2 members (J Lucas, Erniegp),
78
Mod | | | Forums66 Topics128,054 Posts1,055,780 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 38 Apprentice | | Apprentice Joined: Sep 2006 Posts: 38 | Hello,I have removed My rusty headers and want to remove the rust and paint them with a high temp paint.I think after I wire brush them I will soak them in vinegar for a couple of days and then high pressure wash them before painting them.Does this sound like it will work? As far as painting them what would work best? a rattle can paint or a brush on? how about Por-20? I want a good coating that won't burn off and will last for at least a couple of years. | | | | | Joined: Jun 2007 Posts: 53 Shop Shark | | Shop Shark Joined: Jun 2007 Posts: 53 | if you want a paint that will last, get a couple of spray cans of catapillar muffler paint, it only comes in black, I have it on a set of headers and exhaust tubing now for 2 years and it is still going strong. Mike Bourg | | | | | Joined: Sep 2006 Posts: 38 Apprentice | | Apprentice Joined: Sep 2006 Posts: 38 | I'll have to check that out,Theres a Cat store not far from me
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Much written...much said about this. Most swear that the BEST way to ensure lasting appearance is to poweder coat but I personaly cannot say. Someone says the "best" thing to do is rub them down good with the old time polish folks put on wood heaters back years ago. Its still available and if/when needed just spruce the headers back up with a light coat! Someone here stated a while back that it worked good for them. Maybe do a search and see what you come up with?! | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I always say, "once you have rust, you always have rust". I think cleaning and repainting will only be temporary at best. Recoating new headers with high quality high temp paint would be best but that's just my 2 cents worth, Scott | | | | | Joined: May 2007 Posts: 275 Shop Shark | | Shop Shark Joined: May 2007 Posts: 275 | I don't think powder coating will help. Header can reach temperatures of over 1500 degree F. Powder Coating temperatures melt at 425 degrees F. The only method that will work is Ceramic Coating. Caterpillar muffler paint will work. It's a shame it only comes in Black.
Frank
No better smell than that of fresh paint. I've been building and painting cars/trucks for 47 years. Not gonna stop now. http://www.coxcustomcars.com/ | | | | | Joined: Sep 2006 Posts: 38 Apprentice | | Apprentice Joined: Sep 2006 Posts: 38 | I gotta tell Ya, That Vinegar really takes the rust off.I will be getting some type of high temp paint tommorrow.Also to get the header off of the drivers side I have to take off the motor mount and pull the header out thru the engine compartment.I was going to take the clutch linkage off and pull the header off from under the truck.But thats pretty tough to do too. | | | | | Joined: Sep 2006 Posts: 38 Apprentice | | Apprentice Joined: Sep 2006 Posts: 38 | Well I painted one of the headers today. I used a 12 oz can of Dupli-color "High Heat with Ceramic" And whats really cool is it is Orange!! They had a choice of a dark blue and the Orange..I chose Orange because I dont like blue. Anyway it is High Heat for up to 1200 degrees. I hope it lasts at least a couple of years.I am having trouble getting to one of the bolts holding My motor mount on but when I get to it I will be able to paint the other header... I am excited about getting them done now!! Only problem now is I want to paint the Engine Block!!! | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 |
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Well, one of the problems with painting cast iron is that it is porous. Moisture can actually travel right through it eventually, although very slowly. While the 1200 degree paint won't melt off, moisture from the exhaust eventually seeps through the cast iron and gets behind the paint. There is nothing you can do about this, and it is also the reason that only graphite and ceramic stick to cast iron for very long- graphite just works more like a stain and hides any rust, and ceramic forms an impermeable barrier and just kind of encases the cast iron.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Oct 2007 Posts: 84 New Guy | | New Guy Joined: Oct 2007 Posts: 84 | For me, I use BBQ paint. High heat, cheap to buy and I have over 2 years on one app on my Fentons. good for me. dg | | | | | Joined: Jan 2008 Posts: 227 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 227 | DGERTH has hit the nail right on the head ! We call it "Potbelly Black" in Australia....named after our cast iron pot belly wood fires. It soaks into the cast iron and will withstand any ANY temperature that you can throw at it. If any rust,light patches or repairs are needed, just paint on another layer.......will never discolor, peel or flake. Worth every cent of it's $2 asking price for a tins' worth at the local hardware store, which will outlast not only the life of the vehicle, but your grandkids as well! | | | | | Joined: Nov 2006 Posts: 677 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 677 | I used the POR 20 Myself, It worked OK... I followed the instructions as directed, my wife wouldn't let me bake them in the oven so I removed one of the racks in my BBQ and put some aluminum foil on the bottom so the flames wouldn't touch the paint and turned it up as high as it would go and Baked them ! (for 30 min) It worked ! "freaked my neighbors out" but it worked  Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs. 1951 3100 350 TBI Gallery Toddzilla... "$old" | | | | | Joined: Jul 2006 Posts: 186 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 186 | I was trying to figure out how to 'heat treat' my headers also knowing that the wifey won't let me use her new oven. I never thought of using the BBQ grill. Duh! Now I don't have a gas grill so I have to figure out how much charcoal to use to get the right heat!!!
Still trying to get ole Betsy back on the road.
