| | | Forums66 Topics128,130 Posts1,056,712 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 2,842 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,842 | I need to put new shoes on my truck, and will have the drums turned if they have enough meat. If not, does NAPA sell them?
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | they should have'em, my local does, spendy tho'
Bill | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | cmayna, shop around. I have found a big price difference from one place to another. Also remember what years work and ask fo rhe "latest" model year. Seems some want even try if their computer doesn't go back that far. A good counter man is a MUST in most cases back past about 1955. They have access to more parts than what is in the computer but that may also be when "spendy" comes in as mentioned by Red58 | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Call Gary Tidwell at: 817-220-7278 He is an old time parts guy. One of the real ones.
Tell him "Builder" (Uncle Carl's Nephew) told you to call. If that don't ring a bell for him, tell him I drove the IRWIPI truck to South Dakota. | | | | | Joined: Jan 2002 Posts: 2,842 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,842 | Well, I just realized I might have forgotten a very MINOR issue. If I remember correctly, when my front Oak tree crushed my '53, I bought the '50 and I believe I swapped the entire driveline including the front axle.
So, I'll need to pull the drums to see what the heck I have.
My local NAPA has the '51-'59 drums for $67 each which isn't too bad. Hopefully that is what I need.
| | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | http://www.napaonline.com I selected 1953 chevrolet truck 3100 Browse Catalog >> Brake Systems >> Rotors, Drums & Related Parts Vehicle: 1953 >> Chevrolet Truck >> 3100 --------------- Brake Drum - Front TS 4401071 $41.49 w/ 11" X 2" Brakes w/ 1/2 Ton Chassis --------------- Brake Drum - Front UP 6401071 $64.99 w/ 11" X 2" Brakes w/ 1/2 Ton Chassis --------------- Brake Drum - Rear TS 4401071 $41.49 w/ 11" X 2" Brakes w/ 1/2 Ton Chassis --------------- Brake Drum - Rear UP 6401071 $64.99 w/ 11" X 2" Brakes w/ 1/2 Ton Chassis --------------- so, yes, apparently they are still in the NAPA parts system. Yay! -W | | | | | Joined: Jun 2005 Posts: 38 Member | | Member Joined: Jun 2005 Posts: 38 | Any idea what country these are made in? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Probably Mexico, although there's still alot of rotor/drum casting still being done in the US, especially with the premium line parts. Funny thing is that you're more likely to get a USA made drum/rotor aftermarket that you are OE these days.
Bill Burmeister | | | | | Joined: Jul 2005 Posts: 595 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 595 | if your not keeping it stock uprade with duel mc. and discs. front drums are for museum pieces along with standard steering. | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | | | |
