0 members (),
46
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#60375 05/11/2006 10:42 PM | Joined: Dec 2005 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2005 Posts: 103 | Hello all, I was wondering how to set the pinion angle on my rear end. I have a 41 chevy with a 10 bolt gm posi rear end. I plan on putting in a 350 with a 700r4 tranny.I need to weld in the saddles thanks for the help. James
If it was easy, everybody would be doing it.
#60376 05/11/2006 11:25 PM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | It should be very close to the same angle as the transmission, Scott | | |
#60377 05/12/2006 12:43 AM | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | That is what I always thought too but some people have since suggested the differential pinion angle should be a few degrees down to compensate for axle wind up. I don't know much more about this. | | |
#60378 05/12/2006 1:50 AM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | I've heard "parallel to the transmision for normal street use and about two degrees down angle for better launches". | | |
#60379 05/12/2006 2:47 AM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | If you'd do a search of this forum you'd find several references to this site. | | |
#60380 05/12/2006 3:35 AM | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | just replaced my old 350 tranny with a 700R4 in my 37 and while I was at it I "reset" my pinion angle since it was to high. I was lucky as my nephew borrowed a digital guage from Freightliner and helped me set it. First you need to level the chassis then check the angle of the tranny. Set the pinion 2 degree's negative or "low". The gizmo he had we placed on the tranny and got the reading then on the rear housing. I have always heard there is an "angle guage" to do it with but never seen one or know where you can get one...... I would not trust "eyeballing" it as that is what I did originally and it was to high giving me a little vibration. Just FYI hope it helps get you in the right direction. | | |
#60381 05/12/2006 11:54 AM | Joined: Sep 2003 Posts: 324 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 324 | You can get a angle guage at Home Depot for 15 or 20 bucks. FYI | | |
#60382 05/12/2006 7:36 PM | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I read another thread here last night, don't know which forum, but it said Sears had one for 10 bucks. | | |
#60383 05/12/2006 7:38 PM | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | Harbor Freight has one for about $5-
I've heard a couple of degrees downward of parallel in a truck to compensate for when the truck is loaded.
Be sure to measure from the same side of the engine and differential- Negative on the driverside is postive on the passangerside...
#60384 05/12/2006 7:53 PM | Joined: Dec 2005 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2005 Posts: 103 | Thanks for the info guys, I appreciate it
#60385 05/12/2006 8:02 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 |
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
