| | | Forums66 Topics128,056 Posts1,055,792 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#46006 06/08/2005 1:56 AM | Joined: Mar 2004 Posts: 313 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 313 | Hi Fellow Bolters! I know it is hard to diagnos things w/o seeing the vehicle, but my 235 has a intermittent miss on acceleration. The engine only has about 250 miles on the overhaul, new plug wires, coil, dist.cap, rotor, plugs, etc. I also have cleaned and sealed the fuel tank, and have an in-line fuel filter on the truck. It don't seem to miss when it idles, and isn't a constant miss. There isn't any backfire like when a coil has gone bad, or a coil wire is broke. I also switched out the coil for another new coil just to be sure. I did the same with the coil wire. I know what the Chevy truck manual says to look for, but everything is new. Any thoughts? Thanks! KT
1953 3100 with 1957 235, T5 and 12 bolt 373 rear
#46007 06/08/2005 3:48 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I had a cheap distributor cap that was bad right out of the box before. Other than that, it's kinda hard to diagnose without experiencing it first hand, good luck, Scott | | |
#46008 06/08/2005 2:07 PM | Joined: Dec 2003 Posts: 510 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 510 | I'd suspect points or condensor....maybe the distributor itself. I don't like points, so if it were mine, I'd put a Pertronix kit in it.
I had the same type of problem with my 64 292. I finally replaced the distributor with an HEI. No more problems. In my case the distributor bushings were worn (which contributoed to the problem), so it was easier for me to install the HEI than rebuild the distributor and install the Pertronix. | | |
#46009 06/08/2005 2:22 PM | Joined: Feb 2005 Posts: 399 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2005 Posts: 399 | I looked at those Petronix kits, do they just drop right in? And, do I need to get their coil also? Mine is running just fine, but I think it's just a matter of time that I'll have to mess with the points...Thanks, Steve | | |
#46010 06/08/2005 4:39 PM | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | If your distributor is in good working order, a pertronix would be a good choice. Keeps the original look. Takes about 10 min. to install. I have a Mallory coil, but any electronic coil will work. | | |
#46011 06/08/2005 4:43 PM | Joined: Jan 2004 Posts: 210 Member | | Member Joined: Jan 2004 Posts: 210 | | | |
#46012 06/09/2005 12:30 AM | Joined: Mar 2004 Posts: 313 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 313 | Thanks to all who replied. Well, 48Bigtrucks, you have a point. I will switch out the cap and the condensor and see it that makes a difference.I may also check out those pertronix you all are refering to. Thanks again!!! KT
#46013 06/09/2005 12:51 AM | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | About Pertronix. My dealer doesn't have them but has the Crane line. I bought one for a Mustang and this "10 minute install" was more like an hour. You have to remove the distributor on them F**ds. | | |
#46014 06/09/2005 7:29 PM | Joined: May 2004 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 150 | Do you know where you can purchase a Pertronix kit for a '50 3100 (215 engine)? I've checked all of the on-line catalogs I know of and am coming up empty-handed. Thanks. | | |
#46015 06/09/2005 9:07 PM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | I think NAPA among others sell Pertronix, or give them a whistle at www.pertronix.com. You know how to whistle, don't you? | | |
#46016 06/09/2005 9:17 PM | Joined: Jun 2005 Posts: 5 Junior Member | | Junior Member Joined: Jun 2005 Posts: 5 | Sorry, I could not find a "new post" link in the main forum, so I'm doing a reply.
I have a 4 bbl Quadra on my daughters 82 Olds Delta 88 307 Y engine (not orig carb, non-electronic) A friend helped me rebuild it about 4 years ago. About a week ago, it would not start without pouring gas into the carb, then would run fine. The bottom plugs were sealed when it was rebuilt. I changed the fuel pump, and after that it would not remain running after pouring gas into the carb. I removed the fuel line and it is pumping fuel, I removed the fuel filter even though it looked OK, still will not remain running. I do not see any jets of fuel when the accel is depressed. I noticed that the accelerator pump rod was stuck down. I cleaned and loosened up but still not running. Do you think its the Accel pump or float? Why would switching the fuel pump make it completely cease to run?
Thanks Mike Glavin | | |
#46017 06/09/2005 9:36 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You may have too use a latter dist. Like from a 235 to put a petronics on. The crane is agood system but doesn,t cover that model. You might take a hard look at the plugs. I,ve got bad ones out of the box or cracked one putting them in. If the ignition is good you might look for lean carberation or slow timing.  They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#46018 06/19/2005 6:26 AM | Joined: Sep 2002 Posts: 15 'Bolter | | 'Bolter Joined: Sep 2002 Posts: 15 | jcwhitney sells both pertronix and crane cams fireball......I like my little fireball...and yes you gotta pull the distributor out but hey...beats the pants off dealing with points..!! jo's 54GMC
now...where did that part go??
#46019 06/19/2005 6:49 AM | Joined: Sep 2004 Posts: 120 Member | | Member Joined: Sep 2004 Posts: 120 | Maybe it is the accelerter pump in your carb, you did not say any thing about rebuilding it. | | |
