to compensate for when the truck is loaded.
Be sure to measure from the same side of the engine and differential- Negative on the driverside is postive on the passangerside...
#60384 05/12/2006 7:53 PM
Thanks for the info guys, I appreciate it
#60385 05/12/2006 8:02 PM
Jim & Caroline
