3 members (DadsFirstPickup, Hotrod Lincoln, Otto Skorzeny), 163 guests, and 1 robot.
Topics128,131
Posts1,056,722
Members48,454
#238066 07/30/2007 3:05 PM
I need to put new shoes on my truck, and will have the drums turned if they have enough meat. If not, does NAPA sell them?
Craig
they should have'em, my local does, spendy tho'
cmayna, shop around. I have found a big price difference from one place to another. Also remember what years work and ask fo rhe "latest" model year. Seems some want even try if their computer doesn't go back that far. A good counter man is a MUST in most cases back past about 1955. They have access to more parts than what is in the computer but that may also be when "spendy" comes in as mentioned by Red58
Call Gary Tidwell at: 817-220-7278 He is an old time parts guy. One of the real ones.
Tell him "Builder" (Uncle Carl's Nephew) told you to call. If that don't ring a bell for him, tell him I drove the IRWIPI truck to South Dakota.
Well, I just realized I might have forgotten a very MINOR issue. If I remember correctly, when my front Oak tree crushed my '53, I bought the '50 and I believe I swapped the entire driveline including the front axle.
So, I'll need to pull the drums to see what the heck I have.
My local NAPA has the '51-'59 drums for $67 each which isn't too bad. Hopefully that is what I need.
Craig
Socket Breaker
Socket Breaker
http://www.napaonline.com
I selected
1953
chevrolet truck
3100
Browse Catalog >> Brake Systems >> Rotors, Drums & Related Parts
Vehicle: 1953 >> Chevrolet Truck >> 3100
Brake Drum - Front
TS
4401071
$41.49
w/ 11" X 2" Brakes w/ 1/2 Ton Chassis
Brake Drum - Front
UP
6401071
$64.99
Brake Drum - Rear
TS
4401071
$41.49
Brake Drum - Rear
UP
6401071
$64.99
so, yes, apparently they are still in the NAPA parts system.
Yay!
-W
Any idea what country these are made in?
Probably Mexico, although there's still alot of rotor/drum casting still being done in the US, especially with the premium line parts. Funny thing is that you're more likely to get a USA made drum/rotor aftermarket that you are OE these days.
Bill Burmeister
1 Offline
if your not keeping it stock uprade with duel mc. and discs. front drums are for museum pieces along with standard steering.
Socket Breaker
Socket Breaker
