2 members (Rusty Rod, porsche),
64
Mod | | | Forums66 Topics128,021 Posts1,055,357 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2007 Posts: 98 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 98 | Does anyone know a place to find sheets or pieces of rubber - to make mounting parts or bushings? The rubber in my transmission support is shot, and I'd like to avoid the high cost of sending it in to be repaired. Thanks | | | | | Joined: Sep 2006 Posts: 206 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 206 | Would a hockey puck work?? | | | | | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | Dead earth mover tire makes a good doner. Easly cut with a helper and a saws all. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I don't know if these would be big enough but I bought a pair of coil spring helpers and used one to fashion a rubber mount for my rad support. I was able to cut it down with a hack saw. | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | U can buy it at most commercial jobbers. seems like auto zone would even have it. | | | | | Joined: Feb 2000 Posts: 5,194 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,194 | | | | | | Joined: Nov 2007 Posts: 98 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 98 | Thanks for all the great suggestions. JoeH, I've never come across the mcmastercarr site - great website. I came across their foil-faced, flexible polyurethane. It's ordered in 54 inch widths and can be ordered with an adhesive backing. Seems like a good, cheap source of sound deadener for a cab's interior. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Get some conveyor belt, Scott | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 |
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Yup as Scott said ...a chunk of conveyor belt is worth its weight in gold at times! | | | | | Joined: Jul 2005 Posts: 595 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 595 | probably a place near you that repairs conveyor belts and has a dumpster full of old stuff that they will give you. a place that repairs solid forklift tires would have heavy duty rubber sheets. | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | | | | | | Joined: Jan 2008 Posts: 4,960 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,960 | Mud flaps work. I paid way too much money for body mounting pads for a 56 Ford and when they arrived, they had no fabric in them; so I made some out of mud flaps. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I have an old firehose that I cut up. It is "layered" and with two pieces it comes out just right. I glued two pieces together for my panel mounts and they look nice. The hose has rubber and also a couple layers of what is probably woven polyester fabric that will never rot. Just another possiblity. | | | | | Joined: Nov 2008 Posts: 137 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 137 | Subframe bushing from a GM "F" body might work | | | | | Joined: Aug 2008 Posts: 230 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 230 | got any rough idea ,or size's,picture of what it looks like,i might have some thing that might work .
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Poly-urethane from McMaster Carr. About a 80 or 90 durometer. you can also buy casting urethane from McMaster Carr in 88 durometer. It is a 2-part urethane. I have used it to re-cast rubber parts as well as make new parts. I have made bushings new again by removing all the rubber and re-casting with urethane. Urethane is impervious to almost every chemical
It would work great for building transmission mounts if you cast it right.
| | | | | Joined: Nov 2007 Posts: 98 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 98 | I was able to get hold of some conveyor belt, and it worked well. That casting urethane sounds interseting - I'll have to check it out. Thanks for all the great input everyone. | | |
