3 members (Woodcmiami, Cosmo, 1 invisible),
75
Mod | | | Forums66 Topics128,150 Posts1,056,991 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 84 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 84 | Howdy Doo Pard'ners: Before I start I know this topic has probably been covered ad nauseum but I had couple of questions I couldn't find by searching. My '53 3100 has a pretty decent gas tank but it's full of goo from sitting for 20+ years. No rust thru though. Anyway I ordered a new tank and my original filler neck just ain't matching up any where near close. Has anyone else had this problem? I'm trying to use as much of the original truck as I can for cost and plain old nostalgia. I'm considering sending the tank back and restoring the old one. My question is if I don't go the POR-15 route does anyone know of a place that will clean the tank and hot dip galvanize it?
1953 3100 | 1958 3/4-ton NAPCO
| | | | | Joined: Feb 2008 Posts: 829 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 829 | There's a radiator shop in Giddings that will clean and "seal" it for around $130. | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | If the parts not right send it back. The more people who have valid complaints and voice them, the better the chance that the vendor will learn that quality does make a difference and they can take steps to correct their parts.
That being said, if they had made a tank that was appropriate for my COE, it probably would have been cheaper to buy one. The POR-15 sealer, marine clean, and metal ready cost me about $100, but I also bought the gallon sized containers. Add in the 6 gallons of muriatic acid it took to clean it properly, several boxes of baking soda to neutralize the acid, plugs for the tank, etc. Then add the time involved to do everything.
Hope that info helps.
Jeff | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | I have several reproduction tanks that were made in Canada and they fit like oem in gmc's as well as Ford cars. They may have sent you the wrong part number. Stale gas and lead sediment is really hard to get rid of and you almost have to take a used tank to a shop because you can't ship it unless it is degassed and clean. | | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | My preference is OEM parts over repops when possible. If you can find a radiator shop that will boil out your old tank you probably won't even have to coat the inside. Whether you have to coat it depends on the amount of rust on the inside. If there's little to no rust you'll be good to go with just a cleaning. If there's a significant amount of rust you'll need to acid clean it, then coat it. When cleaning/coating I use basically the same process as rustednuts except I use RedKote instead of POR-15. That's not a criticism of POR-15 because I've never used it. Of the several coatings I've used over the years, RedKote is by far the best I've used. My 2¢
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I would look for the right new tank. Ive had problems with every one ive had clean & or coated. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | My 37 tank was in pretty bad shape. I bought the POR kit back in 1999 for about $50 back then. I did buy some muriatic acid from Lowes and spent one afternoon cleaning, and then coating it inside. 8 years later it is still nice inside. I can look stright down into it as its directly under the seat of the 37 and its holding up good. I might add that with the kit came enough of the regular Por15 to coat the outside as well. This is just MY experience.
Yes, I want to put the tank under the bed but haven't found the right solution yet......meaning some way that doen't rob the bank | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Also a lot depends on what kind of use you are going to with it. If it will be used regularly gas splashing around will keep it coated. If it is going to set for periods of time, the parts not contacted with gas will start rusting or the coating can dry out & peal. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | I bought a reproduction tank for my '54 GMC, fits exactly like OEM, no problem. I spent about $160.00 for the new one and probably would have spent that much fixing the old tank and maybe with less than good results. | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | I'd go reproduction myself. | | | | | Joined: Mar 2008 Posts: 374 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 374 | Yes, I want to put the tank under the bed but haven't found the right solution yet......meaning some way that doen't rob the bank...
I put the tank under the bed of my '46 for about $275... even had it fabbed out of aluminum. Feels alot better than 'sitting on' 25 gals of fuel. | | | | | Joined: Feb 2007 Posts: 513 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 513 | i would just buy a new one, then you know for sure there are no pin holes or anything 1949 Chevy 3600 Flatbed all orginal 1964 gmc 4000 1973 gmc 6000 2005 chevy duramax 4x4 1994 chevy 1500 Trucks are GM and Tractors are Orange "I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton | | |
