4 members (originalchuck, TooMany2count, Chip O, Hotrod Lincoln), 78 guests, and 2 robots.
Topics128,024
Posts1,055,392
Members48,422
#476805 11/30/2008 2:38 PM
Does anyone know a place to find sheets or pieces of rubber - to make mounting parts or bushings? The rubber in my transmission support is shot, and I'd like to avoid the high cost of sending it in to be repaired. Thanks
Would a hockey puck work??
Dead earth mover tire makes a good doner. Easly cut with a helper and a saws all.
I don't know if these would be big enough but I bought a pair of coil spring helpers and used one to fashion a rubber mount for my rad support. I was able to cut it down with a hack saw.
1951 1 Ton Completed
U can buy it at most commercial jobbers. seems like auto zone would even have it.
Thanks for all the great suggestions. JoeH, I've never come across the mcmastercarr site - great website. I came across their foil-faced, flexible polyurethane. It's ordered in 54 inch widths and can be ordered with an adhesive backing. Seems like a good, cheap source of sound deadener for a cab's interior.
Get some conveyor belt,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
capital rubber in sacramento,
http://www.capitalrubberco.com/
Jim & Caroline
Yup as Scott said ...a chunk of conveyor belt is worth its weight in gold at times!
1952 Chevy Shortbed
Photos in Photobucket
1 Offline
probably a place near you that repairs conveyor belts and has a dumpster full of old stuff that they will give you. a place that repairs solid forklift tires would have heavy duty rubber sheets.
Mud flap
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
Mud flaps work. I paid way too much money for body mounting pads for a 56 Ford and when they arrived, they had no fabric in them; so I made some out of mud flaps.
I have an old firehose that I cut up. It is "layered" and with two pieces it comes out just right. I glued two pieces together for my panel mounts and they look nice. The hose has rubber and also a couple layers of what is probably woven polyester fabric that will never rot.
Just another possiblity.
Subframe bushing from a GM "F" body might work
got any rough idea ,or size's,picture of what it looks like,i might have some thing that might work .
Poly-urethane from McMaster Carr. About a 80 or 90 durometer. you can also buy casting urethane from McMaster Carr in 88 durometer. It is a 2-part urethane. I have used it to re-cast rubber parts as well as make new parts. I have made bushings new again by removing all the rubber and re-casting with urethane. Urethane is impervious to almost every chemical
It would work great for building transmission mounts if you cast it right.
I was able to get hold of some conveyor belt, and it worked well. That casting urethane sounds interseting - I'll have to check it out. Thanks for all the great input everyone.
